Old 08-09-2012, 12:18 PM   #15
Rob@WretchedMS
Drives: His Wife Crazy
Originally Posted by FresnoStateDogs View Post
I've only found their website. ~$700 for sway bars? GTFO
Pedders will not sell sway bars with out selling the sway bar links along with it, since the stock links are not strong enough for our bars.
So the $700 price tag is for the front sway bar with both adjustable end links,
The rear ZL1 style bar with HD Links (available in two sizes based on the amount of drop you have)
Other manufacturers don't sell them as a package, or as a requirement, their reasons may vary
Rob@WretchedMS is offline   Reply With Quote
Old 08-09-2012, 01:03 PM   #16
PfadtRacing
PfadtRacing's Avatar
Drives: 2010 Camaro, 2006 Z06
Originally Posted by Jimmy Superfly View Post
I can't waint to get a set of these!!
Will they be available in a street package with lowering springs like your current bars?
Stay tuned! More info is coming in the next couple days. We are hoping to have these available by early next week.
To actually answer your question though, they will be available in a package that includes the drop springs at a discount.
Old 08-09-2012, 02:09 PM   #17
toehead93
Drives: 2014 2SS/1LE
Originally Posted by ICTsccaCamaro View Post
Im in both my front and rear ZL1 sway bars and end links for just over 300 not to bad compared to aftermarket I think
This is true, I priced everything needed to swap my 2010 to 2012 ZL1 sway bars, LCAs, and endlinks. It came out to a little over $400. I haven't pulled the trigger yet but great deal.
http://www.camaro5.com/forums/showthread.php?t=344754
Summit White 2014 2SS 1LE
Recaros, NPP exhaust, Nav
2010 2SS A6 - sold.
toehead93 is offline   Reply With Quote
Old 08-09-2012, 02:20 PM   #18
ICTsccaCamaro
ITCRNRS
ICTsccaCamaro's Avatar
Drives: 2018 ZL1 1LE
Very true I already had the 2012 rear control arms so cost was lower and with both front and rear zl1 bars on the car even on the road it is noticibly flater and feels so much more sure footed in the turns very excited for this sundays autocross to see how the car balances out, compared to last event we just ran the rear zl1 bar to compare how just rear vs. front and rear would feel.
2018 ZL1 1LE Ordered 6/29/17 Built 11/6/17 Delivered 12/7/17, Summit White, PDR, NAV
SOLD: 2014 Summit White 1LE 2SS/RS, Recaros, NPP, NAV, KONI Yellow's, Exhaust Commander, GTO Clutch reservoir, Forgestar CF5V 19's
SOLD: 2012 Black 2LT/RS, Fully 1LE swapped, Wichita Region SCCA #98
ICTsccaCamaro is offline   Reply With Quote
Old 08-09-2012, 02:31 PM   #19
Rob@WretchedMS
We sell our 32mm ZL1 rear bar with links for just about the same price, i can't post links or pricing on here though
Old 08-09-2012, 05:47 PM   #20
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
Originally Posted by PfadtRacing View Post
We should be finishing up the build process on our 2012 specific sway bar package VERY soon.
I had a chance to check out the new Pfadt sway bars out this past weekend and they are awesome. The new Quick Switch bar ends are just another example of the engineering expertise that separates Pfadt from others.
Old 08-09-2012, 11:23 PM   #21
stt816
Drives: 2012 Black 2SS/RS M6
can't wait for these pfadt sways to come out
Pfadt Race Engineering 1.25" Lowering Springs| Pfadt Spec Performance Street Alignment|ZL1 Front Bumper Conversion|Factory Reproductions Type 41 Satin 20x9 Rims|Pirelli P Zero All Season Plus 275/40R20Y Square Setup|3M 1080 Matte Black Vinyl Wrapped Hood|Footwell Lighting|G2 Gold Painted Brake Calipers
Stainless Power Long Tube Headers|Cold Air Inductions Cold Air Intake|VMAX CNC Spiral Ported Throttle Body|Stainless Works Retro Chambered Catback
--Jannetty Racing Enterprises Dyno Tuned|408 RWHP
stt816 is offline   Reply With Quote
Old 08-10-2012, 06:21 AM   #22
Apex Motorsports
You won't have to wait much longer. Any day now.
Old 08-10-2012, 10:48 AM   #23
grocerygetter
instigator
grocerygetter's Avatar
yeah...that pfadt endlink thing is sweet. saw that at fest.
-John S.
Thanks to:
Tony@ dv8motoring
TCAudio in Benton AR
Old 08-15-2012, 04:08 PM   #24
Brandon@LSRPerformance
Drives: N/A
Did some research and apparently the rear sway bar for the 2012 Camaro SS is completely different from the 10 and 11's. Does anyone make a rear sway bar that fits the 2012? I checked with Eibach and they said everything else is the same except for that rear sway bar. They expect the rear sway bar to come out in September.
We have designed, engineered, and manufactured a new rear swaybar for the 2012s:
This LSR performance adjustable rear swaybar was made specifically for the 2012+ Camaro with the FE4 and FE5 suspensions found on most SS, 1LE, and ZL1 models.
The factory rear swaybar on models equipped with this option are re-designed and our original rear swaybars do not fit this application.
This new swaybar fits FE4 and FE5 suspension models and is an upgrade for even further improved performance. CNC bent from tubular 1-1/8 inch DOM steel and then TIG welded with billet steel ends. Each end provides three adjustment positions for fine tuning. Each position provides a 10 percent increase in stiffness, with a minimum stiffness increase of 25 percent.
In addition we've also included greaseable, adjustable endlinks with heavy duty 12mm ball joints at each end to replace the rubber bushing endlink design found on the factory swaybar and other competitors swaybars. This eliminates compliant soft rubber in the factory endlinks allowing them to work more effectively, without adding any NVH (noise, vibration, and harshness).
Outstanding upgrade for street and track use.
Product Benefits
  • 3-position adjustability for fine tuning of handling balance
  • Double adjustable heavy-duty ball joint-style endlinks
  • Lightweight thin wall DOM CNC bent tubular steel construction
Please let me know if I can help you with this.
Brandon@LSRPerformance is offline   Reply With Quote
Old 08-16-2012, 04:16 PM   #25
JusticePete
VIR Specialist
JusticePete's Avatar
Drives: Camaro Justice
FYI -- The ONLY srear bar that will fit with Supercar Coilovers is the Pedders Z style rear bar. We have had this bar on the market long enough to have sold through pallets of them. Some of our clients found that the drag wheels they run did not fit with the OE or Pedders Z style bar. based on that client input we have revised our rear Z bar to accommodate 11.5" rear wheels and the Vee / Drag Radial package so many run.
Does Pedders work on the drag strip? The three fastest IRS Camaros at C5FEST were all on Pedders Supercar or Lingenfelter by Pedders Drag Coilovers.
Does Pedders work on a road course or autocross?
Pardon the tach. I set the data logger incorrectly.
Street and track tested
Old 08-16-2012, 04:50 PM   #26
JDP Motorsports
JDP Motorsports's Avatar
Drives: 2011 Camaro SS/ 2016 Camaro SS
There are a few options available at this time. Pedders has had their packages available for a few months and the Pfadt package HERE was just released. If you've already got a 2012 Camaro SS I would suggest sticking with the FE4/5 design. It is superior in every way.
Please feel free to call, email or PM me anytime with questions. We're happy to help you find the best solution for your specific needs and budget.
Kind regards,
Jordan Priestley
888.308.6007
JDP Motorsports is offline   Reply With Quote
Old 08-16-2012, 05:24 PM   #27
PfadtRacing
We have actually just released our 2012+ sway bar package! If you haven't already seen the thread you can get some more info on the entire package here:
Pfadt Race Engineering Releases 2012+ Specific Sway bars. Available Now!
Key Features of our ZL Spec Sway bar package include:
  • Adjustable Front AND Rear bar included in every package
  • Revised front and rear sway bar rates for improved balance
  • Designed to use your factory 2012+ rear endlinks. Front endlinks will be required for non ZL1 models
  • Upgrade Packages now available for 2010-2011 cars
You can get the rest of the details in our thread!
Old 08-16-2012, 07:57 PM   #28
Chainsaw6
Drives: Black/Black 2SS-RS
So now the question is: pedders or pfadt for a 2012 ss or zl1?
Chainsaw6 is offline   Reply With Quote
