Flowmaster Exhaust
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Garage / Tools Discussions
Old 07-22-2012, 05:37 AM   #1
Brutal SS
Brutal SS's Avatar
Drives: 2015 Camaro 2SS 1LE
Advice on Torque Wrenches
A quick question from a mechanical novice: What torque wrench do you recommend for the sole purpose of returning the lug nuts back to GM spec. (140 lb/ft)?
I want to remove my wheels in order to paint my brake calipers and rusty rotor hats, and I really don't anticipate using this tool for any other purpose, so I don't mind going for the cheap made in Taiwan model. Suggestions? Thanks!
Brutal SS is offline   Reply With Quote
Old 07-22-2012, 09:16 AM   #2
Synner
Drives: not stock
Just go to harbor freight if you want a disposable torque wrench ($20). Although I got a sears one which is much nicer for around $100. If you do any suspension or engine work a good torque wrench is necessary.
Synner is online now   Reply With Quote
Old 07-22-2012, 10:31 AM   #3
geaux_tigerss
geaux_tigerss's Avatar
Drives: 2014 GMC Sierra Denali
Found one at o'reilly's for $30 or so. It's pretty good. Just needed a 22mm socket.
2011 2SS/RS M6 CGM Rotofab CAI, Kooks 1 7/8, Corsa (LS3)
geaux_tigerss is offline   Reply With Quote
Old 07-22-2012, 11:26 AM   #4
KAYSTEW
USAF
KAYSTEW's Avatar
Drives: Silver 2016 2SS
As a calibration technician is the Air Force, torque wrenches are items we calibrate on a regular. I would tell you to look for any Snap-on brand wrench preferably a ratchet head type. They tend to hold there calibration longer meaning if by a cheap off brand type it may read what u want it to initially but after a while it may read way off even when you have it set to the proper settings. Just my 2 cents.
KAYSTEW is offline   Reply With Quote
Old 07-22-2012, 11:43 AM   #5
Black-Out
Black-Out's Avatar
Drives: himself insane
Honestly... if you can get used to using one... an "old school" beam type is the best bet!
I worked for a tool importer for 10 years. We sold 'em all. Serviced 'em all (had a certified torque wrench test bed, etc).
I've personally had 'click type' ones that were out of whack after only a few years and were too far gone to to reset.
I've also got a 1/4 drive in/lb beam scale from the 1940's that is STILL DEAD ON!
Same goes for all my 3/8 & 1/2 drive beam scale ones.
As long as they start at "0", and the arm doesn't drag, they just stay right.
Other problem with click types if they slip out of calibration (assuming you don't have a tester!) is that they'll still go click. You'll think it's tight. But you have no idea if you just really tightened it to 120, 140 or 160 lbs!
{sold} -- 2011 Camaro 2SS/RS - Black on Black. Kooks catted LT's, CAI, Accell 9070c ceramic wires, Barton shifter, custom catback w/Dynomax VT's, quad tips, Pfadt springs/sway bars/trailing arms, Diablosport tuner {Lew tune}, 3.91 gear's, Energy cradle bushings.
Black-Out is offline   Reply With Quote
Old 07-22-2012, 10:03 PM   #6
JasonK
JasonK's Avatar
Drives: 2010 Camaro
You know I've got a Craftsman and a HF one. I'll torque something tomorrow and post. See how accurate the HF is.
2015 Sentra / 2015 Murano / 2012 HD Ultra Classic / 1995 Z71 / 1966 Mustang
JasonK is offline   Reply With Quote
Old 07-23-2012, 02:49 PM   #7
Nvincent4708
1st State Camaro
Nvincent4708's Avatar
Drives: 2014 1SS M6
I have a Summit Racing brand one.
I got the calibration checked..and was less than 1% off.
Nvincent4708 is offline   Reply With Quote
Old 08-03-2012, 12:36 AM   #8
Brutal SS
Brutal SS's Avatar
What were your findings?
Old 08-06-2012, 01:40 PM   #9
KRich2587
KRich2587's Avatar
Drives: 2014 Summit White 1LE
Being a professional technician i would say do not skimp on a torque wrench especialy if you are using it for your wheels. ive seen wheels come off from improper tightening not fun. I would look for any snap on torque wrench i have the electric and click types. had mine checked recently after three years of use and both were dead on... just my opinion
KRich2587 is offline   Reply With Quote
Old 08-06-2012, 11:03 PM   #10
376LS3
Eh, that'll happen
376LS3's Avatar
Drives: 2010 2SS
I have the electronic Snap On torque wrench and I love it! Who would have thought it would excite you to own a torque wrench, but I went through and torqued everything! It also has a cool feature to do reverse torque, so when you remove something, it will tell you the torque it took to break the bolt free. I bought it specifically to remove/install the crank pulley bolt.
2010 Camaro SS LS3 - No Modz
376LS3 is offline   Reply With Quote
Old 08-07-2012, 01:06 AM   #11
Nessal
Drives: Exige, Miata, Ghia
Dude just order the brownline one that is posted on this forum. I got one of those and also a Husky torque wrench that I have used for 10+ years.
Nessal is offline   Reply With Quote
Old 08-08-2012, 09:53 AM   #12
ZED SLED
ZED SLED's Avatar
Drives: 17 M_BK ZL1, 16 S-rado, 15 Terrain
I have a craftsman click type that seems to work well. One thing I've been told that I adhere to is to set it to 0 when not in use. Leaving it sit with tension on it can do it no good.
Smoked tail lights/ZL1-1LE 3rd brake
Rotofab cai
lug nuts, torque specs, torque wrench
