Gen5DIY
Old 08-07-2012, 03:26 PM   #57
grocerygetter
instigator
grocerygetter's Avatar
bump for subscribed.
-John S.
Thanks to:
Tony@ dv8motoring
TCAudio in Benton AR
Old 08-07-2012, 04:43 PM   #58
Mr_Draco
Mr_Draco's Avatar
Drives: 2SS/RS
Originally Posted by LS2SLOW View Post
Has anyone tried ordering the 1le gears from a dealer or somewhere else yet?...I was going to pull the trigger on the lpe set but I'm thinking this is the better route assuming they'll fit in my 2010
Not available yet.
Old 08-07-2012, 06:13 PM   #59
stt816
Drives: 2012 Black 2SS/RS M6
so is the zl1 sway bar better than aftermarket for my 2012 ss? Can't seem to find any of these parts, where are you guys getting them?
Pfadt Race Engineering 1.25" Lowering Springs| Pfadt Spec Performance Street Alignment|ZL1 Front Bumper Conversion|Factory Reproductions Type 41 Satin 20x9 Rims|Pirelli P Zero All Season Plus 275/40R20Y Square Setup|3M 1080 Matte Black Vinyl Wrapped Hood|Footwell Lighting|G2 Gold Painted Brake Calipers
Stainless Power Long Tube Headers|Cold Air Inductions Cold Air Intake|VMAX CNC Spiral Ported Throttle Body|Stainless Works Retro Chambered Catback
--Jannetty Racing Enterprises Dyno Tuned|408 RWHP
stt816 is offline   Reply With Quote
Old 08-07-2012, 06:30 PM   #60
Higgs Boson
in the ZL1 Market
Drives: 2014 C7; 2015 2500HD
at your local dealer. lol. are they better? depends what you consider better. if you don't need an all out race adjustable red or orange or pink sway bar and are ok spending a fraction of the money, then yes. better.
the aftermarket bars are stiffer but the zl1 bar is a big difference.
Higgs Boson is offline   Reply With Quote
Old 08-07-2012, 06:42 PM   #61
Stingraye
Stingraye's Avatar
Drives: 2011 2SS / RS M6 LS3 IBM
Def interested in the gears and sway bars. I hope they can be ordered soon!
Stingraye is offline   Reply With Quote
Old 08-07-2012, 08:20 PM   #62
Higgs Boson
in the ZL1 Market
sway bars can be ordered, I already am running the rear one.
Old 08-07-2012, 09:10 PM   #63
Stingraye
Stingraye's Avatar
Good to know thanks! Did you feel a decent change with just the rear one or was it done with several parts at once?
Old 08-07-2012, 10:53 PM   #64
Higgs Boson
in the ZL1 Market
just rear. feels different. if you have a street car the ZL1 bar is awesome. if you are going racing on a track then you might want to go all the way with a kit like pfadt or pedders or whatever.
Old 08-07-2012, 11:18 PM   #65
monstertodd
monstertodd's Avatar
"Oppenheiser said owners of current Camaros will be able to replicate most of the 1LE package from the parts catalog, although they won't have access to the unique final-drive ratio or the new electric power steering. Bummer"
Quote from the recent inside line article about the 1LE. According to Al O. the final drive is a no go on previous Camaros?
Old 08-08-2012, 12:06 AM   #66
Higgs Boson
in the ZL1 Market
anything is possible. i think he might mean warrantable access....?
either the gears can be swapped in or the diff can be swapped. halfshafts and driveshafts are easy to modify if needed. depends on the cost at that point. if too much adapting is needed I guess LPE can keep their gears at 800 bucks. which is very lame. gear sets have cost 150 - 200 dollars for decades.
also, I don't think a dealer has the ability to change the ratio in the computer.... you need a tune. so gm will just say it can't be done.
Old 08-08-2012, 07:00 AM   #67
RogerBzSS
RogerBzSS's Avatar
Drives: 11 IBM n White 2SS/RS M6
Subscribed.
Nice!!!!!!
So for SnG's I found GM Parts Giant Website here is the part # and cost with out 3:91 gears and wheels from the list
shipped all under $1K
Remove **806795 SHAFT X1 $196.07 $196.07
Remove **806796 SHAFT X1 $196.07 $196.07
Remove **845487 LINK X1 $67.94 $67.94
Remove **842517 SHAFT X1 $97.65 $97.65
Remove **786260 SHAFT X1 $113.88 $113.88
Remove **924741 HUB X2 $127.52 $255.04
Calculate Shipping
Shipping: $0.00
Total: $926.65 <<<<<<<<<<<<<<<<<<<<<< Nice
I'd really like to know if the 1LE axles are improved and rated to support more HP than the current SS Shafts
or are they improved at the cv joints only using the same rod material as the SS shafts ???
regardless the 1le shafts are still a much better deal than 1000 pony shafts at 1100$$
Sent from my DROID X2 using Tapatalk 2
Black CIA -Powder Coated Red Air Scoop - Vmax Ported Throttle Body - Ceramic Coated Dynatek Headers - High Flow Cats out thru factory Cat Back - JRE rough idle cam package - Trunion Upgrade - Valve Springs - Hardened Push rods - 3 bolt timing gear - SLP Under drive pully- Washer bottle relo kit - Hurst Short Throw Shifter with updated pin bushing from C5 member NH-SS - IdealG's improved Master Cylinder - GTO Clutch reservoir - L99 Brake Reservoir - Stainless Braided clutch line - wrapped up with a JRE Tune My SS layed down 462 hp on JRE's Superflow Dyno
RogerBzSS is offline   Reply With Quote
Old 08-08-2012, 02:40 PM   #68
Cpanthers85
Drives: 2011 Camaro 2SS RS
That, Sir. is the $1100 question I think we are all waiting an answer for!
2011 2SS/RS L99
2017 Chevy SS
1979 Z28
Mods: Kooks Long Tube Headers, RotoFaB EForce CAI, American Thunder Catback Exhaust, PFADT Stage 1 Drag Kit + Front Sway Bar, GM Strut Tower Bar. ZL1 Fuel Pump. Nitto NT05R. RX Catch Can.LS9 Cam and Springs.LS3 Conversion.JRE Fuel Rail Upgrade.Edelbrock Eforce.60# Eforce Injectors.Extreme Racing Tune. 523/495
MY BUILD THREAD
Cpanthers85 is offline   Reply With Quote
Old 08-08-2012, 03:37 PM   #69
monstertodd
Ofer where are ya bud?
Can you figure out what 1LE parts will work on a 2010-12 SS and what won't?
Old 08-08-2012, 03:50 PM   #70
Higgs Boson
in the ZL1 Market
i thought we already went over that....?
2012 suspension is bolt on.
10/11 needs new trailing arms to use the rear sway.
no one knows about the gears or diff 100% yet.
what do you want to know exactly?
