Old 09-10-2012, 05:01 AM   #295
2012REDSS
Drives: 2012 Camaro SS
with the gears themselves being so cheap I think everyone is just swapping the gears themselves. Even after the gears, LPE install kit, LPW diff cover, JRE posi mod, and install I'll still be under the price for the 1LE rear diff.
2012REDSS is offline   Reply With Quote
Old 09-10-2012, 06:50 AM   #296
TAG UR IT
www.Camaro5store.com
TAG UR IT's Avatar
Drives: 2014 ZL1 #705
Originally Posted by parano View Post
my breakin procedure was done with my 1le 3.91 gears!!! OMG!!!the car is awesome now!!!
that much better, huh?
Old 09-10-2012, 08:28 AM   #297
blazzin1
blazzin1's Avatar
Drives: 2016 2SS (A8)
Just an FYI.....I got an e-mail back from Maureen at Rodgers Chevrolet this morning. She said the 1LE Axles are not available yet, and would only "cancel" if she ordered them at this point. Nothing mentioned about the Hubs, I'm assuming the same. Also, she said no new news on the gears yet.....still backordered.
blazzin1 is offline   Reply With Quote
Old 09-10-2012, 10:04 AM   #298
caverman
caverman's Avatar
Drives: '69 SS Convertible
Yes.....3.91 are that much better.
I use 6th gear around town a heck of a lot more than I used to. Just another perk for having the gears.
Stop light to stop light butt dyno is awesome. You definately won't be disappointed and will kick yourself for not doing it sooner.
I had to pay the big bucks for LPE but everyone hang in there. GM will eventually get the gears rolling and this will be the best way to do it by using the 1LE gears. Start looking for a place to get them installed.
Build Journal
Old 09-10-2012, 04:54 PM   #299
ssmike
Missing Big Red
ssmike's Avatar
Drives: 2006 Corvette DSOM, '13 Equinox CRT
I just got on Maureens list for gears! The waiting begins!
Not a Camaro but it works for now!
Old 09-10-2012, 05:48 PM   #300
dcplus14
dcplus14's Avatar
Drives: '12 Camaro 2SS/RS/Hurst
Does this mean we'll be going through our stock clutches quicker now?
2012 Camaro 2SS/RS: Black on Black, Hurst
[AAC DRL LED's, AAC LED's for trunk, cabin, license plate, CAI Intake, RX Catch Can, Skip shift eliminator, Pedders Sub-Frame Inserts, Pedders Radius Rod Inserts, Pedders Rack & Pinion Bushing, 1LE front and rear sway bars]
dcplus14 is offline   Reply With Quote
Old 09-10-2012, 07:37 PM   #301
Higgs Boson
in the ZL1 Market
Drives: 2014 C7; 2015 2500HD
no.
Higgs Boson is offline   Reply With Quote
Old 09-11-2012, 06:53 AM   #302
TAG UR IT
TAG UR IT's Avatar
sweet
Old 09-11-2012, 11:21 AM   #303
dcplus14
dcplus14's Avatar
Originally Posted by Higgs Boson View Post
no.
Well that explains much. It seems that if the frequency of me shifting gears goes up the more likely I'll be using the clutch more frequently as well.
I'm guessing that the clutch is the same in the 1LE option, so in the long run, it may only be a minimal difference in clutch wear.
Old 09-11-2012, 01:14 PM   #304
pouncer72
Drives: 2011 Camaro SS
Send a message via AIM to pouncer72
Total install cost for the 3.91s for me was $159.50 at the local diff/trans shop plus the cost of an axle seal. I brought them the pumpkin. Hell of a deal if you ask me. Cant wait to get it back in the car
pouncer72 is offline   Reply With Quote
Old 09-11-2012, 01:22 PM   #305
blazzin1
blazzin1's Avatar
That's awesome!!! That was my plan too...to just bring them the pumpkin. Did you install the posi-fix or billet caps?
Old 09-11-2012, 01:39 PM   #306
pouncer72
No, I don't believe either are necessary with an automatic. 6 speed cars break a lot more parts though, the caps would be very beneficial for a 6sp.
Old 09-11-2012, 01:51 PM   #307
blazzin1
blazzin1's Avatar
True....True. I have the manual, and definitely plan on beefing up the rear end a little bit when I change the gears. But I'm having a hard time deciding if I want to just put in the posi-fix, or change out the entire posi-unit for that Eaton Tru-Trac. I seriously doubt I'll ever be over like 580hp or so, so I'm thinking the posi-fix will probably be enough.
Old 09-11-2012, 01:53 PM   #308
Kent2010
Drives: Camaro SS
How is everyone accounting for the new gear ratio? A tune? Can it be changed via a Tech2 by a dealer?
I'd love to have the 3.91's but I don't want to risk my entire 100k mile drivetrain warranty by adding a tune. I am hoping there is another option.
Kent2010 is offline   Reply With Quote
