Nickey Chicago
Suspension / Brakes / Chassis All suspension, brakes and chassis discussions.
Old 08-01-2012, 08:07 PM   #1
Rallyman6
Member
Rallyman6's Avatar
Drives: '10 2SS/RS IOM, Wht Stripes, Roof
Rear end-link keep pulling out of rear swing-arm
I have Eibach sway bars, BC Coil-overs, and stock end-links.
The end-link on the r/r pulled out and broke the tab on the swing-arm. replaced the swing-arm with OEM - 3 weeks later the l/r end-link did the same.
Has anybody made the end-links as a DIY? They are just Heim joints - Hotchkiss wants a lot for in expensive parts.
Any thoughts?
2SS/RS IOM, Wht Stripes, 6MT, IO Interior, Roof, Eibach Sways, BC Coilovers, BMR Swing arms,Barton Short Shift, BBK LT's, GMPP exhaust, Hi-Flow Cats, MAST Stage 2 Cam, CAI = 497RWHP
Rallyman6 is offline   Reply With Quote
Old 08-01-2012, 08:14 PM   #2
Apex Chase
Apex Chase's Avatar
Drives: it like I stole it.
Like this?
It is not the first time it has happened with 2010-2011 control arms. We have reinforcement tabs for that problem.
Apex Chase is offline   Reply With Quote
Old 08-01-2012, 08:23 PM   #3
ICTsccaCamaro
IT.CRNRS
ICTsccaCamaro's Avatar
Drives: 2012 Camaro RS
If your paying good money for control arms just go 2012 FE4-FE5 and don't look back with the new style mounts and links there will be no more little tab to rip off. Just a thought and would require ditching your current rear sway for the new style
2012 Black 2LT/RS
GM strut bar,MRT V2, FE5 ZL1 sway bars, RX can, Brembo swapped, ZL1 Pedals, ZL1 Splash guards, Plastidipped RS wheels, Hot alignment, 4300K LED DRL's, SLP Blackwing, VMax TB, FE6 1LE suspension swap, 20x9's all around
Building a cone eater for Wichita Region SCCA AutoX www.wichitascca.org
ICTsccaCamaro is offline   Reply With Quote
Old 08-01-2012, 08:30 PM   #4
Rallyman6
Member
Rallyman6's Avatar
Originally Posted by Apex Chase View Post
Like this?
do you weld these on?
Old 08-01-2012, 08:57 PM   #5
Apex Chase
Apex Chase's Avatar
No. There are two "teeth" that lock the tab in and then you bolt up the endlink.
Old 08-02-2012, 10:21 AM   #6
BMR Sales
Drives: 2010 Camaro 1SS
We also build some end link reinforcement braces that keep this issue from happening. They are super affordable and easy to install. Here is a quick picture of them.
Kyle Briese - Sales Tech
BMR Suspension
www.bmrsuspension.com
813.986.9302
Like us on Facebook!
Old 09-03-2012, 12:54 PM   #7
L99CAMA2011
L99CAMA2011's Avatar
Drives: 2012 Camaro 1ss LS3 (THE KRAKEN)
Any thoughts?
First of all stock endlinks still . Second thrash the Eibach and get FE4/5 newer setup. No clunking issues and better cornering.
Old 09-04-2012, 09:57 PM   #8
JusticePete
Needs Lowering
JusticePete's Avatar
Drives: Pedders USA Camaro Justice
Old 09-04-2012, 10:00 PM   #9
JusticePete
Needs Lowering
Any thoughts?
The failure rate on the RLCA is very very low. That two have failed within three weeks on your car tells me there is another issue with your car. Can you please post pictures of the endlinks you are using, the washers and nuts? I would also like to see the endlink that has not failed and how it is attached to the arm.
Old 09-04-2012, 10:00 PM   #10
JohnZ
JohnZ's Avatar
Drives: 2010 Camaro 2LT V6
What are you referring to when you say clunking issues? I am curious because I think I might have this problem.
Injen CAI, V-Max Throttle Body, Rx 25mm Iceolator, Rx 10mm Plenum Spacer, Mace Ported Manifold, ARK N-II Catback, Trifecta Tune, Rx Catch Can.
BMR Bushing Inserts,Pedders Radius Rod Inserts, Pfadt Sway Bars and Endlinks, LSR Front Subframe Brace
SS Brembo Brakes, Racing Brake Stainless Lines
JohnZ is offline   Reply With Quote
Old 09-04-2012, 10:09 PM   #11
JusticePete
Needs Lowering
#1 Check the installation.
#2 Check the straps and bushes.
#3 Do the endlink test.
Check the bushes and straps to make certain they are tight.
Make certain they are installed correctly to the MFG's instructions including torque values.
Spherical joints, even those that are supposed to be quiet, will eventually make noise as they wear and loosen. Some are noisier than others. The easiest way to test for a clunk from a spherical or any other type of endlink is to disconnect one endlink stud. Secure the loose endlink and for spherical link tape the remaining joints to quiet them. If the noise goes away you know it is the endlink.
Old 09-04-2012, 11:02 PM   #12
JohnZ
JohnZ's Avatar
Thanks, I will be sure to do that this weekend!
Old 09-06-2012, 06:35 PM   #13
Parabolica
Drives: 2011 2SS
A large, thick washer does the same as those tabs. That's what I've been using with Nyloc Nuts without issue.
My right rear kept coming loose at the bracket, and I had it TIGHT! I think what happens is, if that nut comes loose, it allows the stud to act as a lever on the bracket. If it goes on long enough unnoticed, it'll wear the bracket to a point it'll shear.
Parabolica is offline   Reply With Quote
