sjm autoprod
Old 05-24-2009, 03:40 PM   #1
wooav8tor
2G1FC1EV0A9107755
wooav8tor's Avatar
Drives: '10 Black 2LT Camaro
Bluetooth Gremlins?
So on my first night with #7755 I was able to pair up my bluetooth to my verizon lg voyager and use it with minimal aggravation. Before I shut her down on the first night I had an issue with both an outgoing and incoming call coming in and then immediately being kicked into private call. A minor annoyance that I chalked up to user error.
Today the 'issue' has once again reared its ugly head. So much so I'm at the point where I'm almost ready to rule out user error though readily concede that still could be a distinct possibility. Every call whether outgoing or incoming connects briefly and then is routed to the handset for private call mode. An attempt to get it to switch back is unsuccessful. So to was deleting the bluetooth connection and repairing.
Any thoughts? I'm wondering if there's other troubleshooting I can attempt. Anything to avoid having to take her back to the dealership already.
wooav8tor is offline   Reply With Quote
Old 05-24-2009, 03:51 PM   #2
UCF w00t
Geek
UCF w00t's Avatar
Drives: IOM 2010 Camaro 2SS
I would say take your phone to verizon and see if there's a firmware update available for it. Just as likely that the problem is on your phone's side of things.
UCF w00t is offline   Reply With Quote
Old 05-24-2009, 04:18 PM   #3
wooav8tor
2G1FC1EV0A9107755
wooav8tor's Avatar
Not a bad thought. I could probably stand to have it updated anyway as I haven't since I got it.
Old 05-24-2009, 09:15 PM   #4
edog
edog's Avatar
Drives: 2010 2SS/RS IOM
My Sprint phone has done it a couple times, as well as when listening to music it will skip at times. I find it is with certain file types, and not the actual unit. I change songs and it has no problems.
NOVI1500 ECS SC, 13lb boost, LS3 Conversion 113/225/238 COMP CAM, Pro Yank 3600, 1-3/4 Doug Thorley Tri-Y LT/HF cat, X-Pipe, Lingenfelter dual fuel pump, ATI super damper pulley, Ported TB, 160 therm, Tranny cooler, Pedders sways/end links/sub frame bushings, BMR trailing arms & toe rods, 1" Eibach Drop, 3.45 gears. 705HP/589TQ
edog is offline   Reply With Quote
Old 05-25-2009, 12:58 AM   #5
Gentry78
HOOK'EM
Gentry78's Avatar
Drives: 97 c1500/92 olds
i would say its the phone not the car, so i would check the security settings first then look into both manuals, and if you can get it then check to see if your phone has a update, or a different phone(just to test), then finally the dealer
but i don't have the car, so i can't really test my theories lol
Gentry78 is offline   Reply With Quote
Old 05-25-2009, 09:19 AM   #6
wooav8tor
2G1FC1EV0A9107755
wooav8tor's Avatar
Good input. It's hit or miss. Sometimes an issue sometimes not so it's just a mild annoyance at this stage. I plan on going to Verizon today to get a firmware update as there does appear to be one available for my phone.
Old 05-25-2009, 08:11 PM   #7
Phenix
Drives: 2015 Camaro 1SS/RS 1LE
It's the phone. I had all kinds of issues with bluetooth my LG Voyager from Verizon (the original Voyager, pre-Titanium). Figured the bluetooth on the phone was garbage and I gave up. After the Titanium came out I had Verizon upgrade the software on my phone to match (wanted Rhapsody subscription capability) and found that pretty much all of my bluetooth issues cleared up.
Phenix is offline   Reply With Quote
Old 05-25-2009, 09:35 PM   #8
wooav8tor
2G1FC1EV0A9107755
wooav8tor's Avatar
Yeah--knock on wood--that appears to be the case so far. Like I said it was hit or miss but I definitely needed to update my phone. They said they were upgrading at least two versions and to come back in a few hours. So far so good. Of course, now my vcast tv isn't working so I have to go back and have them fix that. It's always somethin!
Old 05-25-2009, 10:43 PM   #9
etrigan
etrigan's Avatar
Drives: 2010 2SS/RS Black Camaro
Glad to hear it was the phone. Much easier to replace!
So far I have had no trouble at all with the bluetooth connection and have been very happy.
"No matter where you go, there you are."
-B.B.
VIN #2G1FT1EW6A9106795
1100, Preliminary order accepted:10/13/08
6000, Del. to me:5/20/09
etrigan is offline   Reply With Quote
Old 05-25-2009, 11:02 PM   #10
Nexus6
More human than human
Nexus6's Avatar
Drives: 2010 IOM 2SS/RS
i would also look up reviews and such on the headset.There may be a fault in the unit itself.
1100 - 10/22/2008
3000 - 05/27/2009
3300 - 06/06/2009
3800 - 06/29/2009
4B00 - 06/29/2009
Warehouse 13 survivor
Blood stains,speed kills,fast cars,cheap thrills,rich women,fine wine,i lost my sense i lost control i lost my
mind.
Nexus6 is offline   Reply With Quote
Old 06-04-2009, 09:45 PM   #11
Crowley
Okie doke
Crowley's Avatar
Drives: 2012 GT500
I have an iPhone and I am having this same problem .. I'll have to check out some iPhone forums ..
thanks,
Crowley
Crowley is offline   Reply With Quote
Old 06-05-2009, 08:31 AM   #12
Crowley
Okie doke
Crowley's Avatar
Drives: 2012 GT500
Update .. was a firmware issue with the iPhone. I had an older firmware in there because I was jailbroken so I could run my Camaro Lockscreen and some themes. I upgraded to the new firmware and bluetooth works as expected.
Crowley
Old 06-05-2009, 11:54 AM   #13
wooav8tor
2G1FC1EV0A9107755
wooav8tor's Avatar
Crowley
Glad to hear it. Mine too was obviously a firmware issue as well. Since upgrading I haven't had any repeat issues.
Bluetooth trudawg660 Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 62 05-12-2010 03:00 PM
IPOD, Bluetooth, & PITD integration for 2010 Camaro josh1147 Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 64 05-27-2009 11:11 PM
GM Training Video - Bluetooth Pairing josh1147 Camaro Photos | Spyshots | Video | Media Gallery 3 02-14-2009 03:20 AM
How does Cell Service Work with OnStar and Bluetooth? 69er Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 5 01-03-2009 02:31 PM
No Bluetooth or USB in 1LT or 1SS? 1_2Many Camaro Price | Ordering | Tracking | Dealers Discussions 1 10-28-2008 08:46 PM
