| Camaro DIY & HOW-TO instructions & discussions All DIY projects & discussions |
Thread Tools |
![]() Drives: 2010 Camaro 2ss Join Date: Apr 2009
How to install LT headers?
Anyone know where to get instructions on how to install 1 7/8" LT headers on a 2ss M6? Can't find anything in google except for mustangs
2010 CGM/Black 2SS M6
20% Tint -:- Hurst 44% Short Throw Shifter -:- Viper 5901 Alarm/Remote start -:- High Gloss Black Painted Calipers + White Brembo Decal |
Is anyone as confused by this as I am? I am of the mindset the LT is a V6 and a 2SS is a V8 so to put headers on a v8 made for a v6 is imossible let alone Insane?!
ss
Drives: all black ss Join Date: Dec 2008
lt is the brand.
HOOK'EM
Drives: 97 c1500/92 olds Join Date: Oct 2008
Lt=long tube headers
NOICE!!! ™
#6 |
![]() Drives: 6 camaros Join Date: Feb 2009
as far as install... usually... just take off the stock manifolds and bolt up the headers, most will require one or two cuts to attach to the stock exhaust, I haven't had a chance to look at my car and see if there are clamps and where.. borrow or rent some time at a lift, save you a lot of hard work.
2010 IOM RS/SS TVS2300, cam, stall, headers
2002 Z28 427 2002 SSLE Convertible 1968 383 Camaro 1968 327 Camaro Convertible 1967 RS 327 1967 Pro-Tour LS3 in progress |
#7 |
![]() Drives: Hyundai Sonata Join Date: Feb 2009
I don't know about these, but on the 4th gen F-bodies it was a lot easier to install the headers from the bottom. Some jack stands and a creeper will make things a lot easier probably.
#8 |
HOOK'EM
yeah on any car you have to go from the bottom there is no way to fit them through the top about the only vehicle you can go from the top is something like a 50-60's truck thats it, there's no other way on any modern car
just slide them through the bottom, bolt up top, might take a few hours but not that difficult just use some wobble extensions and things will go a lot smoother |
#9 |
On a list for a 2014 Z28
![]() Drives: 2010 Camaro 2SS M6 Join Date: Oct 2008
On a 66 nova if you get fender well long tube headers you can put them from the top.
#10 |
Custom User Title
Drives: Fast Join Date: Jan 2009
I've not seen the Camaro's engine bay, but I do know this; even if you have the engine out, it does not make swapping to headers any easier. On top of that, if you're going to LT headers, you're going to need either a new exhaust system, or a few new parts to hook up to the original.
If you have no idea how to install LT's, get a shop to install them and a new system, that has done this before...or you're going to be paying out the ass for them to design one on the spot. Shops I went to around here said that they keep "plans" for each vehicle that they do exhausts for. |
#11 |
I was hoping to keep the stock exhaust piping since I'm just going to use the cutout diverters from another post
#12 |
Any decent exhaust shop should be able to bend new piping to make it fit. If it won't fit there by the tranny, there will probably be enough room somewhere farther back.
#13 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 00 Blazer Join Date: Aug 2008
![]() Takes time for aftermarket to develop. (short answer). |
#14 |
![]() Drives: Pontiac G8 GT Join Date: Jun 2009
#15 |
Petro-sexual
Drives: Ultra-Grin Join Date: Oct 2006
I haven't installed LTs on a 5th Gen but have installed about six sets total on 4th Gens.
I'd say to start with removing the negative battery cable Jack the car up and get it safely on jack stands as high as you can Pull the plug wires and plugs Pull the dipstick Pull the steering shaft Loosen the intermediate pipes, post cats' Remove the cat' pipes Remove the manifolds from under the car Clean the gasket flanges Slide the LTs into position and bolt them in Add the cats' and/or mid-pipes and align to the headers Put everything else back together Test for leaks and get a tune Obviously a little abbreviated but I think one should get the point
"...What IS true: We anticipated that this would happen - we are never finished - and yes, Ford DOES deserve to win now and then. To think that GM can come out with a car to make ford throw in the towel is simply foolhardy..." - fbodfather
#16 |
NEcamaro5
3rd gen shorty headers go through the top. do it all the time. you do have to take youre time if you heat rap them first.
#17 |
The Demon Photographer
If you want to make the trip to VA, I will install them for you for $300. While you wait. You can even watch if you want.
![]() 1SS IOM LS3, GM 4-pack guages, SLP SS Front Emblem, Roto-Fab CAI, Solo Performance Mach X Exhaust, Barton Industries Short Throw Shifter |
#18 |
I put the FU back in FUN
Drives: 1969 SS 396 , 2010 Camaro SS Join Date: Jun 2009
$300 is cheap if you are close and going to pay someone to do it anyways .
#19 |
www.Camaro5store.com
Dude...there is so much room under the engine bay, it's crazy. I should take some pix of my headers on my LS3 just to show you how roomy it is under there.
#20 | |
Petro-sexual
#21 |
![]() ![]() Drives: 2010 IBM SS/RS Join Date: Oct 2008
I 2nd this.
2SS/RS, 6spd manual, IBM w/black leather
Blacked out tail/signal lights, 5% rear tint, 20% sides, Dynomax Bullet exhaust, Barton short throw shifter, Clear Image offroad downpipes |
| Thread Tools | |
| V8 Camaro Performance Upgrades List | Milk 1027 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 79 | 03-04-2013 09:25 AM |
| Headers for the V6? | Xanthos | Camaro V6 LLT Engine, Exhaust, and Bolt-Ons | 49 | 08-04-2011 12:51 PM |
| EXHAUST | Milk 1027 | Wiki | 2 | 03-07-2010 09:20 PM |
| Shorty headers | 1fine79 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 1 | 05-13-2009 09:19 AM |
| Headers Question | SIK07GTSTANG | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 9 | 04-23-2009 07:14 PM |
