Gen5DIY
Suspension / Brakes / Chassis All suspension, brakes and chassis discussions.
Old 08-02-2012, 12:13 PM   #1
FresnoStateDogs
FresnoStateDogs's Avatar
Drives: 2012 2SS/RS LS3
2012 Sway Bars
Did some research and apparently the rear sway bar for the 2012 Camaro SS is completely different from the 10 and 11's. Does anyone make a rear sway bar that fits the 2012? I checked with Eibach and they said everything else is the same except for that rear sway bar. They expect the rear sway bar to come out in September.
Spiral Ported TB, K&N Typhoon, JBA Performance Cat-back, RX catch can and Oil Breather.
FresnoStateDogs is offline   Reply With Quote
Old 08-02-2012, 12:26 PM   #2
ICTsccaCamaro
IT.CRNRS
ICTsccaCamaro's Avatar
Drives: 2012 Camaro RS
I beleive Phadt has some out and pedders just look up the the sites but im sure they will chime in soon for confermation just look for FE4 FE5 specific bars. Im persanaly running 2012 ZL1 front and rear sway bars on mine as we speak
2012 Black 2LT/RS
GM strut bar,MRT V2, FE5 ZL1 sway bars, RX can, Brembo swapped, ZL1 Pedals, ZL1 Splash guards, Plastidipped RS wheels, Hot alignment, 4300K LED DRL's, SLP Blackwing, VMax TB, FE6 1LE suspension swap, 20x9's all around
Building a cone eater for Wichita Region SCCA AutoX www.wichitascca.org
ICTsccaCamaro is online now   Reply With Quote
Old 08-02-2012, 01:56 PM   #3
Scott@Bjorn3D
Scott@Bjorn3D's Avatar
PEDDERS There is nothing better.
Scott@Bjorn3D is offline   Reply With Quote
Old 08-02-2012, 02:36 PM   #4
VR Baron
SoCal Camaro5 Race Team
VR Baron's Avatar
Drives: 2012 VR 2SS RS M6
Can get 1le sways now or soon I would think also. 27mm front/28 rear
#1 car 2010 Black 2LTRS 1/28/10-10/15/11, 17900 miles
#2 car 2012 Red 2SSRS 10/15/11- way in the future
Mods: Outlaw Axelback & J Pipes/Heritage&Stillen Grill/SLP Fade Gills/Rear Blackout Panel/Halltech CAI/Apex Scoop,Washer Bottle/OEM Strut Tower Brace/VMax T/B/ G.M. Blade Spoiler/Retro 69 SS emblems/Pfadt ZL1 Sways & End links/Hotchkis springs/SLP Splitter/TSW Nurburgring wheels
VR Baron is offline   Reply With Quote
Old 08-02-2012, 02:52 PM   #5
FresnoStateDogs
I've only found their website. ~$700 for sway bars? GTFO
Old 08-02-2012, 02:53 PM   #6
FresnoStateDogs
GM parts are usually way overpriced. Any idea what they cost?
Old 08-02-2012, 03:36 PM   #7
patroklai
Enthusiast
Drives: Camaro SS | e92 M3
I have LG sway bars on my 2012 and they worked fine. They installed different than the OEM and certainly had a different shape but fit in regardless.
Hope this helps.
patroklai is offline   Reply With Quote
Old 08-02-2012, 05:21 PM   #8
FresnoStateDogs
Hope this helps.
Did you force them in or do they have a natural fit?
Old 08-02-2012, 07:35 PM   #9
patroklai
Enthusiast
I disconnected one of my mufflers... I have flow master axle back so it was pretty easy. Once it's out the bar will slide in from that side.
The end links work too... but they are way different than the OEM on the 2012.
Old 08-02-2012, 07:39 PM   #10
ICTsccaCamaro
IT.CRNRS
Im in both my front and rear ZL1 sway bars and end links for just over 300 not to bad compared to aftermarket I think
2012 Black 2LT/RS
Old 08-07-2012, 05:09 PM   #11
stt816
stt816's Avatar
Drives: 2012 Black 2SS/RS M6
what would you say is better for a 2012 ss... zl1 sways vs aftermarket say pfadt for example
stt816 is offline   Reply With Quote
Old 08-07-2012, 05:52 PM   #12
PfadtRacing
PfadtRacing's Avatar
Drives: 2010 Camaro, 2006 Z06
We should be finishing up the build process on our 2012 specific sway bar package VERY soon. As soon as they are available we will be sure to let everyone know.
After done testing with our bars on our 2012 ZL1 we can tell you that there is a definite advantage in running our 2012 bar package vs. the OEM options. Hang in there just a little bit longer and we will have a fully adjustable front and rear sway bar solution for your 2012 that will work more effectively than any of our other previous bar packages for the Camaro.
Just so you know, bars designed for 2010 cars will work on your 2012 car. It will require purchasing rear endlinks, but the fronts will work perfectly and the rear bars will bolt up just fine so long as you purchase the correct endlinks. That being said, our 2012 bar package is so close to being ready to go that if you hold out a little longer you will end up rewarded with the best performance available.
Old 08-07-2012, 06:50 PM   #13
Jimmy Superfly
Jimmy Superfly's Avatar
Drives: 2012 IBM 1SS L99/A6
I can't waint to get a set of these!!
Will they be available in a street package with lowering springs like your current bars?
2012 IBM 1SS L99/A6 -VMAX TB, CAI inc w/ Apex scoop, RX Catchcan, Pfadt Stage 2 FE4/ZL1 kit (springs and adjustable sways), Stainless steel brake lines
Jimmy Superfly is offline   Reply With Quote
Old 08-09-2012, 10:23 AM   #14
mntgome1
mntgome1's Avatar
Drives: 2012 AGM 2SS/RS
I have had my Eibach Pro-Plus installed since February. That includes Lowering springs and Anti-roll sways (Front and Rear) Here is the link. I ordered mine through the dealership I purchased Ashley from.
http://performance-suspension.eibach...ookup_products
mntgome1 is offline   Reply With Quote
Old 08-09-2012, 11:18 AM   #15
Rob@WretchedMS
Evil Pedders Guy Since 06
Rob@WretchedMS's Avatar
Drives: His Wife Crazy Phone:860-880-0486
Pedders will not sell sway bars with out selling the sway bar links along with it, since the stock links are not strong enough for our bars.
So the $700 price tag is for the front sway bar with both adjustable end links,
The rear ZL1 style bar with HD Links (available in two sizes based on the amount of drop you have)
Other manufacturers don't sell them as a package, or as a requirement, their reasons may vary
Rob@WretchedMS is online now   Reply With Quote
Old 08-09-2012, 12:03 PM   #16
PfadtRacing
Stay tuned! More info is coming in the next couple days. We are hoping to have these available by early next week.
To actually answer your question though, they will be available in a package that includes the drop springs at a discount.
Old 08-09-2012, 01:09 PM   #17
toehead93
Drives: 2010 SS, 1993 Z28
This is true, I priced everything needed to swap my 2010 to 2012 ZL1 sway bars, LCAs, and endlinks. It came out to a little over $400. I haven't pulled the trigger yet but great deal.
2SS A6 Black
360 RWHP/382 FTLBS - tune only
Mods on: Dynatech LTs, Vararam Intake, Pedders Xa's, DiabloSport tuned
toehead93 is offline   Reply With Quote
Old 08-09-2012, 01:20 PM   #18
ICTsccaCamaro
IT.CRNRS
Very true I already had the 2012 rear control arms so cost was lower and with both front and rear zl1 bars on the car even on the road it is noticibly flater and feels so much more sure footed in the turns very excited for this sundays autocross to see how the car balances out, compared to last event we just ran the rear zl1 bar to compare how just rear vs. front and rear would feel.
2012 Black 2LT/RS
Old 08-09-2012, 01:31 PM   #19
Rob@WretchedMS
We sell our 32mm ZL1 rear bar with links for just about the same price, i can't post links or pricing on here though
Old 08-09-2012, 04:47 PM   #20
Apex Chase
Apex Chase's Avatar
Drives: it like I stole it.
I had a chance to check out the new Pfadt sway bars out this past weekend and they are awesome. The new Quick Switch bar ends are just another example of the engineering expertise that separates Pfadt from others.
Apex Chase is online now   Reply With Quote
Old 08-09-2012, 10:23 PM   #21
stt816
stt816's Avatar
can't wait for these pfadt sways to come out
Old 08-10-2012, 05:21 AM   #22
Apex Chase
Apex Chase's Avatar
You won't have to wait much longer. Any day now.
Old 08-10-2012, 09:48 AM   #23
grocerygetter
grocerygetter's Avatar
Drives: 2010 SS (2ss/rs, auto, SW/IOstripe)
yeah...that pfadt endlink thing is sweet. saw that at fest.
-John S.
2010 Camaro 2ss/rs-a few cosmetic things, Pfadt stage 2 plus rear arm package, LG chassis brace, Vortech, ADM fpcm/ZL1 pump, Lingenfelter 3.70 gears, JBA catless, ProTorque 3200, 18" TSW N'rings for drag duty, 20" Forgestar F14s for street.
Thanks to: Jannetty Racing, dv8motoring, Gwatney Chevrolet/GPI Jacksonville AR, TCAudio in Benton AR
2012 4Runner -daily driver
Old 08-15-2012, 03:08 PM   #24
Brandon@LSRPerformance
Drives: N/A
We have designed, engineered, and manufactured a new rear swaybar for the 2012s:
This LSR performance adjustable rear swaybar was made specifically for the 2012+ Camaro with the FE4 and FE5 suspensions found on most SS, 1LE, and ZL1 models.
The factory rear swaybar on models equipped with this option are re-designed and our original rear swaybars do not fit this application.
This new swaybar fits FE4 and FE5 suspension models and is an upgrade for even further improved performance. CNC bent from tubular 1-1/8 inch DOM steel and then TIG welded with billet steel ends. Each end provides three adjustment positions for fine tuning. Each position provides a 10 percent increase in stiffness, with a minimum stiffness increase of 25 percent.
In addition we've also included greaseable, adjustable endlinks with heavy duty 12mm ball joints at each end to replace the rubber bushing endlink design found on the factory swaybar and other competitors swaybars. This eliminates compliant soft rubber in the factory endlinks allowing them to work more effectively, without adding any NVH (noise, vibration, and harshness).
Outstanding upgrade for street and track use.
Product Benefits
  • 3-position adjustability for fine tuning of handling balance
  • Double adjustable heavy-duty ball joint-style endlinks
  • Lightweight thin wall DOM CNC bent tubular steel construction
Please let me know if I can help you with this.
Brandon@LSRPerformance is offline   Reply With Quote
Old 08-16-2012, 03:16 PM   #25
JusticePete
Needs Lowering
JusticePete's Avatar
Drives: Pedders USA Camaro Justice
FYI -- The ONLY srear bar that will fit with Supercar Coilovers is the Pedders Z style rear bar. We have had this bar on the market long enough to have sold through pallets of them. Some of our clients found that the drag wheels they run did not fit with the OE or Pedders Z style bar. based on that client input we have revised our rear Z bar to accommodate 11.5" rear wheels and the Vee / Drag Radial package so many run.
Does Pedders work on the drag strip? The three fastest IRS Camaros at C5FEST were all on Pedders Supercar or Lingenfelter by Pedders Drag Coilovers.
Does Pedders work on a road course or autocross?
Pardon the tach. I set the data logger incorrectly.
Street and track tested
