Old 08-12-2012, 08:30 AM   #85
RogerBzSS
RogerBzSS's Avatar
Drives: 11 IBM n White 2SS/RS M6
My decision will be baaed on when GM releases the gears for public purchase, then if that happens i will go GM gears but with JRE posi mod and caps
2nd i was at thinking about 1le axles
But i dont see them being different other than cv joint size or able to handle higher hp being the 1le having the same 400 /426 hp engines as the SS
So i would go with 1000hp axles and alum driveshaft
The zl1 sways are on my list but i am looking to go pedder suspension parts
Sent from my DROID X2 using Tapatalk 2
Black CIA -Powder Coated Red Air Scoop - Vmax Ported Throttle Body - Ceramic Coated Dynatek Headers - High Flow Cats out thru factory Cat Back - JRE rough idle cam package - Trunion Upgrade - Valve Springs - Hardened Push rods - 3 bolt timing gear - SLP Under drive pully- Washer bottle relo kit - Hurst Short Throw Shifter with updated pin bushing from C5 member NH-SS - IdealG's improved Master Cylinder - GTO Clutch reservoir - L99 Brake Reservoir - Stainless Braided clutch line - wrapped up with a JRE Tune My SS layed down 462 hp on JRE's Superflow Dyno
RogerBzSS is offline   Reply With Quote
Old 08-12-2012, 08:50 AM   #86
Cpanthers85
Drives: 2011 Camaro 2SS RS
You are going to still need an install kit. Either from GM or Richmond or somewhere. I don't think GM offers one though...yet. I know I've seen them on most vendors websites in the gears section.
Here's my $.02 on the axles...
They'd have to be stronger. The torque multiplier just went from 3.46(?, not sure about manual, I have an auto which is even taller) to 3.91. That's a half point shorter! Maybe someone can chime in that can actually do the math, but that torque/hp was just multiplied by a heckuva lot more than stock, and GM obviously knows the stock SS axles can't handle that much multiplied power. The other thing to keep in mind is they are designed to be raced at the road course track, not casually driven to the mall.
Now we wait for GM to release numbers or one of us fools to buy them and run em til they break lol
2011 2SS/RS L99
2017 Chevy SS
1979 Z28
Mods: Kooks Long Tube Headers, RotoFaB EForce CAI, American Thunder Catback Exhaust, PFADT Stage 1 Drag Kit + Front Sway Bar, GM Strut Tower Bar. ZL1 Fuel Pump. Nitto NT05R. RX Catch Can.LS9 Cam and Springs.LS3 Conversion.JRE Fuel Rail Upgrade.Edelbrock Eforce.60# Eforce Injectors.Extreme Racing Tune. 523/495
MY BUILD THREAD
Cpanthers85 is offline   Reply With Quote
Old 08-12-2012, 09:45 AM   #87
RogerBzSS
RogerBzSS's Avatar
Thats also a deciding factor at the time of gears being released, i guess i would go gm if also avail at order time
Agree road course specific and the need for improved cv's, i just dont see the shaft material being that much different
We will see..
The torq levels of the zl1 is what pushed the need for improved shafts all around
IMPO coming in at over 500 each
I would go 1000 hp for a bit more $$ over going zl1 shafts
Old 08-12-2012, 05:35 PM   #88
Ucantctchme
Ucantctchme's Avatar
Drives: 2010 ss. 1990 RS the faster one.
Originally Posted by Russell James View Post
For anyone doing the 3.91's as an SS upgrade, what are you doing for an installation kit? A GM part number for an install kit, or aftermarket?
Thanks
I would go with an aftermarket install kit. I am a gm tech and gm diff shim and spacers can be a pain to get if you're in a hurry. They usually come in a pack of 10 in .001" increments. If the aftermarket would sell just the pinion and carrier shims I'd be set. The bearings can be reused if they are not damaged when they are removed.
Ucantctchme is offline   Reply With Quote
Old 08-14-2012, 07:33 PM   #89
fastlane2010
fastlane2010's Avatar
Drives: 2010 camaro with fast lane stage 2
so did any one find out if you can run the zl1 axles with the stock ss diff are they the same splines and such for the diff and hubs
12.4 in 1/4 at 117mph first time
custom 2tone paint fastlane stage 2 hydroformed carbon fiber cowl and cluster kooks headers and 3" xpipe with pypes axle back
fastlane2010 is offline   Reply With Quote
Old 08-14-2012, 10:51 PM   #90
2SSRSinBama
Drives: 2010 2SS/RS Camaro CGM
actually guys, through GM Parts Direct, the parts are much cheaper:
LH Axle - 22806795 - $161.57
RH Axle - 22806796 - $161.57
ZL1 Hubs - 22924741 (x2) - $105.08
ZL1 Front Sway - 22842517 (comes with brackets and bushings) $80.47
ZL1 Rear Sway - 22786260 (comes with brackets and bushings) $93.84
the axles could be done for $533.33 + shipping
the axles and sway bars for $706 + shipping
2010 Camaro SS L99... has a few mods
2SSRSinBama is offline   Reply With Quote
Old 08-14-2012, 11:30 PM   #91
Higgs Boson
in the ZL1 Market
Drives: 2014 C7; 2015 2500HD
and how much is shipping from them? you might find it kills the good deal on the parts....
Higgs Boson is offline   Reply With Quote
Old 08-15-2012, 11:47 AM   #92
Ucantctchme
I got the ring and pinion. I won't be able to install for a while. This car is my daily driver. I also have to wait for it to slow down at work.
Old 08-15-2012, 11:50 AM   #93
Ucantctchme
Old 08-15-2012, 12:28 PM   #94
jlugo
Drives: 2014 1LE 'Summit White'
Smile
Originally Posted by Ucantctchme View Post
...SWEET!
jlugo is offline   Reply With Quote
Old 08-15-2012, 12:29 PM   #95
isrmnd
Drives: 2010 ss camaro
Who did you order the gears through?
isrmnd is offline   Reply With Quote
Old 08-15-2012, 01:25 PM   #96
Ucantctchme
I ordered them through a local dealer. Now I need to order an install kit and diff bushings. Grrrr.
Old 08-15-2012, 01:43 PM   #97
Higgs Boson
in the ZL1 Market
I called the dealer and the part number is not on the price tape yet. have your parts guy go onto GMs dealer parts website and they can find them.
also just found out my price for them is 210. hahaaaa! now to see if the dealer will install them. :-)
Old 08-15-2012, 01:47 PM   #98
jdenotter
jdenotter's Avatar
Drives: 2010 2SS/RS,M6,Black w/CGM Stripes
What all do you need to install the gears?
Sent from my DROID BIONIC using Tapatalk 2
3" RDP Motorsports aggressive cat-back exhaust w/ x-pipe, Vararam CAI, Hurst's short throw shifter, Gary's Customs painted bowties, Ofer's HID DRL/Fog Light wiring harness, Kelvin 8K HID DRL bulbs, ZL1 grille. Johnson's window tint film, LSR lowering springs, Metra dash kit with Pioneer In-Dash DVD head unit.
jdenotter is offline   Reply With Quote
