Emblempros
Old 07-25-2012, 12:25 PM   #15
ChibiBlackSheep
ChibiBlackSheep's Avatar
Drives: 2000 MCSS, 2013 1LS & 68 Camaro SS
Send a message via AIM to ChibiBlackSheep
bowtie v 6 . c o m/forum/download/file.php?id=1404&sid=a733378da3a21ccf72519da91c2ff 303&mode=view
(remove the spaces)
Start multiplying for your rev matches. Example, you drive a v6 in fifth gear and it's 1.0, you want to drop to 2nd? multiply your current RPMs by roughly 2.5, so if you are going in 5th at 2k, then you want 2nd at 4.5k
I enjoy math, once you learn your ratios and can multiply quickly in your head you will be fine... or just use rough estimates
2013 Camaro 1LS - Daily Driver
1968 Camaro SS - Show Car
2000 Monte Carlo SS - Paxton Novi Supercharged Project
2008 Impala LT - Because we need at least ONE family car
ChibiBlackSheep is offline   Reply With Quote
Old 07-25-2012, 12:28 PM   #16
Mr. Unassailable
Mr. Unassailable's Avatar
Drives: 2010 2SS MT, 2010 SHO, 2004 S60R
Originally Posted by puertoricanfont View Post
That happen to me when i first got the car but with nannies on and lets just say that I almost dookie myself
yeah, its more likely going to second to loose the ass. But under the right conditions if you perform a poor downshift at highway speed and floor it, you can loose it.
Garage: 2010 Camaro 2SS/RS M6, 2010 Taurus SHO, 2004 S60R GT, 2008 F250
Mr. Unassailable is offline   Reply With Quote
Old 07-25-2012, 05:33 PM   #17
Nightspore68
Nightspore68's Avatar
Drives: 2013 Camaro ZL-1, Victory Red
The skip shift doesn't seem to mind if you go to 3rd instead of 4th. 4th does seem too high most of the time when the skipshift asks for it.
Rev-matching the downshift takes experience. You just have to be sure you won't hit the redline if you downshift.
I coast to stops. I used to downshift. Nessal's right; you won't have any power. But if you're paying attention, you should have plenty of time to apply power if you suddenly need it.
I disagree about leaving your car in gear at lights. First, it becomes tiring. Second, what if you faint or have a heart attack or simply get rear ended? The last thing you need is for your car to launch into an interesection at the very moment you've lost control.
You'll figure it all out. It's fun, isn't it?
Nightspore68 is offline   Reply With Quote
Old 07-25-2012, 05:44 PM   #18
Nightspore68
(remove the spaces)
You just turned driving into work!
I like math, but not while I'm driving. OK, sometimes I will try to compute how many more miles I can go on a tank or who much longer a trip is... but not during gearshifts.
Old 07-25-2012, 05:51 PM   #19
STW
STW's Avatar
Drives: 2011 Camaro 1SS/RS LS3
I drive the shit out of mine. Change the oil, put premium fuel in it. It's all I can do. Did the same thing with my Chevelle, except it was more oil changes, more premium fuel. 1 to 4 don't bother me cause I shift at a minimum of 2500. Don't buy used. ha.
STW is offline   Reply With Quote
Old 07-25-2012, 09:44 PM   #20
ChrisBlair
Buick 455 Fan
Drives: 1970 Buick, 2012 1SS LS3
How can you pick any gear and decide 'this is the gear I make turns in'? Choose the gear that meets your needs for whatever speed you are carrying.
Why choose to start in second to miss the skipshift? Just shift out of first at an rpm that isn't affected by skipshift. Try 2,000 rpm. Skipshift saving gas does not compute with me, the way the car bogs. I can see it being dangerous, in fact, as the car has no grunt, and gee, here comes a truck blowing a red light. Better economy tip: 1-2-4-6
Rev matching? Why are you worried about this? Are you driving at 9/10ths and need that extra competitive edge? Rev matching is a nice skill to have. But you don't need to use it. Ever, really, until you race for real.
Re: downshifting to come to a stop. Of course. But that doesn't mean 'breaking the tires free on downshift'. You choose the gear appropriate for any speed, whether accelerating or decelerating. Let's say you're coming to a stop from 35 mph and you're in 4th gear. You stay in fourth as you brake. Oops, now you're doing 25 mph and you don't need to stop. You're in 4th gear. For God's sake, why? I'd be in second. At a stop, neutral sure. At 5mph in a coast and I know I'm stopping? Neutral
When you drive an manual, think about what an automatic transmission is doing. It upshifts and downshifts depending on RPM. You're doing nothing different.
ChrisBlair is offline   Reply With Quote
Old 07-26-2012, 01:51 AM   #21
pvolcko
pvolcko's Avatar
Drives: 2012 SS2/RS
Rev matching is more of a feel thing for me. Don't really think of it in terms of mutlipliers or even rpms. More like, "What sound does 3rd normally make at this speed?" Blip the throttle to get near the sound and then a swifter than normal clutch release (not a dump, but quick) and the gas. It takes time to get to know the car and the sound and feel of things at different gears and speeds.
While it is a necessity in a race/track setting, it is also good in every day driving: it lessens powertrain thrash; helps syncros mesh up for easier shifts (get very good at it and you don't even have to use the clutch to shift into the next gear); makes the ride for passengers more comfortable; and in the event you do need to zip around something in an emergency having it down can mean the difference between breaking the tires loose due to a bad downshift or safely negotiating the pass.
And it sounds cool and impresses gearhead friends.
Whatever you do, don't practice this or even try a normally executed aggressive downshift while in a turn (sweeper or tight). It is very easy to break the rear loose on these cars when downshifting aggressively (large gear jump and/or too-fast clutch release without proper rev match). Doing so in a turn can be the start of a very bad day. Stabilitrac will save you in some (perhaps many) cases, but I wouldn't test it at high speed.
pvolcko is offline   Reply With Quote
Old 07-31-2012, 03:33 PM   #22
bb040
bb040's Avatar
Drives: 2011 2LT/RS red jewl tintcoat
when i drove sticks i'd let the sounds the engine and car make tell me when and how it should be shifted i know it's kinda lame but i learned to drive on a stick at 13 and that became second nature for me ...if you can pull away up hill from a standing start and not roll backwards or burn your clutch you will have mastered your stick shift...that's what i taught my kids when i taught them to drive a stick
bb040 is offline   Reply With Quote
Old 07-31-2012, 04:59 PM   #23
1BADLS3
1BADLS3's Avatar
Drives: Sold: 2011 2SS/RS
Originally Posted by FaytalsCamaro View Post
So this is the first manual vehicle I have had and to be quite honest with you I don't think I'll ever go back to driving an automatic. Anyways it's been awhile since I've stalled so I'm pretty proud of myself.
I do have some questions and hope to get some insight and advice from you vets though. Im just gonna list off some of the things I do and have heard and you guys can comment on them.
I ALWAYS take turns in second gear. Is it ok to take them in third? Or does it just depend on your speed?
Depends on your speed. If your car was a 4-speed or 5-speed, 2nd would be the most likely suspect for most 90 degree/corner turns. With the 6-speed and torque of the new Camaro motors, it's usually a toss-up between 2nd or 3rd for corners depending on the conditions, sight distance, etc, and how hard you want to pull out of the corner.
I USED to take off from a stop in second also to avoid the skipshift. But lately I have been going from First to Third, First to Fourth seems to bog down too much.
I'd advise against taking off in 2nd. To take off in 2nd, you have to slip the clutch a little more than normal...that's unnecessary wear. I'd take off in 1st and then decide where to go from there.
Skip shift does momentarily lock you out of everything but 4th gear. If you wait a second, the program will terminate and you can shift into any other gear. I'm really not a fan of the skipshift program...as mentioned, a ~$20 part (basically a pigtail that connects to a wiring harness coming off the trans) will eliminate the program. FYI...I haven't purchased a skipshift eliminator, so I usually slowly shift to 3rd, or if I get skip-shifted out of my next gear, I ride 1st a little harder.
Rev Matching: How do I know the correct RPMs? For example awhile back there was a thread here with a poll asking what everyones favorite gear. Most said third. So I tried it out on the highway. ( Cheese and Rice does it get up and go) But let say Im going about 65 on the highway in 6th. What should my RPMs be at before I downshift to third and go?
You can do a mental math exercise if you know your gear ratios (not practical, if you're dumb like most of us). Or, you can watch and practice. For instance, if I'm in 4th gear, I know I'm going approximately 35mph at right around 1800rpm. If I want to go to 3rd, the RPM's will be higher. Probably around 2400rpm or so. So, shift down and blip the throttle. If you didn't blip enough, you'll feel the car slow as you shift/clutch out into a lower gear. If you blipped too much, you'll feel the car accelerate as you shift/clutch out to a lower gear. "Just right" means you can let out the clutch out with zero slipping or jerkiness in the ride of the vehicle as the speed of the engine and speed of the transmission input shaft are spinning at the same speed, requiring zero slipping of the clutch. Practice comes from memorizing certain points of RPM, speed, and gear selection. Or mental math, if you're crazy Some rev matching is better than none...it really grinds my gears (pun) when people shift to a lower gear and just let out the clutch. It wears the clutch and unsettles the car, annoys passengers like me.
When coming to a stop a always shift to neutral and cruise to a stop. Should I be downshifting through the gears to come to a stop? And when I'm at a stop I always stay in neutral till I'm Ready to go.
I think practical driver's training advises that you keep the car in gear all the time. My style is slightly modified...I do keep the car in gear while I slow to a stop, but the gear is dependent on how fast I was going. I can ride 4th down to 20mph or so, 3rd down to 12 or whatever. I don't downshift through ever gear, I basically clutch in a hundred or two RPM before the car would want to buck ("lug") if I went any slower. This creates for a really smooth stop, and clutching in should be seamless/unfelt. While stopped, I keep my foot on the brake, clutch out, gearbox in neutral. I watch traffic and lights, and shift to 1st before my light turns green. It gives my foot a rest, keeps wear off the throwout bearing.
Any advice or comments would be greatly appreciated and thanks in advance!!!!
Do what feels natural. It's best to practice rev matching when you're NOT driving for performance. See if you can perfectly rev match while putting around town. Practice at higher speeds/RPM as you get more comfortable. It's a smooth driving skill just as much as it's a performance driving skill.
1BADLS3 is offline   Reply With Quote
Old 12-20-2012, 12:07 AM   #24
shrinkdoc
Drives: SRT Yugo GT Super Sport with Manual
Nawww...you are just wasting gas if you start downshift to stop the car. Just mash the clutch and brake to stop it. Just downshift if on steep inclines to save your brakes.
shrinkdoc is offline   Reply With Quote
Old 12-20-2012, 03:02 AM   #25
IPT
Drives: '02 Trailblazer, '12 Camaro 2SS/RS
I'm no expert, but as mention I just blip the throttle and let out the clutch to rev match as I downshift. Then it's sort of simulataneously onto the gas. I've never lurched or chirped doing it that way, it's quite smooth actually.
I tend to maybe downshift one gear or just let the car decelerate in the gear I am in as I come up to a light. I'll then clutch it around 1000 RPMS sometimes a little lower if am feeling lazy and want to push it. Then I am into neutral waiting. Clutch in, 1st gear when I see the yellow light go for the traffic going cross the intersection and I am ready to go.
IPT is offline   Reply With Quote
Old 12-20-2012, 03:07 AM   #26
sspolo
sspolo's Avatar
Drives: 2014 Camaro SS 1LE
Good memories! Kind of reminded me of me when I was learning manual. I went to a hill where cars rarely passed and I just kept on practicing until the car didn't roll backwards. It took me hours to get it right but I got it down in one day. I haven't had problems ever since! Makes me miss driving , I hope I get a job soon and buy myself a Camaro.
sspolo is offline   Reply With Quote
Old 12-20-2012, 12:23 PM   #27
velocity149
velocity149's Avatar
Drives: 2014 2SS RS LS3
2k x 2.5 = 5k rpm... lol just ball bustin'
Thank our veterans for peace today, Support our troops for peace tomorrow. RIP Dad, 1962-2012 SYOTOS
velocity149 is offline   Reply With Quote
Old 12-20-2012, 01:39 PM   #28
oyealiz
oyealiz's Avatar
Drives: c7 3LT, manual, vert
Send a message via AIM to oyealiz Send a message via Yahoo to oyealiz
Y'all make driving a stick seem like WORK instead of FUN!!!
oyealiz is offline   Reply With Quote
