Old 08-30-2012, 11:11 PM   #267
dcplus14
dcplus14's Avatar
Drives: '12 Camaro 2SS/RS/Hurst
This thread is truly awesome!
Any updates on anyone ordering and/or installing the axles and hubs?
2012 Camaro 2SS/RS: Black on Black, Hurst
[AAC DRL LED's, AAC LED's for trunk, cabin, license plate, CAI Intake, RX Catch Can, Skip shift eliminator, Pedders Sub-Frame Inserts, Pedders Radius Rod Inserts, Pedders Rack & Pinion Bushing, 1LE front and rear sway bars]
dcplus14 is offline   Reply With Quote
Old 08-30-2012, 11:36 PM   #268
pouncer72
Drives: 2011 Camaro SS
Send a message via AIM to pouncer72
Originally Posted by ssmike View Post
Unless it's tuned!
Nope. 6th gear is too long to pull. 5th gear nets a higher top speed.
pouncer72 is offline   Reply With Quote
Old 08-31-2012, 11:13 AM   #269
asrautox
Drives: 2010 SS
Originally Posted by Stingraye View Post
On the back order waiting list for the gear set. Thanks Maureen!
Same here! Now the waiting game...
asrautox is offline   Reply With Quote
Old 08-31-2012, 02:42 PM   #270
pouncer72
Waiting on the call to pick up my finished rear end... dropped it off this morning with the gear install folks
Old 08-31-2012, 10:08 PM   #271
RobertHarriSS
RobertHarriSS's Avatar
Drives: 2SS/RS M6
I'm in that line too.
RobertHarriSS is offline   Reply With Quote
Old 09-01-2012, 07:14 AM   #272
MA2010SS
Drives: 2010 Camaro SS
Does anyone know what kind of power the 1LE axles are rated for? I haven't found any info on that.
2010 Camaro SS Whipple SC, CAI Inc Intake, TSP 1 7/8" LT headers no cats, 3" magnaflow exhaust, HPT, RX Catch Can, LSR Toe Rods, LSR Trailing Arms, ALKY Control Meth, McLeod RXT Twin Disc, ZL1 fuel pump, 3.73 ZL1 Differential Kit, BTR PDS Stage 2 Cam, Tuned by SLOWHAWK Performance Bridgewater MA
MA2010SS is offline   Reply With Quote
Old 09-01-2012, 09:25 AM   #273
Russell James
Russell James's Avatar
Drives: Camaros
426 through a 3.91 final drive and MM6 Tremec.
The SS M10 Tremec has a shorter first gear, so it will be interesting to see if a stripper SS could holeshot a 1LE. The MM6's close ratio gears though would probably even up or better the run after a few gear changes.
It's more than just a hp rating when considering axles. It's matching the torque at the axles to an axle with just the right twist properties. You don't want too much or too little, which is why you see different axles on each side of an OE application. They've tested out the optimum axle for each side. If you just through hugely oversized 1400 hp axles in both sides, in an otherwise stock driveline, expect to break diffs, driveshafts... The axles will probably hold just fine, but now your moving the twist/wrap up to other parts that weren't designed for it. Getting the right axle twist is also key to avoiding wheelhop.
Another thing to look into is any mods done to the 1LE driveshaft, such as bigger bolts. Probably a good reason those got upgraded also.
Old 09-02-2012, 01:21 PM   #274
tazz3
Drives: 2012 camaro
sorry for the newbie question how come the 1LE is not on chevys web site it is an option for the SS or ZL1??
tazz3 is offline   Reply With Quote
Old 09-02-2012, 01:23 PM   #275
nak3dsnake
nak3dsnake's Avatar
Drives: 2010 Camaro IBM 2LT/RS M6
Its an option for the SS. Its not its own model.
Looks: AAC P13W DRLs, Heritage Grille, RS Embroidered Headrests, GM Door Sill Plates, GM Premium Floor Mats, Body Color Engine Cover, LLT Mobile 1 Oil Cap, ZL1 Sport Pedals, 3M Clear Bra.
Performance: Vararam Ram Air Intake, Hurst Short Throw Shifter w/ Hurst Hard Drive Pistol Grip, IDEALG Clutch Master Cylinder, RX Catch can, GTO clutch fluid reservoir, Brembo Brakes, 1LE Track Pack, GMPP Exhaust Upgrade.
nak3dsnake is offline   Reply With Quote
Old 09-04-2012, 11:27 PM   #276
Avalnch
Avalnch's Avatar
Drives: Rally Yellow Camaro+Avalanche
Thanks Maureen@RodgersChevrolet.com
Hot off the UPS truck...
Going in next Monday!
But, check this out!
Vengeance Kaotik Cam, C.A.I., ARH LT, Pypes Cat Back, ZL1 Shifter+2012LS3VERT bushing, Quantum Brake Ducts, JDP Tow Hook Scorch Yellow Trim Kit, Shark Fin, AAC DRLs+ABLs+SMDs, ZTA Rear Spoiler, R.Y. 1LE Splitter. Pfadt coilovers, camber plates, trailing arms, Pegasus Solid Subframe. Pedders ZL1 barz, radius arm & steering rack bushings. BMR adjustable toe-rods. Hotchkis Max Chassis Brace. ZL1 GMPP Driveline Upgrade. TurnOne P/S pump.
447 HP @ 6180 RPM / 418 TQ @ 5100 RPM
Avalnch is offline   Reply With Quote
Old 09-05-2012, 07:49 AM   #277
TAG UR IT
www.Camaro5store.com
TAG UR IT's Avatar
Drives: 2014 ZL1 #705
Sweet deal! Let us know how it goes.
FULL REPORT
Old 09-05-2012, 09:30 AM   #278
blazzin1
blazzin1's Avatar
Drives: 2016 2SS (A8)
Awesome, Congratulations! Were you on Maureen's "waiting list", or did she have some in-stock when you called???? Wonder how long it's going to take for some more to show up!?!?!?
blazzin1 is online now   Reply With Quote
Old 09-05-2012, 11:42 AM   #279
blazzin1
blazzin1's Avatar
What are the differences with the ZL1/1LE Hubs vs. the regular SS Hubs?
1LE/ZL1 Hubs - 22924741 (x2)
Are the hubs bigger, stronger, better is some way? Are they required if upgrading to the 1LE axles? Just wondering what the benefit is with these hubs? Thanks in advance....
Old 09-05-2012, 05:12 PM   #280
376LS3
Eh, that'll happen
376LS3's Avatar
Drives: 2010 2SS
ZL1 have a different spline count and cannot be used in the SS. Not sure if hubs are required for 1LE axles. I think they are though.
2010 Camaro SS LS3 - No Modz
376LS3 is offline   Reply With Quote
