| Camaro 1LE Forum Camaro 1LE Package releated discussions |
Thread Tools |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 1SS Join Date: Dec 2009
1LE Parts??
Will the the parts from the 1LE be offered through GMs parts departments so that owners with previous model years can fit the parts to there cars?
I've put a good bit of work into my car already to make it my own and have neither the desire nor the money to trade in for a new 1LE SS. I would have to start all over. |
H1 OFCR
Drives: 2011 Camaro 2SS/RS IOM Join Date: Jun 2011
They're already starting to be available I am almost dead sure.
Corsa
Rotofab BBK ZL1 Hood/Fascia AAC Afterburners/Sidemarkers Havoc Black Chrome 5% Tint/20% Smoked Taillights |
(Prononce Mike-Camaro!)
Drives: A 2010 CAMARO SS-LS3 Join Date: Sep 2009
Location: In the Land of the GenIV Camaros & Firebirds.
I wan to know aswell.
Allyourbasearebelongtous
Drives: 2010 Cyber Grey Metallic 2SS/RS M6 Join Date: Nov 2009
Hopefully the entire rear end will be available and will retrofit.
Casey Woodside
Drives: 2010 Join Date: Jun 2010
second that
#6 |
Founder - Michigan FBody
Drives: 1994 Camaro LT1, 2012 Camaro LFX Join Date: Jun 2008
If they were for the ZL1, I don't see any reason why it wouldn't for the 1LE. You just have to get the part number. Try contacting Maureen@RodgersChevrolet and see what she can find for you.
2012 Camaro LFX M6 - "Clifford" - 270hp/232tq on Dynojet (before TB was installed) - Cold Air Inductions CAI, VMAX Ported Throttle Body, MGW Short Throw Shifter
1994 Camaro LT1 A4 - "Red Alert" - v6-to-LT1 Swapped Cruiser; Cammed, Stalled, Enjoyed Michigan FBody Association http://www.mifbody.com/ Proud member of the unofficial Camaro5 "Rodgers Chevrolet Fan Club" |
#7 |
Casey Woodside
is it a different rear sub frame anyone remember
#8 |
SoCal Mayhem
Drives: 2010 Camaro 1SS/RS Join Date: Aug 2008
Some part numbers here http://www.camaro5.com/forums/showthread.php?t=237956
#9 |
Any care to venture an opinion on the ability of the 1LE rear end parts to hold up to boosted power?
#10 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2012 ZL1 - #670 Join Date: Jun 2009
I would venture to say it is the same gear as the LPE. The same company makes the GM oem gears as the LPE. I'm sure you could contact LPE for any questions you may have. http://www.lingenfelter.com/mm5/merc...egory_Code=C61
#11 | |
#12 |
Parts Guru Extraordinair.
Drives: '11 1LT/RS M6 CGM,01 Cavalier (DD) Join Date: Mar 2011
The strut tower brace is the same one used on 'verts.
No good deed goes unpunished...
#13 |
Looking forward to some lower priced gears and axles. Hopefully
#14 |
![]() Drives: 2012 Victory Red 1SS/RS Join Date: Apr 2012
Anyone know what the part numbers are for the red brake calipers?
#15 |
Big Time Newb
Drives: C63 Join Date: Jun 2012
Damn, I would not buy new calipers for the color. Get some caliper paint.
#16 |
They are $1670 each !
#17 | ||
![]() Drives: '03 MY/MR Z06, '09 Sliver/Red G8 GT Join Date: Mar 2012
I just read an article that said the gears will not be available thru GM. There was one other part that wouldn't be available, but I don't remember what it was. Maybe the article was wrong, but I'm sure we'll find out soon enough. |
#18 |
No offense but I want it to look perfect and to do that with just paint would mean disassembling the originals and then relettering them after painting. I think it would be best just to buy them out right.
#19 |
Founding Member of 'CTCC'
This is what i have 'so far'...
3.91 Gear Set, Part# 22813040 (GM List price $331.05) 1LE Axles - ($196.07ea) LH Axle, part num:22806795/ RH Axle part num:22806796 Does anyone know the part#'s for the Sway Bars and the 'Quad' Diffuser?
Photo Gallery; (http://s100.photobucket.com/albums/m...view=slideshow) "KILLER-BEE" on Facebook; (https://www.facebook.com/jlkillerB) |
#20 |
$1670??? That's uh, a little steep. What are the part numbers?
#21 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro IBM 2LT/RS M6 Join Date: Sep 2009
Quad Diffuser is 22815277 and is $309.00.
Looks: AAC P13W DRLs, Heritage Grille, RS Embroidered Headrests, GM Door Sill Plates, GM Premium Floor Mats, Body Color Engine Cover, LLT Mobile 1 Oil Cap, ZL1 Sport Pedals, 3M Clear Bra.
Performance: Vararam Ram Air Intake, Hurst Short Throw Shifter w/ Hurst Hard Drive Pistol Grip, IDEALG Clutch Master Cylinder, RX Catch can, GTO clutch fluid reservoir, Brembo Brakes, 1LE Track Pack, GMPP Exhaust Upgrade. Future Mods: Pedders Stainless Steel brake lines, Stage III radius rod inserts, Rear Cradle Bushings. |
#22 |
#23 |
LF # 22833922
RF # 22833923 RR # 22833924 LR # 22833925
#24 |
Thanks 727. Appreciate it.
#25 |
![]() ![]() Drives: 2010 camaro 2ss rs Join Date: Nov 2009
wish they just had a complete kit that was a dealer install
:5thgenvert:
| Thread Tools | |
