Flowmaster Exhaust
Old 07-24-2012, 04:05 AM   #1
DarkCry956
DarkCry956's Avatar
Drives: 2011 Camaro 2SS/RS
Unhappy Keep JRE tune or get it Dyno tuned?
I'm not completely satisfied with my Camaros performance I feel like there's a lot left in it. I have full bolt ons, JRE 470 cam, ProTorque 2800 stall and Teds SCT tune.
DarkCry956 is offline   Reply With Quote
Old 07-24-2012, 04:24 AM   #2
mikeSS
mikeSS's Avatar
Drives: 2015 c7
ted will be able to tune remotely better then some dyno tunes. first it depends on who your tuner is.
second, why do you feel like its not right.
also maybe you could contact ted maybe he can make sure everything is right with tune.
Old 07-24-2012, 04:33 AM   #3
DarkCry956
DarkCry956's Avatar
I will be data logging once again just to make sure. It's not that I don't feel its right I just feel like there's more that could be done. I went to the drag strip recently and just did .02 better than last time. I added the cam and stall since then.
Old 07-24-2012, 04:34 AM   #4
RogerBzSS
RogerBzSS's Avatar
Drives: 11 IBM n White 2SS/RS M6
Here is what i would do
Call and talk with Ted
And see if youre concerns can be
improved without a dyno visit
Ted gets 50$ for additional tune adjustments, i would maybe go this
Route once twice if my concerns improved significantly
But being a few short 2 hr drive from jre
I would schedule some dyno time and throw the 100 from above towards the dyno time
But call Ted to discuss youre issues with the cars performance 1st
Sent from my DROID X2 using Tapatalk 2
Black CIA -Powder Coated Red Air Scoop - Vmax Ported Throttle Body - Ceramic Coated Dynatek Headers - High Flow Cats out thru factory Cat Back - JRE rough idle cam package - Trunion Upgrade - Valve Springs - Hardened Push rods - 3 bolt timing gear - SLP Under drive pully- Washer bottle relo kit - Hurst Short Throw Shifter with updated pin bushing from C5 member NH-SS - IdealG's improved Master Cylinder - GTO Clutch reservoir - L99 Brake Reservoir - Stainless Braided clutch line - wrapped up with a JRE Tune My SS layed down 462 hp on JRE's Superflow Dyno
RogerBzSS is offline   Reply With Quote
Old 07-24-2012, 08:02 AM   #5
Southern Comfort
No Tags/Habitual Violator
Southern Comfort's Avatar
Drives: 2010 ABM/LT/RS & z71
Ted has always gone above and beyond for me. I would try him first since he has some history with your car.
Did you see much change in mph in the quarter mile? Often times the et suffers from poor traction, but mph can tell you more about the overall power increase.
Also, forgive my ignorance, are you saying you added the cam & stall & JRE tune then gained .02 in the quarter mile? Can you post the best two tickets?
Southern Comfort is offline   Reply With Quote
Old 07-24-2012, 08:25 AM   #6
Smirnoff
Smirnoff's Avatar
Drives: Camaro SS
Simple answer is your car is making higher HP @ a higher RPM band.....so, if you are not taking advantage of the higher RPM band (launching, shifting, etc) where the power is, you will not like the results.....
11.90's w/headers, CAI, tune, & some high-test (no bling).
Smirnoff is offline   Reply With Quote
Old 07-24-2012, 08:31 AM   #7
Smirnoff
Smirnoff's Avatar
Drives: Camaro SS
I would also recommend (as others) a dyno tune to assure HP/TQ#'s are valid & the motor specs are OK!
Old 07-24-2012, 08:47 AM   #8
Erik@lashway
Erik@lashway's Avatar
Drives: Camaros, Vettes, Trucks
Nothing like a custom dyno tune...sorry folks.
Erik@Lashway
Erik@lashway is offline   Reply With Quote
Old 07-24-2012, 11:11 AM   #9
KARBON
KARBON's Avatar
Drives: 2010 CAMARO 850 RWHP/733 RWTQ
*Night Fury
*Vortec YSI
*Alky Meth
*RPM TH400 with Brake
*Precision 3600 Converter
*850 RWHP/733 RWTQ
KARBON is offline   Reply With Quote
Old 07-24-2012, 11:50 AM   #10
JLE58
Drives: CGM,twin turbo, cam 2010 SS/RS
I'm sure ted has dyno tunes a lot of cars with your same set up. The heat right now and/ or poor track is a heart breaker for people looking for good times.
JLE58 is offline   Reply With Quote
Old 07-24-2012, 05:25 PM   #11
DarkCry956
DarkCry956's Avatar
I got 4 mph gain on the 1/4 and 9 mph on the 1/8
Yes that is correct I only gained .02 when I added the cam and stall.
I don't know how to post pictures from my phone
Oh and my MPG really took a hit
Old 07-24-2012, 05:50 PM   #12
Southern Comfort
If you got the MPH info correct, you picked up 130+ hp in the 1/8th based on MPH
Then something happens and power falls off.
What was the 1/8th ET gain?
It would be really interesting to see the ticket incremental times of the comparison runs.
Old 07-24-2012, 06:02 PM   #13
DarkCry956
DarkCry956's Avatar
1/8 got worse actually...
Bolt ons was
60-2.015_1/8-8.460 at 85.64_1/4-12.991 at 108.68
Cam and stall is
60-2.263_1/8-8.597 at 94.33_1/4-12.976 at 112.54
60-2.187_1/8-8.597 at 92.79_1/4-12.979 at 112.81
Old 07-24-2012, 06:05 PM   #14
Motion427
Drives: 2010 2SS/RS Red Jewel L99
Looks like you lost some traction.
Stock tires?
Your making more power by looking at the mph.
Motion427 is offline   Reply With Quote
