SDTW Custom Wheels & Tires
Old 07-25-2012, 11:13 PM   #1
cid067
cid067's Avatar
Drives: Black 1SS/RS LS3 M6 "The Toy"
Drag Alignment
Does anyone have a good drag alignment that they are using info would be appreciated.
2010 1SS/RS Diablo Sport Trinity JRE Tune OBX headers with Cat delete Borla Cat back Volant PowerCore CAI BMR adjustable trialing arms 4.11 Gears JRE cam package.
cid067 is offline   Reply With Quote
Old 07-26-2012, 12:36 AM   #2
JusticePete
VIR Specialist
JusticePete's Avatar
Drives: Camaro Justice
Yep. The objective is to lower the front tire contact patch while maxing out the rear tire contact patch.
Front
Caster is not adjustable from the factory
Camber -1 for a street driven car and maxed out negative -2.2 for a strip only car
Toe 0.00
Rear
Camber 0.00 and no more than -0.50
Toe IN 0.10 Total 0.20
Old 07-26-2012, 01:01 AM   #3
Turbo99
Turbo99's Avatar
Drives: 08' F250 Diesel & 10' Camaro 2SS
Yup what he said, I just did basically the same thing and dropped a couple tenths off my 60ft time.
Contact me for questions: coopwfo@gmail.com I cant send/receive PMs.
08' F250 CCSB 6.4L Diesel White & Black, Blacked out, 580RWHP @ 55psi 13.21 @ 101mph
10' Camaro 2SS LS3 M6 White & Black, Blacked out, 684 RWHP & 633 FT.LBS @ 10psi 10.82@130mph
TVS2300 ,Hendrix Street Slayer Twin Carbon Clutch, Dana 60 3.73, DSS 1400HP Axles,JRe cam & LaMotta Performance tuned,LPE Fuel, AI Super Chiller,MT ET Streets
Turbo99 is offline   Reply With Quote
Old 07-26-2012, 08:05 AM   #4
cid067
cid067's Avatar
Thanks for the info much appreciated
Old 07-26-2012, 07:29 PM   #5
Rhino79
Rhino79's Avatar
Drives: 2010 Camaro SS L99/Auto
Why the toe in the rear? I would figure youd want the rear toe at 0 as well?
GM LSX parts, builds, and calibration. Home of some of the fastest LS powered vehicles in the world!
http://www.gwatneyperformance.com/
ryan@gogwatney.com jzajac@gogwatney.com aaron@gogwatney.com
Rhino79 is offline   Reply With Quote
Old 07-26-2012, 08:15 PM   #6
pouncer72
Drives: 2011 Camaro SS
Send a message via AIM to pouncer72
Pete, why recommend negative camber at all for the back tires, just curious. I'm at +0.30 camber at ride height.
pouncer72 is offline   Reply With Quote
Old 07-26-2012, 08:22 PM   #7
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1967 Camaro
Madman always suggested toe-in for front of 4th gens.
PROJECT HEAVY CHEVY
13.15@106 1.95 | 100% Stock
Old 07-26-2012, 10:11 PM   #8
Turbo99
Turbo99's Avatar
I did do zero on mine for the rear toe.
Old 07-27-2012, 01:12 AM   #9
JusticePete
VIR Specialist
Originally Posted by Rhino79 View Post
Why the toe in the rear? I would figure you'ld want the rear toe at 0 as well?
The 5th Gen Camaro 5 link is reasonably stable under load. There is some wheel splay under hard acceleration. The toe in helps control that as well as being stable well into triple digits.
I think +0.30 is great. Not all OE height 5th Gens can get there. I haven't seen a single OE hight 5th Gen that couldn't get to 0.00. Many that drag also lower. the -0.50 is for them. With our extended range camber eccentric bolts we add 1 degree of additional adjustment if needed, but I was trying to avoid any product related information in this thread .
We run more than 1 degree of toe out on road course cars with excellent high speed stability. 0.00 toe decreases rolling resistance. That is why we suggest maximum attainable negative front camber, even with skinnies. Every fraction of a second we can find.
The total Toe is only 2/10ths of a degree. We know it will be more stable at high speeds and it should help control wheel splay in the 60'. That said, we are splitting hairs.
Old 07-27-2012, 09:31 AM   #10
Hendrix-Engineering
Drives: First 9 inch-12 bolt IRS Camaro
We use a 1/16th of toe in on the rear to keep the car a lil more stable and not WALK at speed...We stand the rear tires up like a straight axle...
Hendrix-Engineering is offline   Reply With Quote
Old 07-27-2012, 09:38 AM   #11
Pro Stock John
Writer
Toe out for drag racing will wander a bit no?
Sent from my PC36100 using Tapatalk 2
PROJECT HEAVY CHEVY
Old 07-27-2012, 12:02 PM   #12
JusticePete
VIR Specialist
In the front, no. In the rear, yes.
Old 07-27-2012, 12:11 PM   #13
willhe64
willhe64's Avatar
Drives: 2012 45th Vert, 2011 4x4, 9sec Vega
As far as old school drag tech goes, what we try to achieve is the best alignment under the cars full load conditions. When you accelerate down the track, the rear end squats a bunch and the nose comes up a bunch. We set the alignment for the cars attitude.
I feel it only fair to warn you, I have a black belt in CAPS LOCK.
willhe64 is offline   Reply With Quote
Old 07-27-2012, 12:13 PM   #14
JusticePete
VIR Specialist
The more things change, the more they stay the same.
