Old 08-08-2012, 04:03 PM   #71
monstertodd
monstertodd's Avatar
Originally Posted by Higgs Boson View Post
i thought we already went over that....?
2012 suspension is bolt on.
10/11 needs new trailing arms to use the rear sway.
no one knows about the gears or diff 100% yet.
what do you want to know exactly?
a DIY thread would be cool?
1) is the 1LE drive shaft an improvement over the stock 2010 SS drive shaft and is it capable of supporting added hp and torque over stock from forced induction? Will the 1LE drive shaft mate up to a 2010 SS TR6060 and differential?
2) Are the 1LE axles an improvement over 2010 SS axles and will they support added hp and torque over stock from forced induction?
3) are the 1LE hubs markedly different over 2010 SS hubs? Will my 20 X 11 and 20 X 9.5 Forgelines fit on 1LE hubs without rubbing/clearance issues?
Old 08-08-2012, 04:32 PM   #72
Higgs Boson
in the ZL1 Market
Drives: 2014 C7; 2015 2500HD
all things that won't be known until the fall when people have these cars or parts in hand. the drivetrain stuff is unknown right now regarding clearances and bolt patterns, etc.
Higgs Boson is offline   Reply With Quote
Old 08-08-2012, 05:01 PM   #73
monstertodd
Hoping Ofer will take the reigns on this one. He's darn good at figuring this stuff out.
Old 08-09-2012, 09:07 AM   #74
RogerBzSS
RogerBzSS's Avatar
Drives: 11 IBM n White 2SS/RS M6
So ?? what are the Zl1 Axle Part #'s I would expect them to be rated a bit higher and to be able to handle a bit more power being the ZL1 rated at 585 Crank HP??
I would also think the ZLI axles to also be interchangeable to the 10's 11's LS3 / L99's??
ZL1 axles are 580 and 507 $ I did not find part #'s for that I would opt for a noted 1000 pony rated axles from
a C5 Sponsor that are direct bolt in!!
Black CIA -Powder Coated Red Air Scoop - Vmax Ported Throttle Body - Ceramic Coated Dynatek Headers - High Flow Cats out thru factory Cat Back - JRE rough idle cam package - Trunion Upgrade - Valve Springs - Hardened Push rods - 3 bolt timing gear - SLP Under drive pully- Washer bottle relo kit - Hurst Short Throw Shifter with updated pin bushing from C5 member NH-SS - IdealG's improved Master Cylinder - GTO Clutch reservoir - L99 Brake Reservoir - Stainless Braided clutch line - wrapped up with a JRE Tune My SS layed down 462 hp on JRE's Superflow Dyno
RogerBzSS is offline   Reply With Quote
Old 08-09-2012, 09:26 AM   #75
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
Drives: To many to list
I was working on adding the ZL1 diif, i think you can run the SS cradle with some moding, (for the cooler lines) It will take the power to 800Hp IMO.
And that for most of us is all we need but there are some that want more i know.
Old 08-09-2012, 11:32 AM   #76
ITGuy11
Burning up tires
ITGuy11's Avatar
Drives: 2010 Camaro 1SS/RS
Please keep us updated on this project. Will you be using the ZL axles as well?
Blower, cam, supporting mods 644RWHP 615RWTQ
My Build Thread COTW 11/19/12
Detroit 5th Gen Camaro Club
ITGuy11 is offline   Reply With Quote
Old 08-09-2012, 12:16 PM   #77
2SSRS@Gen5diy
That is the plan.
Old 08-09-2012, 12:22 PM   #78
ayceman
Drives: 2007 Dodge Charger SXT, 2010 2SS
Any idea on the rear dampers part number? I would love to see if they can installed and what modifications are necessary.
ayceman is offline   Reply With Quote
Old 08-09-2012, 12:58 PM   #79
jdenotter
jdenotter's Avatar
Drives: 2010 2SS/RS,M6,Black w/CGM Stripes
Can you order the gears yet?
3" RDP Motorsports aggressive cat-back exhaust w/ x-pipe, Vararam CAI, Hurst's short throw shifter, Gary's Customs painted bowties, Ofer's HID DRL/Fog Light wiring harness, Kelvin 8K HID DRL bulbs, ZL1 grille. Johnson's window tint film, LSR lowering springs, Metra dash kit with Pioneer In-Dash DVD head unit.
jdenotter is offline   Reply With Quote
Old 08-09-2012, 01:09 PM   #80
Higgs Boson
in the ZL1 Market
Call your dealer.
Old 08-09-2012, 07:56 PM   #81
LS2SLOW
LS2SLOW's Avatar
Drives: 5th Gen
I was told no by my dealer...they also said the part # 22813040 doesn't exist...he said he looked all over for it and couldn't find anything on it....I hope he's wrong
LS2SLOW is offline   Reply With Quote
Old 08-09-2012, 10:24 PM   #82
nak3dsnake
nak3dsnake's Avatar
Drives: 2010 Camaro IBM 2LT/RS M6
Its not that it doesn't exist, its not in his system yet. He probably needs the most recent update.
Looks: AAC P13W DRLs, Heritage Grille, RS Embroidered Headrests, GM Door Sill Plates, GM Premium Floor Mats, Body Color Engine Cover, LLT Mobile 1 Oil Cap, ZL1 Sport Pedals, 3M Clear Bra.
Performance: Vararam Ram Air Intake, Hurst Short Throw Shifter w/ Hurst Hard Drive Pistol Grip, IDEALG Clutch Master Cylinder, RX Catch can, GTO clutch fluid reservoir, Brembo Brakes, 1LE Track Pack, GMPP Exhaust Upgrade.
nak3dsnake is offline   Reply With Quote
Old 08-10-2012, 09:30 AM   #83
Mr_Draco
Mr_Draco's Avatar
Drives: 2SS/RS
The gears aren't for sale yet. Parts normally won't appear in the dealers parts catalog until GM releases them to the public to be sold.
Old 08-11-2012, 11:51 AM   #84
Russell James
Russell James's Avatar
Drives: Camaros
For anyone doing the 3.91's as an SS upgrade, what are you doing for an installation kit? A GM part number for an install kit, or aftermarket?
Thanks
