SDTW Custom Wheels & Tires
Old 08-01-2012, 04:30 PM   #1
actireman
Drives: 2011 denali hd2500
Has anyone put seats in yet?
Last week I spent the day racing on an open track day and had a blast. The only problem is I also spent the day holding myself in the car. I was wondering if anyone has installed recaro or any other type of seat yet. I talked to my buddys at GM and the floor is completly different from the CTS-v.
actireman is offline   Reply With Quote
Old 08-01-2012, 04:43 PM   #2
Drew10
Enjoys a good train wreck
Drew10's Avatar
Drives: 2010 IBM Camaro 2SS/RS
I was just wondering the same thing. Maybe the seat brackets could be changed from the SS seat to the CTS-V seat. I will be watching this thread for peoples ideas.
Drew10 is offline   Reply With Quote
Old 08-01-2012, 05:31 PM   #3
THR ZL1 #1
Perma Grinning
Drives: 2012 Tom Henry Racing ZL1
What about the air bags? . . . Just asking . .
THR ZL1 #1 is offline   Reply With Quote
Old 08-01-2012, 08:06 PM   #4
69NMYSS
69NMYSS's Avatar
Drives: '69 Camaro SS and '12 ZL1
I would purchase and have the Recaro seats installed from the CTS-V in a heartbeat if it was possible.
69NMYSS is offline   Reply With Quote
Old 08-01-2012, 09:25 PM   #5
DangerZL1
Drives: Accord
It's possible and has been done on an SS. I forgot who did it, but is was really expensive to order all the individual parts and install them. If you do a search it may come up.
DangerZL1 is offline   Reply With Quote
Old 08-02-2012, 01:15 AM   #6
2012ZL1
CaRaHoLiC
2012ZL1's Avatar
Drives: '12 ZL1,67 Cam,68 Biscayne 427 4 sp
I may put in some manual racing seats. Saves a ton of weight also.
2012 ZL1
2.55 upper, 10" lower pullies, Innovators west billet hub and sfi balancer, solid blower drive isolator, 50 mm idler kit, full length S/S headers no cats, comp cams custom grind cam, comp roller rocker trunion kit, comp push rods,dual valve springs retainers and locks, Injector dynamics ID850 inectors, Rotofab ZL1 cold air kit, Lingenfelter 160 thermostat, Rotofab intercooler reservoir, stock plugs, LS7 90mm throttle body, GTO clutch reservoir mod, my own custom catch can, Tuning by Jannetty, install by me.
2012ZL1 is offline   Reply With Quote
Old 08-02-2012, 08:38 AM   #7
actireman
I had the same thought, but the email from my buddy at GM said the floor pans are completly different and won't work. I was hoping maybe GM parts performance would be coming out with seats for the car. I would much rather have some bad#ss seats in my car, than just have some race seats that I fabbed to be in it.
Old 08-02-2012, 09:13 AM   #8
DangerZL1
Drives: Accord
If you do a search you'll find a post that says Hess Motorsports installed the CTS-V recaros in a Camaro and the seat fame was modified to get them to fit. The cost was about $7k, so it is cost prohibitive for most owners. The seats can be changed, but it isn't going to be a straightforward swap with the airbags, etc.
Old 08-02-2012, 12:50 PM   #9
2012ZL1
CaRaHoLiC
2012ZL1's Avatar
Depends what you are after with seats. Comfort and appearance...or...function and performance.
I am leaning towards racing seats for function and performance but the ctsv recaros may be good for comfort and appearance. They are far too heavy for performance use.
2012 ZL1
Old 08-02-2012, 01:00 PM   #10
DangerZL1
Drives: Accord
I'm trying to remember, but I think all the early tests of the ZL1 showed it with fixed back Cobra racing seats installed.
Old 08-02-2012, 02:10 PM   #11
2012ZL1
CaRaHoLiC
2012ZL1's Avatar
ah yes...I think you are right
2012 ZL1
Old 08-02-2012, 03:06 PM   #12
actireman
The problem is, Cobra doesn't list one for the Camaro.
Old 08-02-2012, 04:02 PM   #13
sammyv
sammyv's Avatar
Drives: 2013 red Lingenfelter ZL1
I've come to the conclusion in order to gain enough headroom to wear a helmet i will have to use a racing seat on the drivers side. I will make my own mounts and mount it fixed to the floor. I think I would sit at least 3" lower wich would make the car a lot easier to handle. A local shop told me there are wiring harnesses available to rid of the airbag light. Downside, side airbag gone and more difficult to get in and out. If you have a seat that fits you it's very comfortable once you get seated. I will also mount harnesses at the same time.
sammyv is offline   Reply With Quote
Old 08-02-2012, 09:10 PM   #14
Mr.R
Mr.R's Avatar
Drives: ZL1, Genesis, Grand Cherokee
I spoke with Sparco today and they have a seat bracket for the camaro 2010 which I assume will be the same for the zl1. Then you can pick any seat you want. It gets expensive though: brackets and sliders are 700 for both seats and then a pair of good seats are from 500 to 2000.....I saw a nice one that,s adjustable for 700, so I'll be at 1400+ work if everything fits. I'm not sure if I want to lose the side airbags but at 1g the stock seats are horrible. I have to push with my knee against the door to stay in place. Its ridiculous that there's no optional sport seats for such a high performance car.
http://www.sparcousa.com/product/r505
Mr.R is offline   Reply With Quote
