HeadlightArmor
Old 07-28-2012, 01:09 PM   #1
kjkjr27
COTW 9/16/13
kjkjr27's Avatar
Drives: 2011 2LT/RS Camaro IOM
newbie help
So tomorrow I will be going to the local strip to do a couple of runs for the first time ever in my life. I have an A6 and was wondering what mode is best. Also any other advice is appreciated. Sorry if this has been brought up a ton, I'm at work and don't have time to
kjkjr27 is offline   Reply With Quote
Old 07-28-2012, 06:02 PM   #2
Ice Demon
Ice Demon's Avatar
Drives: 2010 Camaro SS
First of all you definitely want to run in S mode not tap shift. Also a few other tips would be lower the tire pressure to 25-30psi in the rear tire. Also make sure you drive around the water box and if you have stock tires a burnout is not really necessary. Then turn traction control off and then when you are finally staged up hold the brake rev up to about 2200rpm ( the v6 camaros lanuch best between 2k-3k rpm) and then then when you see the third yellow light just let her rip.
Mods: "Cam Only"
Ice Demon is offline   Reply With Quote
Old 07-28-2012, 06:47 PM   #3
kjkjr27
COTW 9/16/13
kjkjr27's Avatar
Thanks very much
