| Tuning / Diagnostics -- engine and transmission Tune and diagnostics for engines and auto transmission. |
Thread Tools |
![]() Drives: 2010 camaro pace car, 2008 cts bl, Join Date: Jun 2011
Surge at idle in gear???
I'm having a hard time trying to get my car to idle with out a surge in my auto car. Its not just cam lope but it will start to surge up and down when rolling at around 2 MPH or when backing out of a parking spot. Any ideas of things I can try to fix this. It actually seems to get worse just turning on the AC.
![]() Thanks for any help. cam is 235/242 603/618 114 with 3000 stall
Mods, 2r max cam, ls3 conv,kooks lt w/hf cats,kooks street sleeper cat back with magnaflow res x-pipe, roto fab cai, v-max TB, vigilante 3000 stall, 3.70 LPE, 442hp/392tq, Mike Norris Tune
Former 2011 LSX/SS Owner
Drives: 2014 Jeep Grand Cherokee Join Date: Nov 2010
that's a pretty beefy cam.
are you using HPtuners? e-mail me your tune file.. PM for my e-mail address. Probably some of the spark tables at lower RPM's need to be flattened some.. datalog some? |
I think we found it, if not I will be in touch. Thanks for the response.
![]() Drives: 2010 SS/RS Victory Red Join Date: Jan 2011
Was it the air/fuel cut off for deceleration? Im having the same issue, but its at any speed in neutral.
Big Time Newb
Drives: C63 Join Date: Jun 2012
#6 |
V- max TB
T-BONES BLACK 2SSRS TEAM L99
CAI w/ADM scoop,Magnacharged 3.8 pulley,L92 ported heads,ss valves,patriot springs,yella terra rockers,Comp cam,L99 to LS3 conv.ATI super damper,Taylor plug wires,NGK plugs,ARH 1 7/8 lt headers w/Borla stingers,Elite oil catch can,trans cooler,Jannetty built Richmond 4.11 rear end,Spohn trailing arms,front Racing Brake rotors,Hawk hps pads,BMR end links,AACstyle lighting. Thanks to Shane & crew for engine work at Thunder Racing & tuner Jeoff at EPS. 501rwhp-463rwtq ++ |
#7 |
Big Time Newb
#8 |
My tuner did not like it , had to Put the stock one back on.
#9 |
Big Time Newb
#10 |
It was in the timing at idle. It was taking out alot and putting in alot at idle. It went from negative timing to 40* all at idle. For a more precise answer call Mike Norris Motorsports and I'm sure he will remember my car
#11 |
Thats what I thought also but Im not worried about that now since the maggie max stage II w/102 tb setup is on my to do list now.
#12 |
So your problem has been solved ? Off your topic but could you tell me if you ran 1/4 mile what gear and rpm's you have at the traps w/3.70 gears ?
#13 |
Yes all is good now. 4th gear around 6400 stock diameter tires. Never data logged it to be sure but that is pretty close.
#14 |
Thats perfect , Thanks.
| Thread Tools | |
