| Wheels and Tires Talk Sponsored by The Tire Rack Discuss issues related to wheels and tires |
Thread Tools |
![]() Drives: 2011 IOM 2SS/RS Join Date: Apr 2012
Matching high performance all-season in 275/40/20 & 315/35/20?
Howdy!
So who makes a high performance all-season tire in both 275/40/20 & 315/35/20 with good tread life? I want a matching set of tires, it must be all-season, must have good tread life, and must not cost $400 a tire! I know that Nitto has the Motivo that lives up to that, but who else?Thanks a bunch!
2011 IOM SS/RS L99
2011 Kawasaki Concours 14 |
No Longer V6^ but V8 :D
Drives: Chevrolet Camaro Join Date: Jan 2012
Continental DWS is another
Thank you!
They are on par with the Nittos on price and looks like they have an AA traction rating while the Motivos only have an A ratings. I guess I have never considered Continental a good tire, does anyone have an experiance with them? Anyone else have other suggestions?
2011 IOM SS/RS L99
Anyone else have any opinions or experience with all-season performance tires?
2011 IOM SS/RS L99
![]() ![]() Drives: 2012 2LT 45th convertible Join Date: Jul 2010
all season tires are a bit of a compromise with performance summer only tires,
performance tires are made of a softer compound for grip and traction, they will wear quicker, especially if you use them at a track. All seasons are a harder compound generally speaking, you will sacrifice some grip and traction but gain year round use and a longer tire life. a bit more costly I know but consider having some wheels / tires just for use in winter. with the salt and snow melt they use in your area during winter you will save the appearance on your polished/painted wheels.
Top Ten Reasons I Procrastinate
1. |
#6 |
![]() Drives: 2010 Camaro 2SS Join Date: Jun 2012
I'm also looking at buying some inexpensive all season tires. Tire Kingdom down here in Miami has the Motiva 245/45's for $236 and the 275/40's for $249. Balance/mounted for $20 and Alignment is $80. Might just go with them...
#7 |
Ocikat, thanks for the post bud. I am aware that a all-season is a compromise tire, but I am OK with that. I will not take my car to the track so no need for super stickies. I have no interest in changing tires twice a year and ultra high performance tires in the 275 and 315 size range are in the $400-600 price range. Not even close to being worth the price on a DD. the high and ultra high performance all-seasons are down in the more "reasonable" $200-250 price range.
2011 IOM SS/RS L99
#8 | |
http://www.roadandtrack.com/tests/tires/nitto-motivo/
2011 IOM SS/RS L99
#9 |
i have motivo's, slightly less grip then stock but for the price and tread life it is a good trade off
#10 |
Im here at work looking at all the options for you,i work for "discount tire", and for the price those two would be the best options,
#11 |
Thanks Monster. I think the Motivos are what i will be going with. I was just wondering if there are some other and/or better options.
Thanks for looking it up!
2011 IOM SS/RS L99
#12 |
Veredestien tires have been getting some very good reviews also, they are imported from europe and are pretty reasonably priced, might be worth checking on. this is their summer performace tire but they do have all season tires too.
1. |
#13 |
Thanks for the heads-up!
2011 IOM SS/RS L99
#14 |
![]() Drives: 2010 2SS/RS M6 Black on Black Join Date: Jan 2010
I've got the Continental DWS tires in 275 and 315 X 20. Have a little over 20,000 miles on them and can still see the DWS in the treads. In theory, the S should wear away first, then the W, then the D. Less dry grip than the Zeroes, but better wet performance. Quiet, and wear evenly and well. I run these tires up through the first major snowfall, and then switch to my stock wheels with Pirelli Scorpion Snow & Ice. The DWS were surprisingly good in 2 inches of snow, and that's saying something with the 315 width.
Mods: Pedders Xa's, bushings, braided brake lines, Solution B sway bars, Hawk ceramic pads, Spohn trailing arms, Kooks 1 7/8 LT's, HF cats, Magnaflow 3" cat-back, MBRP rec tips, Cold Air Inductions black CAI, MGW short-throw shifter w/retro shift ball, Showstopper Engine Bling, Forgeline MD3P's 9.5 & 11", Conti DWS 275's & 315's. AAC plasma DRL's.
Proud previous owner of: 1968 327 Camaro, 1972 Camaro SS 350, 1978 Z28, 1979 Z28. 2010 SS is My 5th Camaro |
#15 |
Thanks bud, good info!
2011 IOM SS/RS L99
#16 |
![]() Drives: Black on black ss/rs 6 speed Join Date: May 2010
Just make sure you get a speed rated tire unless you only drive the speed limit!
#17 |
Of course. All high performance all season tires are at least W rated if not Y rated. Really who needs that anyway, how often are you driving over 168MPH?
The Motivos are Y rated with A+ grip and 60,000 tread life. Good tire!
2011 IOM SS/RS L99
#18 |
![]() Drives: 2010 Camaro 2SS/RS 6M Black-s/s Join Date: Oct 2010
The General G-MAX AS-03 ultra hi performance all season tires are inexpensive have a good ride, have a 480 tread life, a single "A" traction rating (opposed to the great traction of double "AA" summer tire). My only complaint with them is the thin sidewalls. They even get good traction in lite snow! I use them in the winter since my beater car died.
SLP performance- long tube headers, hi flow cats w/full SLP 3'' PowerFlo exhaust incl/X-pipe, 160 degree stat, SLP Blackwing CAI. Dyno tuned by ECS-407/409RWHP&TQ. BMR fabrication- trailing arms w/poly knuckle bushings, toe links, cradle bushings and differential bushings. Hurst short throw shifter. Best 1/4 mile so far- 12:70ET @ 112.24 MPH w/ 2.06 60'. |
#19 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 SS/RS Join Date: Jun 2011
| Thread Tools | |
