autoguy
V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) Driveshafts | Differentials | Gears | Rearends | Clutch | Shifters
Old 07-29-2012, 12:50 PM   #1
GFORCE1320
Drives: 05 GTO
DynoTech driveshafts from Gforce
I'd like to share some info about the driveshafts we've been testing and selling.
We got together with DynoTech driveshafts last year at SEMA and decided to work together to bring a high end, well designed driveshaft to market for the new Camaro's.
After months of testing and then the introduction of the shafts with our 9" kits, we are proud to say we have an excellent driveshaft for the 5th gen Camaro.
We have several OEM replacement shafts out on the road as test subjects and countless shafts that we have sold with our 9" kits.
A little background info about DynoTech driveshafts,
They have been making high quality driveshafts for years. The parent company that owns DynoTech makes high speed driveshaft balance machines and DynoTech of course has the best, newest, state of the art high speed balancers in the industry to make our shafts on.
Each shaft is balanced at between 7500-8500 rpm and even comes with a balance certification tag saying the speed it was balanced to and specs.
Our new driveshafts are an articulating splined slip style shaft.
The shafts slip on a huge aluminum splined assembly that is all self-contained inside a boot assembly.
This type of shaft provides a very smooth and positive plunge as the suspension twists and stretches.
Since these shafts don’t use a cv joint on the front like some of our other shafts have used and others on the market, they are very light weight.
The 3.5" aluminum shaft weighs in at only 15 lbs, compared to the OEM shaft that weighs 24 lbs. That is a 9 lb weight savings over the OEM shaft !!
We have been supplying the slip style shafts in our 9" kits all this year and the results have been stellar to say the least. The customers and install shops can't believe what a well-designed shaft these are and how smooth they feel on the road.
The shaft is a breeze to install, we provide billet adapters front and back that make this an easy bolt in so you don’t have to disturb the differential.
Your heat shields can stay on as well, you might have to bend them around a bit but they all fit just fine. Most people take them off but some like to leave them on.
Thanks
Chris
Gforce Engineering
LIFETIME WARRANTY!
The Leaders in IRS Drivetrain Technology
gforce1320@gmail.com
www.Gforce1320.com 316-260-8433 or 8439
GFORCE1320 is online now   Reply With Quote
Old 08-01-2012, 10:26 PM   #2
thundercat 1
Drives: 2010 camaro ss/rs
thats my s/c camaro in the picture .been beating the driveshaft for some time now with zero problems.if you want the best .call the best. gforce
thundercat 1 is offline   Reply With Quote
Old 08-02-2012, 07:07 AM   #3
GFORCE1320
Drives: 05 GTO
Thank you for doing some testing for us Kevin, I really appreciate it !!
Gforce Engineering
LIFETIME WARRANTY!
Old 08-02-2012, 06:03 PM   #4
GFORCE1320
Drives: 05 GTO
We will have one of the new shafts at the Fest if anyone wants to take a look at it.
Not sure what dealers booth it will be at but just ask around.
Gforce Engineering
LIFETIME WARRANTY!
Old 08-03-2012, 08:30 PM   #5
monstertodd
Allyourbasearebelongtous
monstertodd's Avatar
Have you experienced any rubbing?
Old 08-03-2012, 08:54 PM   #6
TornadoSS
WICKDSS
TornadoSS's Avatar
Drives: 2011 1SS/RS IOM LS3
I ran the new style 3.5" driveshaft on the stock diff with no rubbing issues. I now have the entire 9" kit, no issues there either.
2011 IOM SS/RS, M6. Look up our all generation Camaro club website at Heartland Camaros
Gforce Engineering Drivetrain
12.38 @ 113 mph 1.80 60', DA 3017' - Cam and the usual mods, M&H DR's and skinnies on 17" Welds. Driver mod needed......LOL
TornadoSS is offline   Reply With Quote
Old 08-03-2012, 10:48 PM   #7
thundercat 1
very close but clears.if rubbing is a issue slot the holes slightly that hold up the heat shield,problem solved
Old 08-03-2012, 11:04 PM   #8
Sleez
Sleez's Avatar
Drives: 2010, 2LT, RS, 6M, ABM (#1893) SOLD
any plans for a V6 version?
Sleez is offline   Reply With Quote
Old 08-04-2012, 08:18 AM   #9
GFORCE1320
Drives: 05 GTO
We can do a v6 version, just need to take a look at one.
Thanks
Chris
Gforce Engineering
LIFETIME WARRANTY!
Old 08-10-2012, 11:36 AM   #10
GFORCE1320
Drives: 05 GTO
We've been selling about 5-6 of the new shafts a week now, should be getting more good feedback soon.
Thanks guys!
Gforce Engineering
LIFETIME WARRANTY!
Old 08-14-2012, 01:33 PM   #11
caverman
caverman's Avatar
Drives: '69 SS Convertible
Can you PM me pricing on your driveshaft and post some of the advantages of going with a one piece driveshaft over the OEM one.
I'm assuming less weight means it can put more power to the ground?
Build Journal
caverman is online now   Reply With Quote
Old 08-14-2012, 05:24 PM   #12
BullF-16
USAF retired! Thank God!
BullF-16's Avatar
Drives: 2011 1SS, 1LT red, 1LT/RS SGM
One advantage is you can abuse the crap out of the GForce DS and not worry about it, not so with the OEM. I tried to break GForce DS with 715rwhp, no luck, but i did break my motor....but i was actually trying to in my defense!
HKE LSX427(Mast blk lbl 305 6bolt LS7heads, PatG231/246 blower cam, ARH LT s, Procharger D1SC, Squash dual 400LPH/ID1000s, ALKY 4 gal meth, AM AFR/Bst/oilpres/oiltemp gauges,SWretro3" exh, VMaxx TB, RX monsterCC. Pedders Justice road crs pkg: All HD bushes, supercar coil overs, supercar ZL1 sways, camber plates setup by JusticePete! :Gforce 9" 35spline S-Trac, 300M axles, 3.5"alum DS, MCLeod RXT clutch, 4xForgeline 19x10.5 4xBridgestone 305/30R19 RE-11, next CTS-v calipers/ZL1rotors/carbotech pads
BullF-16 is offline   Reply With Quote
Old 08-14-2012, 06:11 PM   #13
TornadoSS
WICKDSS
TornadoSS's Avatar
Any time you can reduce rotating mass is a plus that frees up some HP. I don't know of any specific gain numbers though.
Old 08-14-2012, 06:26 PM   #14
GFORCE1320
Drives: 05 GTO
We have several options, you might take a look at our web site to see which one you might need. I will also send you a PM on prices.
You won't see a big performance improvement over a stock shaft, the main reason you would want to replace a stock shaft with ours would be the dramatic increase in strength you get with an aftermarket shaft compared to an OEM.
Our shaft is also considerably lighter so the weight saving will give you a slight performance improvement.
It takes less horsepower to spin less rotating mass.
Thanks
Chris
Gforce Engineering
LIFETIME WARRANTY!
Old 08-15-2012, 12:18 AM   #15
doomsdayjesus081
Drives: VR 2010 Camaro SS/RS
I am still awaiting the gforce shaft. I will say after about 70 miles with a competitor's shaft in my car, the felt difference in an m6 car between 1 piece and factory 2 piece is phenominal.
doomsdayjesus081 is offline   Reply With Quote
Old 08-20-2012, 11:49 AM   #16
GFORCE1320
Drives: 05 GTO
Did you get the new Dynotech shaft installed yet? We've been shipping out about 10 a week. They are selling like hot cakes, people love em!
If you read on other threads where other vendors are trying to throw our shafts under the bus, our shafts are nothing like the ones they are talking about.
They are talking about old school technology slip style shaft like you would see in a farm truck or something LOL
Our shafts are built by one of the largest driveshaft manufacturers in the industry and even come with a balance report showing how and what speed it was balanced on. Most are balanced to around 8,000 to 9,000 rpms.
They even manufacture driveshafts for Ford.
If your going to SEMA this year, come by the DynoTech Driveshaft booth. We will have these driveshafts on display.
Thanks
Chris
Gforce Engineering
LIFETIME WARRANTY!
Old 08-20-2012, 11:59 AM   #17
GFORCE1320
Drives: 05 GTO
I'd also like to add that all of our shafts are built and shipped in 3-5 days, if you need one in a hurry, we can also expedite it even faster.
Thanks
Chris
Gforce Engineering
LIFETIME WARRANTY!
Old 08-20-2012, 01:16 PM   #18
GFORCE1320
Drives: 05 GTO
I just talked to the guys at DynoTech and they make the shafts for the Ford GT500's. They are very similar to the shafts we sell for the Camaro.
Gforce Engineering
LIFETIME WARRANTY!
Old 08-20-2012, 01:24 PM   #19
TornadoSS
WICKDSS
TornadoSS's Avatar
All I can say is, if Shelby trusts these Dynotech 1 piece shafts enough to put in their Super Snake and Cobra Jet Drag cars then they must know that this is a superior design to any other style currently offered. Shelby could have went with any other shaft designer, but instead, being the innovator that Shelby was known for, after much testing, went with the Dynotech 1 pc design. The same design that Gforce is selling for our 5th Gens!
Sorry I had to mention Mushtangs on here but it proves that this shaft has been out there in use for some time without any major issues.
Old 08-20-2012, 01:32 PM   #20
GFORCE1320
Drives: 05 GTO
Originally Posted by TornadoSS View Post
All I can say is, if Shelby trusts these Dynotech 1 piece shafts enough to put in their Super Snake Drag cars then they must know that this is a superior design to any other style currently offered. Shelby could have went with any other shaft designer, but instead, being the innovator that Shelby was known for, after much testing, went with the Dynotech 1 pc design. The same design that Gforce is selling for our 5th Gens!
Ha! I was just looking at the Shelby website too LOL The shaft they sell looks just like yours
Gforce Engineering
LIFETIME WARRANTY!
Old 08-20-2012, 01:40 PM   #21
TornadoSS
WICKDSS
TornadoSS's Avatar
Yep, Dynotech is the official supplier of driveshafts to Shelby American.
Old 08-20-2012, 06:09 PM   #22
Smirnoff
Smirnoff's Avatar
Drives: Camaro SS
Thanks
Chris
Appreciate the clarification on the driveshaft style.....
No china cheap bolt-on's, drywall, buffet, or yubiwaza here.....平的
Smirnoff is offline   Reply With Quote
Old 08-20-2012, 06:18 PM   #23
GFORCE1320
Drives: 05 GTO
No problem, just wanting everyone to know that these are NOT just a simple splined male/female shaft.
The proper name for this style of shaft is "Articulating shaft"
If you look at some of the other high end cars out there like the Ford GT500 and others, this type of shaft is the one that is normaly used.
We didn't just throw this shaft together for the Camaro market, it is a proven shaft on several different platforms.
We even supply our 9" kits with them.
I'm not going to throw the cv joint style shafts because we sell those as well when someone requests one. We prefer to use the articulating slip shaft when possible. We've had very few problems with them compared to the cv joint style.
Thanks
Chris
Gforce Engineering
LIFETIME WARRANTY!
Old 08-21-2012, 12:31 AM   #24
doomsdayjesus081
Thanks
Chris
i have the shaft sitting in the living room at the moment, waiting on adapter plates to arrive tomorrow. Chris you are getting bashed pretty good in the dss vibration thread. I am definitely impressed with the visual quality of this shaft. I am anxious to install it, as I want to be able to drive my car again without the annoying metallic knock that is louder than a cammed full exhaust(headers, no cats, flowmaster outlaws) note.
Old 08-21-2012, 06:26 AM   #25
GFORCE1320
Drives: 05 GTO
I'm not too worried about it, it's just one source doing the bashing.
Our Shafts work great and are not the ones with the problems.
Let me know how the shaft works out for you.
Gforce Engineering
LIFETIME WARRANTY!
