Old 07-22-2012, 06:13 PM   #1
mdiaz0618
mdiaz0618's Avatar
Drives: 2012 1LS
Heel and Toeing v6
Whats up everyone, kind of a nooby question here, but whenever i heel and toe into 2nd gear, I either 1. give it alot of gas and end up going so slow, or 2. not giving enough and jerking alittle. 3. I give it the right amount of gas and i still jerk. Im practicing my ass off and still cant get it down right, Anybody else on the same boat? How much gas are you suppose to give it when you downshift into 2nd? v6 1LS
Thanks
mdiaz0618 is offline   Reply With Quote
Old 07-22-2012, 08:26 PM   #2
DarkneSS
Drives: 2010 Camaro 2SS/RS 6MT
Wish I could explain, I generally just "feel" it. If I'm going slow and I'm downshifting to 2nd I normally give it a small pulse and that does the trick perfectly. It really depends on the speed. 2nd goes from about 8mph at idle to 65mph at redline so the closer your current speed is to 8mph the less gas you should give it. Like if I'm on a hill stopped waiting for a light, when it turns green I'll roll in neutral if its steep enough then press the clutch in and put it in 2nd. When I hit 8 mph I let off the clutch with no gas and the gear engages smoothly. Now lets say I'm rolling on flat ground same situation with the car in 2nd and the clutch in, and I'm going say 20 mph, I'll give her about 20-25% throttle. If I'm going 45-65 mph and I want to go into 2nd, which are likely race like situations, I'll give it a minimum of 60-80% throttle to get that perfect downshift with no jerk.
How many miles do you have? You probably just need practice.
My best advice, start by giving it more gas than you think you need and work your way down into finding the sweet spot. You won't cause too much damage giving it more gas but you will if you aren't giving enough and you jerk it, which means you're bogging.
Lol I hope I helped even a tiny bit, very hard to explain over the internet.
DarkneSS is offline   Reply With Quote
Old 07-22-2012, 08:33 PM   #3
mdiaz0618
mdiaz0618's Avatar
Drives: 2012 1LS
haha wow, thanks bro, yeah I have about 3700 miles on it, I was driving to Jersey today and all of a sudden i was thinking to myself, why the hell do i keep jerking into 2nd going into turns and stuff lol
Old 07-22-2012, 08:37 PM   #4
mdiaz0618
mdiaz0618's Avatar
Drives: 2012 1LS
Alot of people say that you dont have to heel toe in everyday driving situations, but how are you ever going to turn without doing it? haha what part of NY are you?
Old 07-23-2012, 09:54 PM   #5
DarkneSS
You do you just don't need to do it all that much. If you live in NY you have to downshift a lot so you better learn the right way or you will mess your car up quick ya know? I'm over in Yonkers/White Plains!
Yeah this is my first stick car and I've heard from others that its a bit tricky of a stick car to drive. 1st gear is like a 4.x gear ratio too so its very short, i think thats why going from 1st to 2nd without jerking takes a little more practice at first.
Old 07-24-2012, 07:02 AM   #6
Norm Peterson
corner barstool sitter
Norm Peterson's Avatar
Drives: 08 Mustang GT, 10 Legacy 2.5GT, ...
mdiaz - are you really talking about heel & toe (where the brake pedal is involved) or just double-clutch downshifting to get the revs matched (and lose the jerking)?
Pedal spacing on most cars isn't particularly conducive to true heel-toe'ing, and for most street driving the simpler double-clutch is sufficient.
Either way, it's a "feel" thing that comes with practice.
On edit . . . the wider the transmission gear ratios are spaced, the more you have to kick the gas to get the revs matched. In most cars, dropping into 1st from 2nd at any speed above a jog is more trouble than it's really worth.
Norm
Norm Peterson is offline   Reply With Quote
Old 07-24-2012, 11:34 AM   #7
kenkartasasmita
COTW [4/23/12]
kenkartasasmita's Avatar
Drives: Camaro Of The Week.
this might help you.
Originally Posted by Nightfall View Post
C.A.M.A.R.O- Constantly Adding Modifications Addiction Relentless Obsession
2010 Camaro V6 1LT | Kooks Catback Exhaust + MBRP exhaust tips | TF3 Stripes | GM Transformers Emblem and Door Sill | Stillen splitter | GMX rear diffuser | K&N CAI | Pulstar iridium spark plugs. | Gm High Wing Spoiler | BBK LT Headers | BMR 4 Point Strut Bar | BMR 1" Lowering Springs | ZL1 Side Skirt | Black Ice-olator | Trifecta Tune |
My Build Thread
kenkartasasmita is offline   Reply With Quote
Old 07-24-2012, 07:26 PM   #8
mdiaz0618
mdiaz0618's Avatar
Drives: 2012 1LS
Norm, yes I'm talking about heel toeing
Old 07-24-2012, 08:34 PM   #9
mdiaz0618
mdiaz0618's Avatar
Drives: 2012 1LS
and Norm, how do you double clutch when going into a turn?
Old 07-25-2012, 10:02 AM   #10
Norm Peterson
On the street typically approaching an exit ramp - down one gear before I start to brake, down another just before corner entry and after I've got my braking done. That's in the 5-speed cars, sometimes in my wife's 6-speed car I'll squeeze one more in between depending on conditions. A few tenths of a second on the street means nothing.
If I'm being held up badly enough in the turn to want yet another downshift, it'll be because I won't be moving fast enough for it to upset the chassis balance even if I do get a little clumsy (which still happens once in a while even after as long as I've been driving).
Anybody who claims to get every single downshift perfect with no jerking ever - has a case of selective memory.
Norm
Old 07-25-2012, 10:10 AM   #11
mdiaz0618
mdiaz0618's Avatar
Drives: 2012 1LS
idk I'm starting to think the camaro wasnt meant for easy heel toeing, im still messing up fml lol, what if you put it in neutral, brake and after the turn put it in 2nd and go on from there?
Old 07-25-2012, 11:41 AM   #12
Norm Peterson
Ever since Audi got into trouble with "unintended acceleration" (aka "pedal mis-application") back in the mid-1980's, cars have not been set up with H-T in mind. Of all the cars in my driveway now, my wife's Legacy 2.5GT is probably set up for it the best.
I think you need to get the matter of rev-matching down first, and even when done in a perfectly straight line just this part takes a little practice.
1. Clutch in/shift into the neutral gate/clutch out.
2. Kick gas to bring revs up and then get out of the gas.
3. Clutch in/downshift to lower gear/clutch out. Don't wait for the engine revs to start falling - do this while the engine revs are dropping to or slightly through the rpm that the lower gear wants to see at whatever your road speed is.
Even though there are several distinct operations involved, they really just sort of all flow together without much thought after a while.
Coasting in neutral is a poor choice (and may even be illegal in some areas).
Norm
Old 07-25-2012, 11:44 AM   #13
mdiaz0618
mdiaz0618's Avatar
Drives: 2012 1LS
Thanks norm, can you do this while braking and turning though?
Old 07-25-2012, 12:19 PM   #14
Norm Peterson
First things first. Straight lines for now.
Yes, it's possible. If you're cornering very hard at all, you have to be smoother. If you're also braking, you also have to get that gas kick done without spiking the pressure you're putting on the brake pedal or taking much pressure off it. You can upset the car otherwise.
I've heard it said that braking is the last skill that fully develops . . . FWIW
Norm
