SDTW Custom Wheels & Tires
Old 07-30-2012, 11:46 AM   #1
Rangore
Rangore's Avatar
Drives: 2012 Camaro 2SS 45th Anniversary Ed
CAI Scoop and Winter weather = bad or no worries?
I'm thinking of doing a CAI scoop and washer reloc kit. I drive my Camaro daily even in the winter. I know the draw backs of the reloc kit means a little less washer fluid, but that's not a worry. Snow/salt/ice in the scoop area is my worry. Is the scoop a bad idea with winter weather?
2012 Camaro 2SS 45th Anniversary Edition - No longer owned: 2010 Camaro 2LT, 1993 Camaro Z-28
Rangore is offline   Reply With Quote
Old 07-30-2012, 12:16 PM   #2
c_LoW29
Drives: 2011 2SS/RS, 2010 Mustang GT
I dont see why you would have an issue, people run injen intakes and those things have the filter very close to the floor and never have an issue. You should be good to go unless you drive in a blizzard.
c_LoW29 is offline   Reply With Quote
Old 07-30-2012, 12:49 PM   #3
Rangore
Rangore's Avatar
I don't drive thru heavy snow. I wait for the road to be mostly cleared off. MN winters can be a pain with snow, slush, salt, and all that crap. c_Low...are you in a northern state during the winters?
Old 07-30-2012, 12:57 PM   #4
c_LoW29
I am in maryland we dont see a ton of snow. The scoop does have more intake but i dont see it pushing up a bunch of snow at least not enough to get into the filter and damage anything.
Old 07-30-2012, 02:05 PM   #5
Rangore
Rangore's Avatar
Cool...thanks for your thoughts c_LoW
It would be cool if our Canadian friends or other northern drivers could weigh in as well.
Old 07-30-2012, 06:58 PM   #6
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
There is nothing to worry about. The scoop directs additional air flow into the air box but it does not create a vacuum capable of sucking water or snow vertically. Once the air enters the scoop it makes a 90 degree turn and travels about 1 foot vertically to the air box. With our scoop there is a 45 degree panel that directs the air vertically and provides a surface for moisture to condense against. Once it does there are holes at the bottom of the panel to allow for drainage.
cai, scoop, washer, winter
