SDTW Custom Wheels & Tires
Old 08-03-2012, 05:52 PM   #43
Higgs Boson
in the ZL1 Market
Drives: 2014 C7; 2015 2500HD
different axles.
Higgs Boson is offline   Reply With Quote
Old 08-03-2012, 08:26 PM   #44
monstertodd
monstertodd's Avatar
Do we know yet if any of these parts will even fit on a 2010-2012 SS?
Old 08-03-2012, 08:50 PM   #45
Higgs Boson
in the ZL1 Market
all of them will fit on 2012 (FE4).
some of the suspension pieces will need different control arms/links, etc on 10-11 cars.
I am already running the ZL1 rear sway bar, steering wheel (lol), and toe rods. Plan on getting the gears and wheels as well. Axles and hubs are as necessary.
Old 08-04-2012, 10:59 AM   #46
Birm
Birm's Avatar
Drives: Florida Speed & Power
10/11's will require some changes to LCA's (FE4/5) for the sways but the differentials and axles should be interchangeable.
Birm is offline   Reply With Quote
Old 08-04-2012, 11:00 AM   #47
Birm
Birm's Avatar
Old 08-04-2012, 11:28 AM   #48
Jason@
Drives: 2016 1LT RS Camaro; 72 Chevelle
Send a message via AIM to Jason@ Send a message via MSN to Jason@
That's only for the rear swar bar, right? Isn't the front the same on the 10-11, as the 12+?
2016 1LT RS, 2.0T A8
13.462 @ 100.65, stock eng/tune w/ some weight reduction
12.957 @ 103.45, JacFab BigMouth TB & Charge pipe, Catless downpipe, LSD diff swap, Ghetto drag pack, unfinished tune.
Jason@ is offline   Reply With Quote
Old 08-04-2012, 12:08 PM   #49
pouncer72
Drives: 2011 Camaro SS
Send a message via AIM to pouncer72
Correct
pouncer72 is offline   Reply With Quote
Old 08-06-2012, 04:00 AM   #50
C-redfly
C-redfly's Avatar
Drives: 2012 completely Red Camaro
Does anyone know if the 1le axles/hubs and differential with 3.91 gears will merge with the 2012 v6 A6?
C-redfly is offline   Reply With Quote
Old 08-06-2012, 04:20 AM   #51
C-redfly
C-redfly's Avatar
Can someone pm with a price qoute on your ss axles an hubs and differential if you purchase the 1le set up? Keep me in mind Thxs.
Old 08-06-2012, 01:13 PM   #52
vandervortadam
Drives: 2010 Camaro 2ss black 21's
Can i just get the gears and slide them right in my 2010ss. If so that would be great.
vandervortadam is offline   Reply With Quote
Old 08-06-2012, 02:39 PM   #53
Higgs Boson
in the ZL1 Market
$64K question. when they are available, we will all be trying, trust me....
Old 08-06-2012, 05:18 PM   #54
Driveshaftshop
Driveshaftshop's Avatar
Drives: own more cars than i can list
I'd really like to know about the drive shaft as well.
i was also told the shaft had 14mm bolts and not the 12mm of the SS
Driveshaftshop is offline   Reply With Quote
Old 08-06-2012, 08:14 PM   #55
LS2SLOW
LS2SLOW's Avatar
Drives: 5th Gen
Has anyone tried ordering the 1le gears from a dealer or somewhere else yet?...I was going to pull the trigger on the lpe set but I'm thinking this is the better route assuming they'll fit in my 2010
LS2SLOW is offline   Reply With Quote
Old 08-07-2012, 02:25 PM   #56
grocerygetter
instigator
grocerygetter's Avatar
Doesn't the GM parts manual power rate drive line parts or is that just for transmissions?
-John S.
Thanks to:
Tony@ dv8motoring
TCAudio in Benton AR
