southerncarparts
Forced Induction - V8 V8 Supercharger, turbo, nitrous discussions
Old 07-31-2012, 07:18 AM   #1
ITGuy11
Burning up tires
ITGuy11's Avatar
Drives: 2010 Camaro 1SS/RS
Wideband: AEM UEGO vs. Aeroforce
Looking for opinions on these two wideband O2 setups.
The Aeroforce wideband sensor combined with the Aeroforce interceptor gauge will cost ~ $420
http://www.aeroforcetech.com/product..._wideband.html
The AEM UEGO will cost ~ $190
http://www.aemelectronics.com/wideba...fuel-gauge-25/
What are your thoughts?
Blower, cam, supporting mods 644RWHP 615RWTQ
My Build Thread COTW 11/19/12
Detroit 5th Gen Camaro Club
ITGuy11 is offline   Reply With Quote
Old 07-31-2012, 08:09 AM   #2
thebeast916
Drives: Blown G8 GT
I have the aem uego and dual aeroforce gauges. Have a zr1 map sensor so I can read boost on the aeroforce. Will have fuel pressure hooked up soon too.
I have had no issues with the aem. But there are better gauges out there
2008 G8 GT-Procharger D1-Livernois Stage 1C Cam-Kooks 1 7/8 Longtubes-Magnaflow Exhaust-Camaro SS Wheels and Brakes-Demon8 Designs Triple Gauge Pod( Dual Aeroforce and Wideband)- Dual Kicker CVX10-BMR Sway Bars, Trailing Arms, Toe Rods and Cradle Bushings
596/526 @9.5 lbs
11.6 at 123. 1.92 60ft
thebeast916 is online now   Reply With Quote
Old 08-09-2012, 07:35 PM   #3
Julio@Bisimoto
Drives: Fast
I have used AEM UEGO's on my setup and is very accurate. Another Gauge to look into instead would be the AEM Wideband Failsafe gauge which displays both air/fuel ratios and vacuum/boost. It also features data-logging capability over three hours of data and can trigger a low side output if air/fuels go dangerously lean to either activate a warning light or if you have a EMS capable of receiving a low side input you can set of ignition retard, add fuel or countless other things to save your engine.
Julio@Bisimoto is offline   Reply With Quote
Old 08-10-2012, 12:40 AM   #4
Higgs Boson
Big Time Newb
Drives: C63
ngk afx w/ntk sensor
Higgs Boson is offline   Reply With Quote
Old 08-16-2012, 09:57 PM   #5
forcefedjunkie
Drives: Duramax H2
Aeroforce:
Todd
forcefedjunkie is offline   Reply With Quote
Old 08-16-2012, 10:13 PM   #6
jrpxxii
jrpxxii's Avatar
Aeroforce are top notch and loved mine
