ADM PERFORMANCE
Old 08-04-2012, 09:09 AM   #1
2012ZL1
CaRaHoLiC
2012ZL1's Avatar
Drives: '12 ZL1,67 Cam,68 Biscayne 427 4 sp
de-winging the ZL-1 heads
Hi Guys,
Has anyone done any porting/de-winging ports for better flow?
All the aftermarket heads that I know of do not have a wing, so does removing the wing cause a problem on these heads or is it ok for modding for more power?
Any experience/input appreciated. Pics are welcome too if ya got them!!
Mark
2012 ZL1
2.55 upper, 10" lower pullies, Innovators west billet hub and sfi balancer, solid blower drive isolator, 50 mm idler kit, full length S/S headers no cats, comp cams stage 3 cam, comp roller rocker trunion kit, comp push rods,dual valve springs retainers and locks, Injector dynamics ID850 inectors, Rotofab ZL1 cold air kit, Lingenfelter 160 thermostat, Rotofab intercooler reservoir, stock plugs, LS7 90mm throttle body, GTO clutch reservoir mod, Tuning by Jannetty, install by me.
2012ZL1 is offline   Reply With Quote
Old 08-04-2012, 11:09 AM   #2
ADM PERFORMANCE
214-228-8782
Drives: 2013 ZL1 #138
Originally Posted by 2012ZL1 View Post
Hi Guys,
Mark
It is there for a reason.
Andy Mages
Owner/Operator
214-228-8782
admperformance@gmail.com
www.admperformance.com
ADM PERFORMANCE is offline   Reply With Quote
Old 08-04-2012, 11:16 AM   #3
1st Gen Forever
ZL1 #140
1st Gen Forever's Avatar
Drives: Camaros: 68 SS, 10 2SS/RS, 12 ZL1
And it seems next to impossible to find any good data on what that reason is, other than GM sales propaganda...
Better atomization of air/fuel? Ok, then why do I get 16MPG?
1st Gen Forever is offline   Reply With Quote
Old 08-04-2012, 11:22 AM   #4
JLE58
Drives: CGM,twin turbo, cam 2010 SS/RS
There has been A lot of people port them out. Talk to Richard at west coast cylinder head he has them ported in stock and will tell you all you need to know about them.
JLE58 is offline   Reply With Quote
Old 08-04-2012, 11:25 AM   #5
ADM PERFORMANCE
214-228-8782
LMAO
That is not the reason!
Andy Mages
Owner/Operator
214-228-8782
Old 08-04-2012, 11:32 AM   #6
1st Gen Forever
ZL1 #140
Oh wait. I know the reason! It's there so you know when you're done with your port work. Once it's ground away, you're done!
Old 08-04-2012, 05:35 PM   #7
2012ZL1
CaRaHoLiC
2012ZL1's Avatar
Why all the cloak and dagger Andy? Whats the reason then? speak up!
2012 ZL1
Old 08-05-2012, 11:46 AM   #8
2012ZL1
CaRaHoLiC
2012ZL1's Avatar
(IMHO) The only reason I see to keep them is that a hemisphrical reverse dome piston needs help promoting full combustion as a result of inadequate quench.
There is no quench pad on the piston, so the wing helps create turbulence in a "non turbulent" environment for proper homogenization of the fuel/air mixture.
If this is the case it is not wise to remove it,and port flow must be improved in other areas. Minor smoothing or blending of the wing is probably o.k., but the leading edge should be kept prominent.
Replacement pistons with a quench pad could be used with wing removal.
The theoretical reason for non quench pistons in a supercharged environment is to remove detonation or hot spots which can happen on the piston.
In hyperutectic pistons, a hot spot is what causes failure from what I've read. Idealy, a hemisperical combustion chamber would be perfect, but since the engine design does not allow this, the next best thing is a reverse hemisphere piston.
Now the lack of turbulence from the piston needs help, and help is in the form of the wing. The wing keeps the "turbulence generator" out of the actual combustion chamber, which should lessen the chance of hot spots, and let the piston live, and allow more timing etc.
This effect only happens on after supercharger fuel injected engines, because in traditional carburated roots set ups the fuel comes in pre- blower so the blower does all the homoganization of the mixture.
In supercharged engines that fuel is added "after" the blower such as this, the fuel does not have the benefit of the blower mixing it into the air.
You need something in the arrangement to do the mixing of the two post injection site. That leaves the bowl area or the combustion chamber. For the reasons I mentioned above the chamber is out, so that leaves the bowl area.
Its not that it won't work without it it's just more efficient with the homoginizer in the mix.
Now the question remains that at more aggresive cam profiles and raised rpm ranges, will the wing be needed, and will it be a detrement to power once those variables are changed.
This is just my guess from what I've seen of the parts,and general experience with blowers, but if I'm wrong anyone can feel free to call me stupid. Heck call me stupid anyway I don't mind..lol
2012 ZL1
Old 08-05-2012, 02:54 PM   #9
ADM PERFORMANCE
214-228-8782
Your not stupid.
In short :
You could have said it helps reduce detonation.
Andy Mages
Owner/Operator
214-228-8782
Old 08-05-2012, 03:41 PM   #10
2012ZL1
CaRaHoLiC
2012ZL1's Avatar
That would have taken less words alright.
2012 ZL1
Old 08-05-2012, 05:45 PM   #11
Zee-Ell-One
Yooz gotta B freekin kidn
Zee-Ell-One's Avatar
Drives: 2013 6mt ZL1#826
Looks like you knew the elaborate answer to your own question all along
The Zeldabeast! A True Thoroughbred Road Warrior!
Zee-Ell-One is offline   Reply With Quote
Old 08-05-2012, 06:26 PM   #12
1st Gen Forever
ZL1 #140
Hey 2012ZL1, now research how changing fuel injectors on an LSA might affect atomization with or without the wing...
Old 08-05-2012, 06:46 PM   #13
Higgs Boson
Big Time Newb
Drives: C63
just like anything else from the factory, it's there for a reason. but that doesn't mean that reason is aligned with your goals. if your goal is more along the lines of maximum airflow, then.....
Higgs Boson is offline   Reply With Quote
Old 08-05-2012, 06:49 PM   #14
tsnow
tsnow's Avatar
Drives: 12' ZL1, AGM 6M
2012ZL1, I enjoyed the lengthy reply.
Really looking forward to the new DI V8s, add a blower.... and BOOM serious power with less det and better mileage to boot!
tsnow is offline   Reply With Quote
Old 08-05-2012, 07:04 PM   #15
Higgs Boson
Big Time Newb
Drives: C63
me too as long as they figure out how to keep the valves clean. I think the Pcv days have run their course.
Old 08-06-2012, 02:12 AM   #16
2012ZL1
CaRaHoLiC
2012ZL1's Avatar
D.I ..yeah thats an interesting subject. That would rely on the injector to :
1. Overcome combustion pressure
2. Provide an extremly high level of atomization
3. Ideally allow for the best manifold and head flow.
Dry air is easier to deal with than wet air. I guess Injector "aiming" and combustion chamber / piston shape would be all you have to work with for homogenizing the mixture.
Sounds interesting I think I'll have to read up on it.
2012 ZL1
Old 08-06-2012, 03:01 AM   #17
2012ZL1
CaRaHoLiC
2012ZL1's Avatar
Interesting. One would think larger injectors would reduce the need for detonation help, but In this case I don't think injector size has any effect.
If the tune is done correctly the computer takes care of fuel air ratios and other than a larger inector being able to supply more fuel when asked, the fuel air mixtures are still the same.
Even if you used a different "style" of injector,and you find a style that provides better atomization, it would still need help to mix it into the air stream. It could be a heavy patch of fuel or a light patch of fuel it still wouldn't be mixed with the inlet air as well without turbulence.
IMHO injector type or size really has no effect on what the wing is trying to do.
I think a tune that uses a fuel curve optimized for performance rather than fuel economy will no doubt help with detonation over a factory curve, so a wing may be slightly less important with a performance fuel curve.
I think now that I examined the reason for the wing, for all out power, removing the wing should not cause a problem, because at some point, elevated rpm and boost levels require volume and flow over chamber turbulence to reduce detonation.
Also one could remove or shrink the wing if other measures were substituted for reducing detonation such as cooler inlet air, better fuel, etc.
The wing is great for the intended usage and boundaries of the stock or mild engine.
Before I pushed this engine to the extremes I think I would change pistons and rods anyway, so the question comes to mind is it worth it to remove the wing for me?...probably not. I will probably have the ports cleaned up, gasket matched and call it a day.
2012 ZL1
Old 08-06-2012, 08:48 AM   #18
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
Subscribed!
"...What IS true: We anticipated that this would happen - we are never finished - and yes, Ford DOES deserve to win now and then. To think that GM can come out with a car to make ford throw in the towel is simply foolhardy..." - fbodfather
Old 08-07-2012, 12:50 AM   #19
2012ZL1
CaRaHoLiC
2012ZL1's Avatar
Just read another thread on the subject at another site. Apparently the wings also direct the fuel air mixture into the center of the cylinder. More research is needed.
2012 ZL1
Old 08-10-2012, 10:52 AM   #20
MrDew
MrDew's Avatar
Drives: 2012 ZL1 #165
found a nice article on the ZR1 heads... they also talk about the wings...
http://corvetteactioncenter.com/spec..._pursuit6.html
right clicking is disabled but point 4 is where it talks about it
MrDew is online now   Reply With Quote
Old 08-10-2012, 10:55 AM   #21
willhe64
willhe64's Avatar
Drives: 2012 45th Vert, 2011 4x4, 9sec Vega
It's squeltch, not quench.
I feel it only fair to warn you, I have a black belt in CAPS LOCK.
willhe64 is online now   Reply With Quote
Old 08-11-2012, 01:37 AM   #22
1st Gen Forever
ZL1 #140
Nice read! Good Find!
Old 08-11-2012, 02:05 AM   #23
mgoodbar
White 2ss, LT, CAI, Tune
Drives: 2010 L99
Are these wings anything like the old 462 SBC heads were they thought having a specific shape in the valve boal area, it would cause a tornadic effect and mix the fuel better??? After some time and research was done the hot rod community simply removed all the material. The finding was it caused more harm than good. Removing the excess materials from under the valve area, Think it was called boal blending, actuall increased the CFM of the heads substantually.. So it would stand to reason that if this is helping to mix the charge of fuel as it enters the valve boal area I would think its effectiveness would be determined by the location of the injector nozel vs the air flow vs the wing placment. We need pictures..... If this wing is actuall doing its job and a supercharged engine does infact benifit from this extra mixing of the fuel, why not desighn a injector like a nitrous nozel?? That way it could be pointed in the direction of the incoming air and cause greater atimoziation of fuel.. ????? kinda like pissing in the wind.. Sorry for the spelling...
mgoodbar is offline   Reply With Quote
Old 08-11-2012, 02:14 AM   #24
mgoodbar
Drives: 2010 L99
some info on flow.. I will find some more and I saw the wing. This is a completly differand design than the old fuel heads. under the old fuel head in the boal area, I guess it could best be described as a giant single protruding thread, directly under the valve seat. It was supose to do the very same thing as this wing. http://www.circletrack.com/enginetec...s/viewall.html
Old 08-11-2012, 02:19 AM   #25
mgoodbar
Drives: 2010 L99
you can see here were the boal has been somewhat blended removing some of this lip/ or thread area. what ever it's called??? hope this info helps....
