Solo Performance
Old 07-31-2012, 06:19 PM   #1
Cody6.2
Drives: 2012 Camaro 2SS
1LE Driveshaft or Intake Differences?
I haven't seen an undercar or hood shot yet so I was just curious if anyone knew if the 1LE had a specific air tube or driveshaft. Back in the day I know they had a few different things so I didn't know if it carried over to the 5th Generation.
Thanks
Cody6.2 is offline   Reply With Quote
Old 07-31-2012, 06:46 PM   #2
United_727
Parts Guru Extraordinair.
United_727's Avatar
Drives: '02 SS 'Vert M6
Only the stub shafts are 1LE specific.
Please check out my other hobby ; http://jetphotos.net/showphotos.php?userid=1008
United_727 is offline   Reply With Quote
Old 07-31-2012, 06:59 PM   #3
Butcher
Drives: '03 MY/MR Z06, '09 Sliver/Red G8 GT
Do you mean half-shafts? If so, they are not 1LE specific, they are the same ones used in the ZL1.
Butcher is offline   Reply With Quote
Old 07-31-2012, 08:09 PM   #4
pouncer72
Drives: 2011 Camaro SS
Send a message via AIM to pouncer72
Wrong. The ZL1 has a competely different differential which requires different length halfshafts.
pouncer72 is offline   Reply With Quote
Old 07-31-2012, 08:16 PM   #5
Butcher
My mistake. The half-shafts were inspired by the ZL1, not the same as.
Old 07-31-2012, 08:26 PM   #6
pouncer72
Correct. The fat center design is the same, as is the larger outer CV, but the ZL1 inner stub is larger then the 1LE stub, and the lengths of the axles are different.
Old 08-01-2012, 07:37 AM   #7
United_727
United_727's Avatar
Dont agrue with the parts man.
Old 08-14-2012, 01:16 PM   #8
caverman
caverman's Avatar
Drives: '69 SS Convertible
Does anyone know if the upgraded 1LE axles will fit an SS?
I hoping to never have to but if I were to ever snap an axle I figure a 1LE axle would be cheaper than the 1400 hp aftermarket axles.
Build Journal
