Old 07-19-2012, 03:27 PM   #15
NDC123
The Machinist
Drives: 2012 2SS/RS LS3 IBM silver rally
Originally Posted by Joshehring View Post
What's a ported throttle body
Ported throttle body takes the step out of the stock TB and smooths out the airflow making the airflow faster into the intake manifold.
American Racing Headers w/high-flow cats and x-pipe, Flowmaster American Thunder Axle-back mufflers, VMAX ported throttle body, CAI intake, ADM race scoop, RX Catch Can, PEDDERS Street Z package-ZL1 sways-XA Coilovers, PFADT trailing arms-toe rods, RPM 3:91 gears, RPM Stage V Trans, ADM diff bushings, tune by ADM, and still bustin' knuckles!
NDC123 is offline   Reply With Quote
Old 07-19-2012, 03:28 PM   #16
Cliffjumper
Cliffjumper's Avatar
Drives: 2013 2LT RS Black
Where is that located
Cliffjumper is offline   Reply With Quote
Old 07-19-2012, 03:28 PM   #17
Cliffjumper
I'm guess before the intake manifold lol
Old 07-19-2012, 03:29 PM   #18
Cliffjumper
What's a good set of exhaust that will make my Camaro noticeable but not overbearing and isn't to expensive. Sorry I'm going to be asking alot
Old 07-19-2012, 03:33 PM   #19
Cliffjumper
Ok tb is what the gas pedal is attached to
Old 07-19-2012, 03:34 PM   #20
NDC123
The Machinist
What about turbos. Are they worth that money. And I was wanting to get a k&n air thing. Dont know what it's called
Turbochargers compress air and fuel into the cylinder making more powerful explosions when ignited.
K&N is a brand of CAI (cold air intake). Cooler air into your engine means more expansion upon igniting. Hotter air doesn't have as much expansion when ignited as cold air hence more power. This is because everything as it heats it expands. So, the engine compartment air has already been expanded further than cold air by the temperature of the engine. High flow air systems like CAIs allow the air to flow in fast enough it doesn't have time for the engine compartment to heat it up. HTH.
Old 07-19-2012, 04:00 PM   #21
hapisok
crazier than a coconut
hapisok's Avatar
Drives: 2010 2SS/RS LS3
not to be a dick...but you asked...instead of just bombarding questions about everything, take a second or maybe a few minutes and search. you've got questions about stuff...so search those questions before you hit "post". i promise you, you will amaze yourself at what you can find. its time consuming but you will learn more that way. if you want to go FI...then start your research around FI. it appears that you want the most HP you can get. but just a reminder, your a V6 asking in a V8 section. so the setups, builds, and tunes are slightly different. instead of just asking an open question like "are turbos worth the money?" find out what a turbo is first...only you can decide if its worth YOUR money. you've got a bit more research to do just for your own knowledge base before you go throwing parts at your car. if you just throw mod after mod at it, next you'll be on here flaming us for your motor grenading. nothing wrong with being eager to learn, take your time, and invest some interest in it instead of looking for somebody to hand you the answers and build your car for you. your gonna have 50 different answers to 1 question and 1,000,001 ways to build your car up. there is an exhaust sticky in the V6 section which should give you a good idea of the sound your looking for...start there.
hapisok is offline   Reply With Quote
Old 07-19-2012, 04:01 PM   #22
Cliffjumper
I started doing that after I posted it all sorry I click in a little late lol
Old 07-19-2012, 04:05 PM   #23
Cliffjumper
I'm just overwelmed with the stuff I've learned in the past week on here and I'm getting to excited about it all
Old 07-19-2012, 04:06 PM   #24
NDC123
The Machinist
I will answer any questions I can and i dont mind doing it. I won't build your car for you . All I can provide you is info the decision is always yours.
Old 07-19-2012, 04:08 PM   #25
Cliffjumper
I really appreciate it I do need to "study up" before I ask a lot Now that i have some knowledge cause I will eventually wear my touch screen out with all the questions I have lol
Old 07-19-2012, 04:10 PM   #26
NDC123
The Machinist
This forum is for finding out information and using each others knowledge as a resource so you don't have to search four million websites to answer a question someone already knows and can answer in two seconds. Anyways ask all the questions you want. Sometimes you can get a better explanation from someone with experience as opposed to reading direct information.
Old 07-19-2012, 04:13 PM   #27
Cliffjumper
I am soon to be going to uti in Houston so when that's over I'll be able to talk with the big boys on modding and engines lol
Old 07-19-2012, 04:15 PM   #28
Cliffjumper
Well I guess my problem is is that I know the parts just not their names or "street" names so I get told a part and google an image of it then know what it is
engine
