BeckyD @ James Martin Chevy
Old 07-28-2012, 01:24 PM   #1
2012ZL1
CaRaHoLiC
2012ZL1's Avatar
Drives: '12 ZL1,67 Cam,68 Biscayne 427 4 sp
plugs for headers
Just a question, when installing headers, cold air kit, pulley etc, what plugs are people using? hotter? colder? same?
Normally I would have said colder, but what are people on here using?
2012 ZL1
2.55 upper, 10" lower pullies, Innovators west billet hub and sfi balancer, solid blower drive isolator, 50 mm idler kit, full length S/S headers no cats, comp cams custom grind cam, comp roller rocker trunion kit, comp push rods,dual valve springs retainers and locks, Injector dynamics ID850 inectors, Rotofab ZL1 cold air kit, Lingenfelter 160 thermostat, Rotofab intercooler reservoir, stock plugs, LS7 90mm throttle body, GTO clutch reservoir mod, my own custom catch can, Tuning by Jannetty, install by me.
2012ZL1 is offline   Reply With Quote
Old 07-31-2012, 08:14 AM   #2
sammyv
sammyv's Avatar
Drives: 2013 red Lingenfelter ZL1
I was just looking a Lingefelter's 700+ hp kit and there is no mention of a plug change.
sammyv is offline   Reply With Quote
Old 07-31-2012, 08:57 AM   #3
ZL WON
ZL WON's Avatar
Drives: too many to list
One stage colder is what we did on my car.
ZL WON is offline   Reply With Quote
Old 08-01-2012, 08:18 AM   #4
Meister@Torq
Drives: 2001 Crown Vic
Send a message via AIM to Meister@Torq Send a message via MSN to Meister@Torq
NGK TR6 is a suggested plug for anything over stock boost
Meister@Torq is offline   Reply With Quote
Old 08-01-2012, 10:31 AM   #5
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
Yup. This seems to be the most common for LS-motors. They aren't iridium-tipped, like OEMs, nor are they platinum, which means you have to change them somewhat regularly (what - 30K-miles?...), but you'll be less prone to detonation because they're cooler to run. They're pretty inexpensive, too
05 Hummer H2 SUV on OEM Air Ride
Forged 11.4:1 408 LQ4 (K1 crank & rods; Mahle pistons)/CPP LS3 CNC heads/BTR Stage IV LS3 cam/home ported L92 intake manifold/ported 90mm TB/custom Volant CAI/mid-length headers/AFE dual 3" CB/Corvette Servo/el cheapo lift/Cognito UCAs/Sphon poly adjustable TA/Sphon adjustable rear LCAs/e'fan conversion/DirtyMax radiator/Moroso catchcan/HPTuners/HID conversion/LED exterior lighting/LED interior accents/Autometer Cobalts/AEM WBPioneer AVH-5600BHS/Pioneer GM-9601/2-Pioneer TS-W310D4s/Obcon Labyrinth dual-12 box/lots of other little stuff
Old 08-02-2012, 12:03 AM   #6
alex33x
Drives: 2013 Camaro ZL1
Are they? I would say they're cheap.
http://www.texas-speed.com/p-102-ngk...ark-plugs.aspx
Devliered July 20, 2012
alex33x is offline   Reply With Quote
Old 08-02-2012, 01:12 AM   #7
2012ZL1
CaRaHoLiC
2012ZL1's Avatar
Awesome,
Thanks for the info. I will pick up a set of these for my car.
2012 ZL1
Old 08-02-2012, 01:30 AM   #8
Blk-Ice
750HP of Twisted Reaper!
Blk-Ice's Avatar
Drives: Blk 2SS/Blk Carb Fibr NS-1 stripes
+1
Fear the LMR Twisted Reaper Brotherhood!
Blk-Ice is offline   Reply With Quote
Old 08-02-2012, 10:29 AM   #9
Meister@Torq
You can pick these up directly from our website if required for modifications
Old 08-05-2012, 08:08 PM   #10
Higgs Boson
in the ZL1 Market
Drives: 2014 C7; 2015 2500HD
change those tr6 every 10k or every other oil change.
I am running tr55s but I have a lowly ss. :-)
Higgs Boson is offline   Reply With Quote
