SDPC
Old 08-18-2012, 09:06 PM   #141
Russell James
Russell James's Avatar
Drives: Camaros
Originally Posted by L99CAMA2011 View Post
Is this just the gear pieces or the whole pumpkin. Would the 1LE pumpkin fit our SS.
Just the gears. Not sure that there is anything else different inside the housing. All the info I've seen on the package has talked about the new rear gears and new axles. I haven't seen anything indicating anything else inside the diff case has changed. Yes it would fit, just not sure why you would need the whole thing.
Old 08-18-2012, 09:13 PM   #142
L99CAMA2011
L99CAMA2011's Avatar
I thought the 1LE had a diff with a diff cooler. This would also be a good upgrade having a cooler diff for road course stuff.
Old 08-19-2012, 07:09 AM   #143
Russell James
Drives: Camaros
I haven't seen that. Nobody has actually worked on one yet, probably will know more as they start to get delivered. But the only difference in the rear diff that I can see is the R&P gear. The 1LE case and diff carrier are the same part numbers as the SS w/o 1LE.
Old 08-19-2012, 08:31 AM   #144
Higgs Boson
in the ZL1 Market
Drives: 2014 C7; 2015 2500HD
is there a part number for an assembled diff?
Higgs Boson is offline   Reply With Quote
Old 08-19-2012, 09:07 AM   #145
Russell James
Drives: Camaros
The complete 1LE differential, case and everything inside it, is 22806794. Retail list price $1821.98.
Then all the parts inside it are available as individual service parts.
Old 08-19-2012, 09:13 AM   #146
TAG UR IT
www.Camaro5store.com
TAG UR IT's Avatar
Drives: 2014 ZL1 #705
Caught up...but still have questions. Need to make a call later...
Old 08-19-2012, 09:27 AM   #147
Higgs Boson
in the ZL1 Market
¡¡aye chihuahua!!!
Old 08-19-2012, 10:30 AM   #148
pouncer72
Drives: 2011 Camaro SS
Send a message via AIM to pouncer72
Awesome, looks around $1300 to my door. Since you don't have to pay a core, that's a really good price.
pouncer72 is offline   Reply With Quote
Old 08-19-2012, 10:57 AM   #149
Russell James
Drives: Camaros
Wouldn't someone just need the gears? Just curious about the interest in the whole rear for an SS. I'm doing the 3.91s soon, want to make sure I'm not missing something. So far my plan is just the gears, axles, hubs, pinion crush sleeve and shim kit.
I'm also trying to figure out what if anything is different about the 1LE driveshaft. Possibly the bolts?
Old 08-19-2012, 11:47 AM   #150
pouncer72
Well, it's $400 for gears + install kit, and probably 300 more for installation.
So $700.
Or you can get a factory pre-setup rear for ~$1300-1500, and sell your old one for $700.
So $700.
It's the same actual cost, either way.
Old 08-19-2012, 12:41 PM   #151
Russell James
Drives: Camaros
Ok, interesting thought. Or, one could keep the stock diff and put it back in at trade in time. It does open up some possibilities.
Old 08-19-2012, 01:08 PM   #152
376LS3
Eh, that'll happen
376LS3's Avatar
Drives: 2010 2SS
So $700.
So $700.
Can you tell where you found $1300 shipped? Cheapest I found was $1509+shipping.
2010 Camaro SS LS3 - No Modz
376LS3 is offline   Reply With Quote
Old 08-19-2012, 01:33 PM   #153
Jason@JacFab
Jason@JacFab's Avatar
Drives: 2016 1LT RS Camaro; 72 Chevelle
Send a message via AIM to Jason@JacFab Send a message via MSN to Jason@JacFab
I was doing some reading on what people were paying just for the gear install, and between the gears, install kit, and labor most were in the $1200 range, even saw some in the $1400-1600 range. I can probably get the 1LE diff to my door for under $1400 through my local dealer, I'd just go that route.
2016 1LT RS, 2.0T A8
13.462 @ 100.65, stock eng/tune w/ some weight reduction
Jason@JacFab is offline   Reply With Quote
Old 08-19-2012, 01:49 PM   #154
376LS3
Eh, that'll happen
376LS3's Avatar
Drives: 2010 2SS
Ya, Im with you. Id much rather have a brand new GM diff delivered to my door for the same price as a gear install! Lol!
