JDP Motorsports
Old 07-19-2012, 09:39 AM   #1
Cliffjumper
Cliffjumper's Avatar
Drives: 2013 2LT RS Black
Help me?
Delete thread please wrong area Hopefully I'm doing this right
Cliffjumper is offline   Reply With Quote
Old 07-19-2012, 09:53 AM   #2
Juiced1
Juiced1's Avatar
Drives: 2012 2SS CAMARO 45th
You have a lot of questions there. Adding power is easy but first you should now how an engine works. Check out this link.
http://www.howstuffworks.com/engine.htm
Read up on that. Once you have a good idea of how an engine works a lot of the other stuff makes more sense.
Juiced1 is offline   Reply With Quote
Old 07-19-2012, 10:27 AM   #3
Cliffjumper
Well I know how the engine works and can successfully explain it to I just I don't know what's in the engine to mod or differences or how you can replace a part with something that looks the exact same can boost performance ie camshaft
Old 07-19-2012, 10:28 AM   #4
Cliffjumper
I guess better said I know how it all works I just don't know what makes it all work
Old 07-19-2012, 10:54 AM   #5
BubbaSS
WHAT RED LIGHT?!
BubbaSS's Avatar
Drives: 2011 Black Camaro 2SS/RS M6
IMO, best N/A mods for power to this engine are headers, cam, gears and tune. Just focus on those 4 upgrades and you'll be good to go
2011 2SS/RS M6 BLACK - VARARAM NO TUNE INTAKE, MODDED AND PORTED TB, PORTED INTAKE MANIFOLD, VITESSE THROTTLE CONTROLLER, DOUG THORLEY LT'S, CATLESS, X-PIPE, 25" STAINLESS WORKS RETRO CHAMBERED MUFFLERS, CUSTOM 2.5" MANDREL BENT EXHAUST, RICHMOND 4.10 GEARS, CUSTOM CAM (231/242 @ 114LSA), MUSTANG DYNO TUNED BY TORQ, 20% CERAMIC TINTS, EIBACH PROKIT SPRINGS 1" DROP, HAWK PERFORMANCE CERAMIC BRAKES, NITTO INVO TIRES, HYDROCARBON TAIL LIGHT AND FOG LIGHT BEZELS BY EMBLEMPROS, METRA DASH KIT, JVC KW-AV71BT, PHOENIX GOLD iAMP GM1, PASSPORT QI45 - 450 RWHP 415 RWTQ
BubbaSS is offline   Reply With Quote
Old 07-19-2012, 11:01 AM   #6
hapisok
crazier than a coconut
hapisok's Avatar
Drives: 2010 2SS/RS LS3
AIR IN & AIR OUT
1. AIR
1. FUEL
1. SPARK
those are the 3 primary things you need to make power. its finding ways to increase AIR getting to the combustion chamber where it can mix with the fuel. more AIR = more FUEL = more power.
CAI allows more air to flow. a ported throttle body increases the velocity rate at which air enters the intake manifold. the manifold volume helps with the distribution of air to each cylinder and/or aid in throttle response. head work can increase the volume of the cylinder allowing room for more air and fuel mixture. the cam can increase or decrease the duration and lift of the valves also affecting air flow not only in but out also. aftermarket headers help remove burned gases out of the cylinder to create room for fresh air. there is also science behind headers that the velocity of exhaust gas moving out of they cylinder quicker helps to facilitate the compression of more air into the cylinder due to velocity. high flow cats remove a lot of the restriction in the exhaust system that hinder the scavaging of exhaust from the engine.
you may have the basics understanding of HOW it works. but you have to look at breaking everything down and how that effects everything else. if you want to know how a particular component increases or decreases HP...don't be afraid to google it or use wikipedia to get some basic theory. it'll start to come together the more you research and the more specific your questions will become. just gonna take some time.
try this link:
http://www.google.com/webhp?sourceid...w=1024&bih=653
modding can simply be looked at as improving the basic function of how an engine works. so if you understand that...the rest will make sense, sometimes. not sure what your background is, but if you buy a computer and 2yrs later its having a hard time keeping up with the 20 search bars you installed on your web browser and 5,000,000 widgets on your desktop, along with the little dancing stripper...you don't just buy a new computer, you upgrade your RAM. OR...you can clean it up a little bit, get rid of shyt that doesn't need to be there so it runs nice and smooth (kinda like a TUNE). OR BOTH!
hapisok is offline   Reply With Quote
Old 07-19-2012, 01:31 PM   #7
Avenging Orange
Avenging Orange's Avatar
Well, for one, there is a search feature here. When you see something you want info on, type it in the box..........or, Google it.
Most of us here have no issue answering your questions, no matter how dumb they may seem to you. We all had to learn this stuff (and are still learnng)...and we all asked questions and researched.
2010 Inferno Orange 2SS/RS M6 Black Leather,Sun Roof, OBX Headers, Haltech CAI , non synthetic fluids, Mike Norris tuned 419/413
2015 Ford Interceptor// 2007 Ford F150 XLT 4X4
Avenging Orange: 39 years of not buying into the Hype........and damn proud of it!!
Avenging Orange is online now   Reply With Quote
Old 07-19-2012, 02:01 PM   #8
Cliffjumper
I know this I tell people all the time the same thing. But like I already said I don't exactly know what I'm wanting to know much less what to search for. I always say everyone know everything
Old 07-19-2012, 02:03 PM   #9
Cliffjumper
Plus I would like advice tips and help from my fellow c5ers
Old 07-19-2012, 02:08 PM   #10
Cliffjumper
Originally Posted by hapisok View Post
AIR IN & AIR OUT
1. AIR
1. FUEL
1. SPARK
try this link:
Thanks this is what I'm looking for. Thank you. And my background is in computers I actually repair mobile devices I am technical I just never really got past changing an alternator or a water pump that's as far as I've gone into the motor
Old 07-19-2012, 02:21 PM   #11
TheNewCzar
Drives: 2011 SS Rally Yellow Vert, 2000 WS6
Better air flow is a key. Plus the temp of the air coming into the engine, the colder the better (NOS is really really cold).
Cold Air Intake, CAI scoop, washer bottle relocate, and ported Throttle Body helps get more (and cooler) air into the engine
Headers, hiflow cats, and better cat back or axle back exhaust helps get air out.
A good tune ties it all together and tweaks your cars computer to run the engine and transmission more efficiently for power.
And stickers, don't forget the stickers that come with your new stuff.
Stickers are cool.
So are fezs and bowties.
TheNewCzar is offline   Reply With Quote
Old 07-19-2012, 02:30 PM   #12
NDC123
The Machinist
Drives: 2012 2SS/RS LS3 IBM silver rally
Originally Posted by Joshehring View Post
I really want to learn and I feel like I'm going to get crap for not know but I want to understand a lot of these threads about engines. Cause I want to boost my Hp but I feel like I'm reading Greek What are these different engines that are stock in the Camaro. And then what are well known engines and what makes then so unique. What is it when y'all re talking about rear wheel Hp or something like that What are easy thing to add to my engine to get boost in Hp and wth are all the other things other than Hp I have a basic knowledge of what you can see when you look at a car and can completely maintain one my self fluids brakes tire rotations. But I want to learn. So gear head lay on the knowledge. Cause I can't look it up cause I don't know what to look up
Thanks and sorry for the runons
Remember there are no stupid questions...just stupid people.
American Racing Headers w/high-flow cats and x-pipe, Flowmaster American Thunder Axle-back mufflers, VMAX ported throttle body, CAI intake, ADM race scoop, RX Catch Can, PEDDERS Street Z package-ZL1 sways-XA Coilovers, PFADT trailing arms-toe rods, RPM 3:91 gears, RPM Stage V Trans, ADM diff bushings, tune by ADM, and still bustin' knuckles!
NDC123 is offline   Reply With Quote
Old 07-19-2012, 03:18 PM   #13
Cliffjumper
What's a ported throttle body
Old 07-19-2012, 03:19 PM   #14
Cliffjumper
What about turbos. Are they worth that money. And I was wanting to get a k&n air thing. Dont know what it's called
engine
