BORLA
Old 08-02-2012, 04:21 PM   #1
PalmerGA
PalmerGA's Avatar
Drives: 2013 SIM 1SS/RS L99
The "Dead Spot"
Does anyone know how we (LFX Camaro owners) might be able to convince GM they need to address the "dead spot" issue in our cars? I mean, that just isn't right. And seeing how the new TBs being touted here seem to fix the problem, GM should hold some responsibility for selling cars with faulty throttle bodies.
Any suggestions on how to get the ball rolling on something like this?
2013 1SS/RS Coupe L99, Stainless Power Works LT Headers, SCT X4 Custom Tune from RDP, CAI Inc. Air Intake w/ Apex Scoop, VMAX CNC Ported Throttle Body, Solo Axle-Back Exhaust w/ J-pipes, Apex Catch Can, Husky Splash Guards, Heritage Grille, 3D Carbon Rear Spoiler, Oracle Chrome Turn Signal Bulbs, GM Reverse Light Trim Billets, Gorilla Black Locking Lugs, Emblem Pros Retro SS Badges/Custom Retro SS Kickplates/Under-hood Bowtie, 35% window Tint
PalmerGA is offline   Reply With Quote
Old 08-02-2012, 06:02 PM   #2
SC2150
Never happen.
GM had the best design TB in the LS2, and then dropped it for the LS3/L99 version with deeper dips and peaks and made no sense.
The LS2 VMax CNC ported makes more gains then the LS3/L99 but they are not compatable to swap.
I think many confuse the "best design" with the marketing demographics, the budget and cost caps, and what most owners will never complain about or even realize that really dictate how well anything is designed.
Always has been this way, and probably always will. Look at the oil ingestion issues.....since 1997 when GM released the first LS motor there have been issues and very little done as far as changes to really deal with it.
99% have no idea what it does over time in their engine so why engineer it better when a fraction complain?
At least the fix is inexpensive for those not happy w/it.
Old 08-02-2012, 07:36 PM   #3
PalmerGA
PalmerGA's Avatar
Originally Posted by SC2150 View Post
Never happen.
I understand, but when you build a car that's made for cruisin' and jumping on the gas at lights, etc., it seems a dead spot in your lower power range is a rather bad advertisement. People have noticed (as is evident on this forum) and frankly, word of mouth about this and other problems experienced with the LFX is going to cost them (GM). If it's a know problem - they should fix it.
Fortunately... you guys are here to kiss it and make it better.
Old 08-02-2012, 10:17 PM   #4
awfarley
awfarley's Avatar
Drives: 2011 5.7L Tundra Double-Cab X-SP
I've read all about the dreaded dead spot, but I've honestly never had any issue with mine. Maybe once I get a cold air intake I'll feel a difference, but for now my Camaro is the only one I've ever driven so I have never known anything different.
awfarley is offline   Reply With Quote
Old 08-03-2012, 12:02 AM   #5
JohnnyBfromPeoria
JohnnyBfromPeoria's Avatar
Drives: 2012 LS M6, Black
It's pretty apparent with a manual. Try to pass someone in a high gear on the superslab and there's nothing there. Looking to wake up some low end that I know is there in this engine. My ported TB will be here on 8/8/12, so I will post back to let everyone know if it helps and where to get one.
John B.
12 LS M6, IPF S/C, ASA GT-5 wheels, VMax PTB
1995 Mitsubishi Montero SR
1987 Dodge Raider Turbo Project
1986 Mitsubishi Montero 2.4l FI Transplant
JohnnyBfromPeoria is offline   Reply With Quote
Old 08-03-2012, 08:54 AM   #6
malave7567
malave7567's Avatar
Drives: 2015 Camaro 1SS
John B.
I just removed my CAI and tune, and I forgot how bad that issue was. Highway went from 75 to 55 then back to 75. When I tried to get back up to 75, no juice in 6th anymore, felt like it was lugging and downshifted to 5th. This is my morning and afternoon commute for work and I usually just cruise along in 6th the whole way on the highway. Forgot how much CAI and tune really wake the low end up.
malave7567 is offline   Reply With Quote
Old 08-03-2012, 01:39 PM   #7
PalmerGA
PalmerGA's Avatar
Yeah - I could see it being much more of an issue with the M6 than with the A6, but still... it is a known problem with the V6s and GM should own up to it.
Old 08-03-2012, 11:45 PM   #8
Henry G.
Drives: 2012 Camaro LFX,CAI,DynomaxVT,RX CC
I still havent found this "dead" spot. The dyno doesn't show a dead spot. Can anyone describe this dead spot and at what rpm it occurs? I floor my car it goes faster and faster linear until 4k then it shoots up sharply...
Henry G. is offline   Reply With Quote
Old 08-04-2012, 12:07 AM   #9
meissen
Founder - Michigan FBody
meissen's Avatar
Drives: 1994 Camaro LT1, 2016 Camaro LT
Take off from a dead stop and you'll notice it accelerates decently from a stop, then you hit about 2500rpms and the RPMs climb much more rapidly. That sub 2500 rpm range is the dead spot.
My ported TB will also arrive on 8/8. Can't wait to give feedback.
2016 Camaro 1LT V6 A8 - "Elmo" - LGX V6 with 8-Speed Automatic, NPP Dual Mode Exhaust
1994 Camaro LT1 A4 - "Red Alert" - v6-to-LT1 Swapped Cruiser; Cammed, Stalled, Enjoyed
"Gone But Not Forgotten"
2014 Camaro 1LT M6 - "Cherry Bomb"
2012 Camaro 1LS M6 - "Clifford"
Michigan FBody Association
http://www.mifbody.com/
meissen is offline   Reply With Quote
Old 08-04-2012, 07:51 AM   #10
ecko04
Drives: Too many to list
Your logic is seriously flawed. The vast majority of people don't notice and those that do, and aren't searching for a cause/remedy online, will go to the dealer. The dealer will search for a TSB and there will be none. Customer will be told everything works within "specs" and that'll be the end.
If there isn't a mass influx, as in thousands, of vehicles heading back into the stealership for the same issue, with the same explanation and the dealer actually acknowledging the issue and submitting it to GM...it won't even be looked at. In fact, it is more costly to try to rectify these problems with, say a new TB, post-production from GM than it would be to let it skirt under the rug. This is why most recalls and TSB deal with safety issues more so than anything else. A dead spot in the lower RPM range will get a *shrug*.
In the end, it won't cost GM a thing. Camaro5 is in no way, shape, form or fashion representative of total 5th Gen LFX Camaro ownership.
In My Garage
'12 Volkswagen Jetta SE
'12 Chevrolet Camaro
'11 Harley Fat Bob
'11 Honda Accord Coupe EX-L
'05 Mercedes E500 W211
'01 BMW 328xi
'89 Chevrolet Suburban
ecko04 is offline   Reply With Quote
Old 08-04-2012, 01:48 PM   #11
PalmerGA
PalmerGA's Avatar
You're correct. My logic is based on the desire to provide outstanding customer service, which is sorely lacking in most businesses today. If someone is experiencing the dead spot they should be able to bring it to the dealership, show them that it is occurring, and have the throttle body replaced at no charge. Very simple - customer satisfaction.
I know it won't happen and I understand why... for the reasons you mentioned.
Old 08-04-2012, 02:43 PM   #12
SC2150
People on the forums seem to be far more "connected" to their car and they notice things 99% dont. Just lke the gunk buildup on the valves. It occurs gradually so 99% dont notice the drop in performance and fuel economy. If the dealer tells them "everything is fine" they put it out of mind.
Most people buy a vehicle to get from point a-point b and only service it when the DIC tells them to. Never even open the hood to check oil, etc.
On these forums, we are the 1%ers.....(not all, as you can see the debates all the time "if it needed it, GM would have done it" etc.) we want the best and expect the best.
Old 08-04-2012, 02:48 PM   #13
meissen
meissen's Avatar
Heck even people on the forum don't know where the dead spot is...
Old 08-04-2012, 08:33 PM   #14
camtx45
camtx45's Avatar
Drives: 2012 2LT/RS 45th Vert
I do.... right between the ears of a Mustang owner.
camtx45 is offline   Reply With Quote
