Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums -
sjm autoprod
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - > Marketplace > Sponsors Classifieds Marketplace > V6 Bolt-Ons & Tunes
Old 07-30-2012, 12:42 PM   #1
Sales@Phastek's Avatar
Drives: 2010 X5 Camaro Turbo
K&N AirCharger Cold Air Intake #63-3078 2011-2012 Camaro V6 @ Phastek
2011-2012 Camaro V6 K&N AirCharger Cold Air Intake #63-3078 Adds 11 hp
A sister product to K&N's 57 Series FIPK, our 63 Series AirCharger® Intake Kits are guaranteed to increase horsepower and come with a Million Mile Limited Warranty. K&N intake systems replace your vehicle's restrictive factory air filter and air intake housing. K&N intakes are designed to dramatically reduce intake restriction as they smooth and straighten air flow. This allows your vehicle's engine to inhale a larger amount of air than the OEM air filter assembly.
More air means more usable power and acceleration throughout the engine's RPM range. The filters on these kits are washable and reusable. Most of our intake kits are relatively easy to install using tools commonly available (see installation instructions). 63 Series Intakes are street legal in most states. They are not legal for use in California and other states adopting California emission standards.
Part 63-3078 Product Specifications
Product Style: 63 Series Aircharger Kits
Estimated Horsepower Gain: 11.45 HP @ 5800 RPM
Replacement Filter: RC-5107
Street Legal In All States: No
The World's Best Flowing, Best Filtering, High Performance Air Intake Systems
- Guaranteed to Provide more HP and Increased Acceleration
- Engineered to Specific Vehicle Design
- Easy to Install, Usually in 90 minutes or less!
- Lasts up to 100,000 Miles Before Service is Required (depending on driving conditions)
- Million Mile Limited Warranty
- Air Filter is Washable and Reusable
- Replaces OEM Filter and Air Box
- Works with Original Equipment Manufacturer Computer Systems
- Designed to use Factory Holes & Mounting Points Whenever Possible
- Street legal in most states (not street legal in CA – Check part number or vehicle listing for specific CARB status)
K&N's 63 Series Air Intake Kits (AirCharger's) are a sister product to their 57 Series FIPK's. These intakes are built for many different vehicles and represent a dramatic improvement over a K&N O/E replacement filter alone; they use only non-metallic rotationally molded tubes that can reduce intake air temperature and decrease intake sound over a metal tube. Restriction can exist BETWEEN an air filter and the engine reducing the benefit of a K&N Air Filter. The weakest link in the airflow “chain” robs a vehicle of its natural horsepower. Often that weak point is the factory air path leading to the Engine. K&N Air Intake Kits virtually eliminate air path restriction by replacing the air filter and the entire air path to the engine. The aerodynamically engineered tube drives a massive amount of air into an engine, which translates into POWER.
These 63 Series kits are truly state-of-the-art. K&N start with the largest conical shaped High-Flow air filter we can fit into the engine compartment while using factory holes and mounting points. This extra filter size provides even more airflow at lower restriction than a standard K&N O/E replacement filter that is limited to the size of the factory air box. The oversize air filter also captures and holds more dirt increasing the service life before a cleaning is required (up to 100,000 miles). The filter is isolated from high engine temperature by a heat shield designed to lower the temperature of the air entering the engine, which increases horsepower. Next we attach the filter to a rotationally molded tube made from interlaced High Density Polyethylene. This process allows us to precisely shape the tube to reduce turbulence and accelerate airflow into the engine. This is why some of our tubes have unique shapes or indentations that are specifically engineered for each application. Finally the tube is connected to the engine with adapters made from high strength materials such as silicon and reinforced nylon and ensures long life. Put all this together and you have the best high-flow intake system available today.
Place your orders at
Sales@Phastek is offline   Reply With Quote
