autoguy
Camaro DIY & HOW-TO instructions & discussions All DIY projects & discussions
Old 07-20-2012, 12:52 PM   #1
iCamaro
iCamaro's Avatar
Drives: 2012 LT RS Camaro
How do you remove center air vent bezel on a 2012
I have found a thread on how to remove every bezel part on the interior, but have not seen how to remove the air vent bezel on a 2012 camaro. I did read that the small bezel on the 2010/11 can not be remove unless you take the dash out? Is this true for the 12 too and either way anyone have photos/video/write up on how to take it out?
iCamaro is offline   Reply With Quote
Old 07-22-2012, 04:57 PM   #2
2012_1LT/RS
Drives: 2012 Camaro 1LT/RS
Its very easy to do First pull the long strip on the dash off. Then remove the 6 7mm bolts underneath it. Next lift the Shifter surround (piece with the tray/gauges) out of the way. Next, Remove the 2 bolts for the radio. Next remove the upper 2 7mm bolts behind radio. Then just pop off the leather trim section and the unbolt AC vent from that. And finally unclip the trim from vents. and reinstall in reverse order and you get.....this painted mine Matte Black
2012_1LT/RS is offline   Reply With Quote
Old 07-22-2012, 11:22 PM   #3
iCamaro
iCamaro's Avatar
Thank you!
Old 07-22-2012, 11:37 PM   #4
2012_1LT/RS
Not a problem let me know how it goes
Old 08-09-2012, 10:02 AM   #5
iCamaro
iCamaro's Avatar
Update
Here are a few photos of how it turned out.
Old 08-09-2012, 06:49 PM   #6
ragtop11
ragtop11's Avatar
Drives: 2012 SS/RS
very nice, looks great
2012 Camaro SS/RS Black and Black.
added Solo Performance "J" pipes
ragtop11 is offline   Reply With Quote
Old 08-09-2012, 11:52 PM   #7
iCamaro
iCamaro's Avatar
Thanks, it was a lot of work. I have never done this before but my two best friends in the project where the plastic trim tools to take it apart and camaro5 for the DIY threads. The alpine set up was so easy too. All but the part where I had to sit in the car for 8 minutes paying angry birds waiting for the computer to go into sleep mode. That when I lost the new car smell!
Old 08-12-2012, 02:13 AM   #8
v6
v6's Avatar
Drives: 2012 45th 2LT RS
that looks awesome what did you use to paint this white?
v6 is offline   Reply With Quote
Old 08-12-2012, 12:28 PM   #9
LandonB
LandonB's Avatar
Drives: 2011 Camaro LS M6
Anyone know if this will work on the 2011's too?
LandonB is offline   Reply With Quote
Old 08-13-2012, 01:32 PM   #10
iCamaro
iCamaro's Avatar
I have heard to get to the 201-11 center air vent you have to remove the whole dash. Some have just taped off the vent and painted it in the car so they don't has to remove he whole dash.
Old 08-13-2012, 02:31 PM   #11
The Stig
Fireproof Moderator
The Stig's Avatar
Drives: a PBM camaro
Correct. Because the 2010 and 2011's air vent is built into the dash, the only way to gain access to it is to remove the entire dash.
Stieger's BLACK Build Thread thanks for the sig Russ
Old 08-15-2012, 04:57 PM   #12
StOrM TrOOpEr
TK-421
StOrM TrOOpEr's Avatar
Drives: 2012 2SS/RS Summit White
subscribed !!.. any step by step pics? how do u remove the 2 side circle air vents? and what white did u use? clear? im hesitant to do white/clear using cans coz it always yellows out..maybe i will just do it black
EDIT: nevermind i found a post by stieger
Thanks. No I unfortunately didn't snap photos of the process. But basically you can pop off the side of the dash. Like you were going to acess the fuse box. From their it is three 7mm bolts that hold the vent in place. When you're there you'll see what I mean. Once you undo those screws you can just pull the plastic vent and the trim out.
For the center trim I kind of cheated. I just taped off the dash and hand painted it. Used a really fine artists brush. You can't even tell unless you're right there looking at it.
[LEFT]2012 CAMARO 2SS/RS A6 L99, TPW 7-18-2011 FIRST PRODUCTION WEEK 2012 MODEL #349
"LIKE" me on my FACEBOOK page http://www.facebook.com/stormtroopercamaro2ssrs
MY BUILD THREAD: http://www.camaro5.com/forums/showthread.php?t=209482
StOrM TrOOpEr is offline   Reply With Quote
Old 08-15-2012, 05:11 PM   #13
zkdreads
zkdreads's Avatar
Drives: 2010 Camaro LS V6
damn it. i sure did just go to my car and tried this lol
C-LO or Sonic
"Without Struggle there is no progress"
I am your best nightmare!
zkdreads is offline   Reply With Quote
Old 08-15-2012, 05:20 PM   #14
The Stig
Fireproof Moderator
The Stig's Avatar
I used Duplicolor rattle can: gloss black + 2 coats of clear
Old 08-15-2012, 05:25 PM   #15
StOrM TrOOpEr
TK-421
im not worried about black and clear.. its the white.. coz it yellows over time
Old 08-15-2012, 06:51 PM   #16
BNB
Rollin' The Lunchbox
Drives: 2012 Camaro Ashen Grey
What radio and shifter is that?!
BNB is offline   Reply With Quote
Old 08-15-2012, 11:20 PM   #17
StOrM TrOOpEr
TK-421
I DID IT !!!! removed the a/c vent bezels .. it wasnt that bad at all..
Old 08-16-2012, 08:48 AM   #18
iCamaro
iCamaro's Avatar
It is the Alpine system W910 with the Alpine Perfect Fit dash kit too. Everything is touch screen. Alpine had a cord included for my iPhone that not only charges my phone, but gives me full access to it too. I purchased the items from Creative Audio in Springfield, MO. They shipped it next day and have the best customer service ever! I had a problem with the touch screen on the dash kit. They sent me a new one with no questions asked. I installed everything myself.
The only two problems I have seen with this set up are - I can not use my AUX cord in the arm rest of the car and I can not lock or unlock my car with the key from a great distance anymore. Alpine has a great set up for my iphone so I dont miss the AUX at all! I have no idea what the deal is with the key less entry
The shifter is a DefenderWorx Shift Knob. You can get on almost any camaro accessories web site for around 200 dollars.
Old 08-17-2012, 05:52 PM   #19
StOrM TrOOpEr
TK-421
so i made a DIY .. thanx Chris81106 and steiger..
http://www.camaro5.com/forums/showth...47#post5458547
