third_shift studios
Old 07-27-2012, 06:17 PM   #1
Indyblue98
2012 RS 2ss
Drives: 2012 2SS RS L99 WhippleCharged
Help Finding 5 Volt Source ***
Really need to know how to access 5 volt power.
The rest is just ranting and whinning.
Purchased a Dashtronix Gauge Projector that allows the DIC and HUD to display Boost and Air Fuel Ratio's.
The unit comes with a Map Sensor that requires 5 Volt input.
When I contacted DashTronix what wires are 5 volts.. the response was to find a 5 volt sensor wire, and piggyback into the fuse for that sensor .
Don't connect to 12 volts it will destroy the unit.
OK,,, where is the source of this 5 volt sensor.
Response ,, model specific , do your own research.
Originally bought the unit in May and was installed when the Supercharger was put on.
But it was not compatiable so the Dashtronix and the Inovative Wideband were both sent back to Dashtronix for an update.
10 weeks later it returns with a 1 page install sheet.
This is supossed to be calibrated for a 12-13 Camaro
so why not tell me what the used for setup?
Indyblue98 is offline   Reply With Quote
Old 07-27-2012, 06:47 PM   #2
audiomikej
audiomikej's Avatar
Drives: the wife crazy talking Camaros
You could always buy a 5 volt regulator from digikey.com for like a $1, take the 12 volts safely down to 5 volts. Electronics 101.
audiomikej is offline   Reply With Quote
Old 07-27-2012, 06:55 PM   #3
Indyblue98
2012 RS 2ss
Thanks , From the Dashtronix response I was expecting a 5 volt source somewhere already available.
Guess thats why they said to do my own research.
Old 07-27-2012, 07:02 PM   #4
jeepguy_1980
jeepguy_1980's Avatar
Drives: 2010 Camaro 1SS
USB is 5v, so any phone charger should do the trick, or maybe the PDIM. There's also this, if you don't want to make your own solution.
http://www.1topstore.com/en-usd/car-...5w-p21794.html
jeepguy_1980 is offline   Reply With Quote
Old 07-27-2012, 07:08 PM   #5
jeepguy_1980
More
Old 07-27-2012, 07:39 PM   #6
Indyblue98
2012 RS 2ss
Cool , Thanks
Old 07-27-2012, 08:17 PM   #7
gutterball
gutterball's Avatar
Drives: 2011 1LS M6 Supercharged
Send a message via AIM to gutterball
go to walmart, they have a unit that plugs onto 12v and you select the voltage out via a slide switch, 3v, 5v, 6v, 9v, 12v etc
gutterball is offline   Reply With Quote
Old 07-28-2012, 07:02 AM   #8
CWI
Helping Build America
CWI's Avatar
Drives: 2010 2SS/RS,LS3 2013 Duramax 3500HD
Jeepguy, you gave a LS diagram. The OP has a 2SS
Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, shouting "Holy shit, what a ride!"
CWI is offline   Reply With Quote
Old 07-28-2012, 07:25 AM   #9
jeepguy_1980
BCM and radio are still the same.
