Flowmaster Exhaust
Old 08-02-2012, 09:48 AM   #1
kjkjr27
COTW 9/16/13
kjkjr27's Avatar
Drives: 2011 2LT/RS Camaro IOM
Ported TB install help/ something's wrong
Just installed my ported throttle body and when I went to start up my car it sputtered and I got a CEL and a reduced engine power appeared on my DIC. I rechecked everything but idk. Any ideas.
kjkjr27 is offline   Reply With Quote
Old 08-02-2012, 09:51 AM   #2
Agarc
Dr.Frankenstein
Agarc's Avatar
Drives: 15gt
clear the codes
Carandsoulcustoms puntocomm
Agarc is offline   Reply With Quote
Old 08-02-2012, 09:55 AM   #3
67 GTO
13.453 @ 101.90
67 GTO's Avatar
Drives: 2010 Camaro 2LT Rally Yellow
Did you disconnect the battery? If not, try that.
I got a cel with my TB install and disconnected the negative in the trunk for about 15 min. and cel went away.
GMPP exhaust/JBA shorties/Vararam CAI/VMax TB/SLP Pulley/VMax IM isolator/MACE Ported IM +Plenum Spacer/IPF Tuned
67 GTO is offline   Reply With Quote
Old 08-02-2012, 09:55 AM   #4
BaylorCamaro
Track > 1/4 Mile
BaylorCamaro's Avatar
Drives: 2016 C7 Z51
Originally Posted by Agarc View Post
clear the codes
IF you have a way of checking the codes on your lap top or the torq ap I would do that before you clear them so you know what they are, as it would give you an idea what the cause may be.
With that being said, make sure the plug is connected to the TB, those are some really picky connectors. A month ago I took my TB off along with IM to inspect my gaskets and when I put everything back together I got a CEL. Everything looked OK when I inspected it, I unplugged the TB connector clearned it out with MAF cleaner and that fixed it.
BaylorCamaro is offline   Reply With Quote
Old 08-02-2012, 10:02 AM   #5
kjkjr27
COTW 9/16/13
kjkjr27's Avatar
I had the battery disconnected while I was doing the install.
Old 08-02-2012, 10:25 AM   #6
kjkjr27
COTW 9/16/13
kjkjr27's Avatar
I re-installed the stock one and that works fine, but when I install the ported one that's when the problems happen.
Old 08-02-2012, 10:31 AM   #7
Blade
Blade's Avatar
Drives: 2016 Camaro 2SS BVM 2SS
I had this happen over the weekend, here is what I was doing:
I wanted to replace the 4 center bolts on the intake manifold, so I took the whole thing off, which requires unplugging the TB sensor wire. Hell I didn't even disconnect the battery (Yes, I am one of those knuckleheads)
Put it all back together and I was expecting a CEL. Well I got that and the sputtering and the message saying "Reduced engine power" I let it run for another 10-15 secs for it to calm down from the cold start, but it still sputtered, so I turned the car off, waited about 30 secs and started her up again and she came on like nothing had happened.
The CEL stuck around for about 8-10 more miles, the code was for the throttle position sensor being off, no biggie. After the 8-10 miles the CEL went away.
My suggestion, install the ported TB, make sure the sensor wire is plugged back in, start her up, I am sure the CEL and the sputtering will happen. Let her run a bit, about 15-30 secs. Turn her off, start her up again and see if she starts normal. If she does take her for a nice long drive with the wife/girlfriend. By the time you guys come back home, the CEL will probably be gone.
Blade is offline   Reply With Quote
Old 08-02-2012, 10:34 AM   #8
kjkjr27
COTW 9/16/13
kjkjr27's Avatar
Thanks for the advice I'll try that.
Old 08-02-2012, 10:38 AM   #9
kjkjr27
COTW 9/16/13
kjkjr27's Avatar
Well after starting her up and waiting she just shakes like crazy so turned it off and back on and it continues to shake. I just finished leaving the battery disconnected. Could there be something wrong with the tb? Wish I had a way to figure out what the codes are.
Old 08-02-2012, 10:49 AM   #10
nyrfan
Let's go Rangers!
nyrfan's Avatar
Drives: 13' AGM 2SS/RS L99
You may need to relearn the trottle postion, see below (Simple process):
FSP tuned: 377/389
Old 08-02-2012, 10:53 AM   #11
kjkjr27
COTW 9/16/13
kjkjr27's Avatar
Yea but when I install the stock back in the car runs fine.
Old 08-02-2012, 10:56 AM   #12
nyrfan
Let's go Rangers!
nyrfan's Avatar
Correct, the new one may be in a slightly different position.
Also I noticed you painted the TB, were you extra careful with the overspray?
FSP tuned: 377/389
Old 08-02-2012, 11:01 AM   #13
kjkjr27
COTW 9/16/13
kjkjr27's Avatar
I had it sent to Rx for them to paint it.
Old 08-02-2012, 11:03 AM   #14
Monchy36
ZLT!!! COTW (8/5/13)
Monchy36's Avatar
Drives: 2011 IOM 1LT RS M6
If you just got it you can ask VMax to replace it... Maybe FedEx or UPS damage the TB...
My 2 cents...
Monchy36 is offline   Reply With Quote
