BORLA
Old 07-26-2012, 12:48 PM   #1
mikesvert
Drives: 2012 2SS TF & 2012 LT Conv(hers)
What PSI to run on stock tires at the dragstrip?
Running the stock pirellis on my SS and trying to help with wheel spin. I assume dropping some tire pressure will help ? Whats a good # to run them at??
Thanks,
mikesvert is offline   Reply With Quote
Old 07-26-2012, 02:56 PM   #2
Quick
Quick's Avatar
Drives: 2012 Camaro SS 45th
I drop mine down to 25 psi...never lower. some will, I wont.
OBX 1 7/8 LT's w/high flow cats. Doug Thorley catback w/x pipe. Cold air intake by CAI w/apex scoop.V-max ported throttle body.DynoSpeed tuned by Forest.369 rwhp/385 rwtq
Something wicked this way cometh...
Quick is offline   Reply With Quote
Old 07-26-2012, 03:38 PM   #3
Stingr69
'69 Owned Since '79
Stingr69's Avatar
25 PSI hot worked well for me. Traction is very limited with my car. "Chirp and roll on the throttle" is about the best I can shoot for with the stock Pirellis and a blower.
-Mark.
Old 07-26-2012, 04:09 PM   #4
mikesvert
Thanks fellas... ill try 25 at the strip tomorrow and see how that works.
Old 07-26-2012, 04:36 PM   #5
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1967 Camaro
L99, I've run 22-25 psi cold. Last time I ran 23 psi, cut 1.92 but the track was also great.
PROJECT HEAVY CHEVY
13.15@106 1.95 | 100% Stock
Old 07-26-2012, 05:41 PM   #6
DarkneSS
Drives: 2010 Camaro 2SS/RS 6MT
I cut a 2.01 in a stock V6 RS with the pressure at 23.
DarkneSS is offline   Reply With Quote
Old 07-27-2012, 12:43 PM   #7
blufin
blufin's Avatar
Drives: Fire Engine
I never run my Pirelli's less than 30-32 and have managed a 1.87 60" time stock, and a 1.77 60" after the supercharger was added. If you let too much air out of the tire, it will begin to cup in the middle, decreasing the contact patch and limiting traction. Stock tires are made for optimum performance at a certain psi and temp. Go outside that and the traction will suffer.
12.618 @ 110.75 Bone Stock 1/4 mile
8.165 @ 86.52 Bone Stock 1/8 mile
11.189 @ 124.44 on a 1.73 60' TVS2300 3.4 pulley, JRE tuned, Kooks LT headers and HF cats, MBRP catback exhaust, CAI intake, ADM scoop. Stock wheels/tires.
Sold
blufin is offline   Reply With Quote
Old 07-27-2012, 12:45 PM   #8
Nasty1970
Nasty1970's Avatar
Drives: 2011 Red 2SS RS Convertible
This was a conversation i just had with some friends....the tires obviously grab better at lower PSI, but how does this affect the top end i wonder? Because a maximum(according to tire) inflated tire has less resistance at higher speeds, I wonder if the tire pressure cancels itself out in this case, or is traction more important? I know traction is incredibly important, but if a consistent launch could be obtained with properly inflated tires, would the ETs be lower?
I’m not sure this is an answerable question because the results are probably negligible, but I’m curious. I run drag tires on my 1970, and run about 18 PSI. But the design of those tires is completely different than the Z-rated Pirellis on my 2011....Food for thought! Food for thought!
[IMG]
<a href=http://i683.photobucket.com/albums/vv198/nacogdochesjaycees/20161112_121016.jpg target=_blank>http://i683.photobucket.com/albums/v...112_121016.jpg</a>
[/IMG]
1970 Camaro ,2011 Red Convertible 2SS,2008 Saturn Sky,2012 Jeep Wrangler
Nasty1970 is offline   Reply With Quote
Old 07-27-2012, 12:59 PM   #9
camslambam
Drives: 2010 SS, 06 SRT10 Ram
Use to run 18psi on my 21s.
camslambam is offline   Reply With Quote
Old 07-27-2012, 01:03 PM   #10
scrming
Red Brick of Vengeance!
scrming's Avatar
Drives: 12 Second Brick
I would say 25 to 28 PSI... too low the tires will cup and you'll actually end up with less of a contact patch.
Other thing speaking of tire pressure... go ahead and OVER inflate your front tires! I would run them up to 45 PSI or so.... don't forget to let the air out when you leave the track though...
scrming is offline   Reply With Quote
Old 07-27-2012, 01:42 PM   #11
Pro Stock John
Writer
Car won't feel weird at 25 psi, no difference at all actually.
On other cars I've run slicks as low as 11 and drag radials as low as 14.
PROJECT HEAVY CHEVY
Old 07-27-2012, 04:21 PM   #12
mikesvert
Thanks for all the feedback fellas ... great info...cant wait to experiment
