Old 08-03-2012, 08:55 AM   #15
sammyv
sammyv's Avatar
Drives: 2013 red Lingenfelter ZL1
I also wonder if I remove the factory seat are there sensers mounted in or under the drivers seat?
sammyv is offline   Reply With Quote
Old 08-03-2012, 10:39 AM   #16
actireman
Drives: 2011 denali hd2500
Originally Posted by Mr.R View Post
I spoke with Sparco today and they have a seat bracket for the camaro 2010 which I assume will be the same for the zl1. Then you can pick any seat you want. It gets expensive though: brackets and sliders are 700 for both seats and then a pair of good seats are from 500 to 2000.....I saw a nice one that,s adjustable for 700, so I'll be at 1400+ work if everything fits. I'm not sure if I want to lose the side airbags but at 1g the stock seats are horrible. I have to push with my knee against the door to stay in place. Its ridiculous that there's no optional sport seats for such a high performance car.
http://www.sparcousa.com/product/r505
That's funny, my left knee was rubbed raw by the end of the day. I told a buddy I worked just as hard keeping myself in the car as I did driving.
actireman is offline   Reply With Quote
Old 08-03-2012, 12:57 PM   #17
DangerZL1
Drives: Future ZL1 Owner
When you disconnect the airbags, you'll get an SRS light on the dash. There is a company on the Internet that sells a kit which uses a resister to trick the computer into thinking the airbag is still functional. You also have to make sure the passenger seat weight sensor is still functional.
DangerZL1 is offline   Reply With Quote
Old 08-03-2012, 01:12 PM   #18
pyr0b0y
need....more....hp
pyr0b0y's Avatar
Drives: The Neighbor Hater
I have sparcos in my car, both driver and passenger. My shop Blu808 tabbed up the tracks and brackets. They fit perfectly and do not wiggle at all. I think his price was better than Sparcos. I would try PMing him. They are setup on tracks so I can slide forward and backward. The mounting plate also provides points for installing a 6-point harness.
The airbag light will come on, but you can add a resistor so the system doesn't trip.
I would have went with CTS-V seats, but just waaaaay to expensive!
Mast Motorsports Built LS3 Stroker 418, IPS GT35R Twin Turbos, Exedy GTO4XD Twin Disc Clutch, Aeromotive A1000 Eliminator Stealth Fuel Pump, AEM Meth Injection, DSS 1400hp Axels, BC Coilovers, Pfadt & BMR Suspension, Hawk HPS Pads, Drilled/Slotted Rotors, Hurst Shifter, Custom Roll Cage by Blu808, T3 Ports, 22" Custom Concave Mesh Rims
pyr0b0y is offline   Reply With Quote
Old 08-03-2012, 01:59 PM   #19
Mr.R
Mr.R's Avatar
Drives: ZL1, Genesis, Grand Cherokee
can you post a picture, please?
Mr.R is offline   Reply With Quote
Old 08-03-2012, 02:09 PM   #20
Fesler
Fesler's Avatar
Drives: 1969 Camaro and 2010 Camaro's
We do Recaro in them all the time and let me tell you they are a blast to drive. These are the power Recaro seats in a 2011 Camaro with a matching back seat.
Chris Fesler
Fesler Built
Fesler is offline   Reply With Quote
Old 08-03-2012, 03:22 PM   #21
pyr0b0y
need....more....hp
pyr0b0y's Avatar
Old 08-03-2012, 03:22 PM   #22
pyr0b0y
need....more....hp
pyr0b0y's Avatar
Old 08-03-2012, 09:19 PM   #23
Mr.R
Mr.R's Avatar
Wow! You,re the best. Thanks a lot - they look awesome!
Old 08-04-2012, 09:52 AM   #24
2012ZL1
CaRaHoLiC
2012ZL1's Avatar
Drives: '12 ZL1,67 Cam,68 Biscayne 427 4 sp
I like that sparco set up. It looks LIGHT.
2012 ZL1
2.55 upper, 10" lower pullies, Innovators west billet hub and sfi balancer, solid blower drive isolator, 50 mm idler kit, full length S/S headers no cats, comp cams custom grind cam, comp roller rocker trunion kit, comp push rods,dual valve springs retainers and locks, Injector dynamics ID850 inectors, Rotofab ZL1 cold air kit, Lingenfelter 160 thermostat, Rotofab intercooler reservoir, stock plugs, LS7 90mm throttle body, GTO clutch reservoir mod, my own custom catch can, Tuning by Jannetty, install by me.
2012ZL1 is offline   Reply With Quote
Old 09-19-2012, 05:03 PM   #25
toehead93
Drives: 2014 2SS/1LE
Has anyone tried angel pads for track days?
http://www.camaro5.com/forums/showthread.php?t=344754
Summit White 2014 2SS 1LE
Recaros, NPP exhaust, Nav
2010 2SS A6 - sold.
toehead93 is offline   Reply With Quote
Old 09-20-2012, 12:08 AM   #26
hognutz
hognutz's Avatar
Drives: 2013 ZL1
there is a website called andy auto sport I would email them. they have the power recaro's for like $2700 each. then you would need a bracket for each side. since these are power If the slider assembly comes on them or not.
This is one of those things that people complain about not having the factory option but I have always wondered if people would really pay the 5k just for seats.
I am not going to but for 5-6k I am sure you can have these recaro's in your car.
2017 zl1 or GT350 hmmmm
2015 Hellcat-sold
2013 ZL1 -sold
2013 Dart
2013 Megacab 8" lift 38"mt's
hognutz is offline   Reply With Quote
Old 09-20-2012, 08:15 PM   #27
BIGBLKZL1
BIGBLKZL1's Avatar
Drives: '12 ZL1/M6
What about creating a deeper pocket for your back in the stock seat? Seems like there would be room to cut/reduce the vertical springs that are against your back and allow you to sit deeper in the seat.
BIGBLKZL1 is offline   Reply With Quote
