JUICEDMOTORSPORTS
Old 08-03-2012, 02:07 PM   #1
C-redfly
C-redfly's Avatar
Drives: 2013 VR vert ZL1
Anyone know why richmond doesn't make 3.73's for our A6 LFX
C-redfly is offline   Reply With Quote
Old 08-04-2012, 07:21 AM   #2
etmx183
etmx183's Avatar
Drives: 2012 Camaro 2LT RS
Because GM made our differential different from all the others and the market is not big enough to warrant the cost to make them yet. 3.73 without a posi is just more torque to burn one tire with.
Originally Posted by C-redfly View Post
etmx183 is offline   Reply With Quote
Old 08-04-2012, 01:57 PM   #3
C-redfly
C-redfly's Avatar
Thxs. It makes sense. I woulda thought they would make 3.73's instead of the 3.55's they made available
Old 08-04-2012, 02:19 PM   #4
C-redfly
C-redfly's Avatar
A posi trac unit would be sweet if one was available. I would do some LPE 3.91's with it. It would be fast enough for me.
Old 08-04-2012, 05:17 PM   #5
etmx183
etmx183's Avatar
Once you start, it is hard to stop going fast. It seems fast for a while than you get used to it and you look for more.
Old 08-04-2012, 05:36 PM   #6
C-redfly
C-redfly's Avatar
Yea I could imagine.
Old 08-04-2012, 05:52 PM   #7
POWERFREAK
I.AM.
POWERFREAK's Avatar
Drives: 2010 2SS/RS/M6
You could swap in a diff from an M6 car...it's been done.
NY5thgen.com
POWERFREAK is offline   Reply With Quote
Old 08-04-2012, 10:23 PM   #8
C-redfly
C-redfly's Avatar
Yea that's my plan. You got a idea about how much ill be spending on that, with the LPE 3.91's?
Old 08-05-2012, 04:37 AM   #9
lscamaro
lscamaro's Avatar
Drives: 2011 CGM Camaro LS A6
You'd spend like 2000 in parts for just the stuff needed for the swap. Add on top of that how much for the 3.91s and then labor and there you go. Member Asanti has a thread on how he did it by himself and what parts he had to get
Old 08-05-2012, 07:22 AM   #10
POWERFREAK
I.AM.
POWERFREAK's Avatar
I've seen used diffs go for under $500...just keep an eye out. You'll also need axles and hubs which dont cost that much. I have axles i'lll sell ya cheap. Not sure which driveshaft you have to use, but i can send you one of those too. I wont spend $2000 + the cost of the gear swap...unless you buy everything from a dealer.
NY5thgen.com
Old 08-05-2012, 02:35 PM   #11
C-redfly
C-redfly's Avatar
Ok Thxs. So I need the SS or m6 axles right?
