Old 05-22-2009, 12:14 PM   #1
Scott@Bjorn3D
Scott@Bjorn3D's Avatar
First Oil Change Done.
Well 810 miles so I took the plunge and changed the oil. $87.00 smakers. I did notice it lowered the valve chatter I did have.
Scott@Bjorn3D is offline   Reply With Quote
Old 05-22-2009, 12:25 PM   #2
speedster
SST...
speedster's Avatar
Drives: SST Camaro 2010
Time to hammer it Scott...
Next item to change: rear tires. It's amazing how fast they go bald.
Old 05-22-2009, 09:22 PM   #3
Zeus95
Zeus95's Avatar
Drives: IOM 2010 - 2SS/RS
Going tomorrow to get mine done tomorrow at 9am. Got 900 miles on it. Good chance traction control might get turned off tomorrow !! Giddy UP !!
2010 2SS/RS IOM Upgrades: Fastlane CAI / SLP II Loudmouth axle back / V Max Ported TB / Kook's Step Long Tube Headers / High flow cats / Straightline Tune / BMR front & rear sway bars / Hotchkin End Links / Hurst Short Throw. LG ZR28 Wheels 1 of 2 sets made. Pfadt trailing arms / Diff Bushings & Sub Frame bushings / 1LE Axle & Hubs.
Zeus95 is offline   Reply With Quote
Old 05-24-2009, 12:25 AM   #4
etrigan
etrigan's Avatar
Drives: 2010 2SS/RS Black Camaro
What is the thinking in getting an oil change so early?
"No matter where you go, there you are."
-B.B.
VIN #2G1FT1EW6A9106795
1100, Preliminary order accepted:10/13/08
6000, Del. to me:5/20/09
etrigan is offline   Reply With Quote
Old 05-24-2009, 12:34 AM   #5
GMtothecore
"That Guy"
GMtothecore's Avatar
Drives: Camaro SS...........what else?
Location: OOOOOOOklahoma where the wind comes sweepin' down the plains.
to get the tiny metal shavings and fragments that's in your crank, engine, and filter out....
GMtothecore is offline   Reply With Quote
Old 05-24-2009, 12:44 AM   #6
Legend
Hello!
Legend's Avatar
Drives: 2008 JSB Z06!
Changed mine on Wednesday....had a little over 800 miles on there. I've drove this thing with traction control off...it's everything you could imagine!
Legend is offline   Reply With Quote
Old 05-24-2009, 11:21 AM   #7
earn88hardt
earn88hardt's Avatar
Drives: 2010 IOM Camaro SS
thats wht the filter is for these motors are pre run no reaon to change oil until the oil life is up your just throwimg money away
earn88hardt is offline   Reply With Quote
Old 05-24-2009, 11:24 AM   #8
BLUEMARO
A Classical Greek
BLUEMARO's Avatar
Drives: DTS, Bonneville and an SS !
What do you think the filter does?
BLUEMARO is offline   Reply With Quote
Old 05-24-2009, 12:10 PM   #9
ShnOmac
ShnOmac's Avatar
ShnOmac is offline   Reply With Quote
Old 05-24-2009, 12:45 PM   #10
Splitter
Drives: '14 RRM 1LT/RS A6
Originally Posted by shnomac77 View Post
Splitter is offline   Reply With Quote
Old 06-03-2009, 12:40 AM   #11
2010 SS RS
2010 SS RS's Avatar
Drives: 2010 2SS/RS IBM Black Polished
I changed mine up at 350 miles and screened the oil. It was pretty clean but burned off a 1/2 quart. Mobil 1 is great but you will need to add oil quickly after a change due to the amount of detergents in it. I am going to do two more changes with mobile 1 then going Royal Purple baby! How are you doing Scott? Is it all that you expected?
418 Stroker, 621RWHP 648 lbs TORQUE Built by Laramie GM Auto Center Tuned by Nick at Mac Autosport. EForce SC, 2 3/4pulley,LPE dual fuel pump, JRE Twin fuel rail upgrade, posi clutch kit, RX oilcatch can and breather, Callies Compstar crankshaft and rods, Racing bearings, CP -13.8 race pistons, steel rings, Comp Cams X6 blower cam, Springs, HD timing chain and tensioner, Doug Thorley Tri Y LT headers, 89.7lb injectors, RPM rollbar, DSS1400 shafts, Simpson 5 pt harness, BMR Toe rods and trailing arms, led lights, RPM input and output shafts
2010 SS RS is offline   Reply With Quote
Old 06-03-2009, 12:44 AM   #12
2010 SS RS
2010 SS RS's Avatar
I cant just leave that with a face palm.....You are just kidding us all,,,,right?
Old 06-03-2009, 06:42 AM   #13
Scott@Bjorn3D
She is plenty quick, kind of bumming that it will not break the tires loose with out power braking it. Talked to GM about it and the designed the car to grab and go not sit there and spin. They said if I want to spine them with the auto go buy some cheaper tires.
Old 06-03-2009, 07:39 AM   #14
Ranger 75
Ranger 75's Avatar
Drives: 2010 Camaro 2SS IBM
Changed my oil at 500 miles. Yes, they are supposed to be prerun at the factory, but you never know. I will change mine again at 1500 miles then go to a regular schedule. Sticking with Mobile 1 as I use it in all my vehicle even my 1998 Harley Evo and my 2001 Toyota truck . My Harley has 132,000 miles on it and the Toyota Truck has 230,000 miles on it, so Mobile 1 must be doing something right!
Ranger 75 is offline   Reply With Quote
Oil change MustangKillr 4th Generation Camaros 52 06-09-2009 06:21 PM
How about a barrel of oil for around $16? Blownhotrodder General Automotive + Other Cars Discussion 19 03-06-2009 08:25 PM
The 3,000 Mile Oil Change Myth KILLER74Z28 General Automotive + Other Cars Discussion 35 07-20-2008 10:02 PM
