BeckyD@RodgersChevrolet
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Members Classifieds - Parts for sale or wanted > Transmission / Driveline
Old 07-19-2012, 10:09 PM   #1
Posidon42
Drives: 08 G8 GT
Tick Performance Lvl 2 TR6060
Sold to a local buyer. Thanks all.
I bought a TR6060 from a member here to swap into my G8, but it turns out there are some major differences in the bellhousing / input shaft and I can't fit it into my car. The trans is a Tick Performance LvL 2 built trans with the 9310 output shaft and support bearing, carbon synchro blockers, bronze fork pads, etc.. Details are here: (http://www.tickperformance.com/tick-...010-camaro-ss/)
From the previous owner, it had a total of 650 miles on the whole thing but he was upgrading to a 4L60 for racing. For now, the only thing I am selling is the transmission as I am going to buy a GXP transmission and swap that into my car. It is still unused and in the shipping container as we couldn't compare the parts until the transmission arrived.
Asking $2300 plus shipping. Hope this goes to a good home that can use it!
Posidon42 is offline   Reply With Quote
Old 07-21-2012, 12:17 AM   #2
Posidon42
Drives: 08 G8 GT
Bump.
Old 07-21-2012, 10:42 AM   #3
markssylver
markssylver's Avatar
Drives: 95 bbb impala ss
You can't change the bell housing and mid plate to fit your car also I think you would have to change the bearing at the flywheel to the newer style to accept the input shaft
10.56@134mph
ADM BUILT AND TUNED CGM 2SS RS
ADM/LPE 417 with ported heads/inconel vavles gt11 cam
ADM ported maggie with 14 rib rear 10 rib front pulleys
ADM fuel system and race air intake
ADM/LPE ZR1 clutch /pedalreturn spring
ADM billet aluminum valve covers /RPM LEVEL 6 TR6060
LPE HD 241mm diff with 3:45 gears HD axles and d/s
ADM widened wheels with 315nitto nt05s Bogart 17 dragwheels CTS-V front 6 piston brakes
Pedders HD subframe/differential bushings alignment kit 27/32mm sways Supercar coilovers
683RWHP/650RWTQ
markssylver is offline   Reply With Quote
Old 07-21-2012, 07:50 PM   #4
Posidon42
Drives: 08 G8 GT
Yes. The problem is that the front cover for the GXP trans isn't available from GM. They said the only way to get it was to get another trans. Even checked with the Australian parts guys and same answer. The bearing would have been easy
Old 07-22-2012, 12:18 PM   #5
1stGM
1stGM's Avatar
Drives: IOM 2SS/RS M6
This is my old trans.. If somebody is looking for an almost indestructible trans that shifts super smooth
this is it... No second gear grind and no getting locked oit of second @ 6500 rpm!!!
2010 2SS..LS3..Procharger..4l80e..DSS 9"
1stGM is offline   Reply With Quote
Old 07-22-2012, 11:16 PM   #6
Posidon42
Drives: 08 G8 GT
Thanks for chiming in. I wasn't going to name drop without your permission All, from 1stGM, the trans had about 8400 miles on it total and about 1000 miles on the trans after the Tick upgrade. You won't be disappointed!
Old 07-23-2012, 09:01 AM   #7
flht99b
flht99b's Avatar
Drives: 2010 Camaro 2SS/RS RJT
Any idea of shipping costs to 37934 ??
Ed M.
RJT 2SS/RS, AAM 3.70's, MTI Sway Bars, Shifter & SS brake lines, ZLI calipers & rotors, BMR Trailing & Toe Arms, full rear cradle & diff bushings, Pedders XA's, Camber/Toe eccentrics, Radius arm inserts, ZL1 Brembo Brake pads, GTO clutch reservoir, LS9 cam, Comp Cam valve springs, Melling 10296 oil pump, CR 5 timing chain, LS2 damper, CAI Cold Air Induction, ARH LT headers w/HF cats, GMPP touring axle back, Elite Engineering Catch Can, Forgeline 20x9.5 & 20x11 DS3 wheels w/Vredestein 275/40/20 & 315/35/20 tires, '11 Convertible spoiler, Lloyd "SS" Floor Mats, GM Camaro Trunk Mat
flht99b is offline   Reply With Quote
Old 07-23-2012, 05:33 PM   #8
Posidon42
Drives: 08 G8 GT
Residential or business delivery?
Old 07-23-2012, 08:27 PM   #9
flht99b
flht99b's Avatar
Let's use a business address at zip 37932.
Ed M.
Old 07-23-2012, 08:42 PM   #10
yotaman96
yotaman96's Avatar
Drives: 2010 Camaro SS, 2000 Trans Am WS6
If only I had the money.
2010 IOM Camaro 2SS/RS manual trans (Sold)
Magnacharged 2000 Trans Am WS6 manual trans
2015 Ram Crew Cab Cummins
yotaman96 is offline   Reply With Quote
Old 07-24-2012, 12:17 AM   #11
Posidon42
Drives: 08 G8 GT
Ed M.
It was about 160 pounds shipped when it came to me. Probably around $200 if using a business address.
Old 07-24-2012, 10:19 PM   #12
Posidon42
Drives: 08 G8 GT
In the spirit of full disclosure, my parts supplier and I are making one more attempt to get the right parts to swap this transmission into my car. IF that doesn't work, then I am putting all of the swap parts up for sale. The only thing I don't have is the driveshaft. I have the pedals, OEM and ZL1 clutch/slaves, GTO reservoir, OEM and MGW shifters, shift knobs, etc.
I am 75% certain that adapting the GXP transmission cover to this transmission is not going to work, but we wanted to get the part in our hands and look at it before making the decision to start over.
Old 08-04-2012, 03:29 AM   #13
Third-Gen
Olson Kustom Works
Drives: 91 Camaro, LS3, TVS2300, TR6060
since I know the trans will bolt up to the back of the engine in your G8, if you use a Camaro clutch, slave cylinder, and pilot bearing, and modify the shift linkage, why wouldnt this swap work?
Third-Gen is offline   Reply With Quote
Old 08-04-2012, 08:41 AM   #14
Posidon42
Drives: 08 G8 GT
That could have been an option but I would have needed a custom driveshaft. I am going to measure that combination before I try to install the g8 trans cover on the camaro trans.
Oh and until further notice, the trans is no longer for sale. I am going to try a couple more options before throwing in the towel.
