Old 08-04-2012, 09:43 PM   #1
L99CAMA2011
L99CAMA2011's Avatar
Camaro 1LE vs. Camaro ZL-1
No not in a drag race but in the handling characteristics. I notice in the Japolink write up on the 1LE the editor said this,"The car does have more understeer than the ZL1, especially in the faster turns, and I wish the brakes were updated and not just painted. They just don't live up to the incredible handling available, but it certainly wasn't a deal breaker. The gearbox ratios are tuned for the racetrack and the throw is short and tight. For the price, its performance is not that far from that of its big brother." Now I would have thought that the 1LE would have been more neutral all round with the 20x10s all round and no blower in the front end, but seems like the ZL-1 with more power to the rear, more weight with the 9" rear end balancing the weight distribution more than the 1LE makes the ZL-1 the more neutral handler which shocked me but not so much after closely analyzing both setups. It is true that more power to the rear wheels can make a car more neutral around corners and I have experienced this many times in the past but I still see the 1LE as being the more toss friendly platform in events like autocrossing and so on. What say you.
Old 08-05-2012, 01:22 AM   #2
Fenderaddict2
Opinionated bugger!
Fenderaddict2's Avatar
Drives: Boss 302, Mazda 2, Praga & Intrepid
I'd love the opportunity to compare them. Personally I'm drawn to high revving NA motors and there is talk that the 1LE can walk a Boss as I would expect following the car to market with a well sorted IRS. Not buying the 4 second VIR advantage though.
At then end of the day I suspect price will be the biggest deciding factor between the two King Camaros.
Follow me on forums everywhere as Fenderaddict2 or my kid on the track and Twitter @fastmyles
Fenderaddict2 is offline   Reply With Quote
Old 08-05-2012, 03:56 PM   #3
Sleepy
Sleepy's Avatar
Drives: 2011 LS M6 SW
Don't forget 1LE has larger 27mm front stabilizer bar to offset the square tire sizes.
Sleepy is offline   Reply With Quote
Old 08-05-2012, 04:13 PM   #4
L99CAMA2011
Sorry I forgot to mention that but My current setup has the ZL-1 rear 28mm bar with H&R front 28mm bar with staggered setup and corners very freaking neutral but of course the stock cars don't have the full equipment I have. My car with even tires front and rear would be even better. Just thought the 1LE should be more neutral than say my car is. Also spring rates and strut/ shock stiffness plays an important role as well.
Old 08-06-2012, 11:05 AM   #5
Sleepy
Sleepy's Avatar
You and me both. I was also hoping for the a more neutral car with less body motion.
Old 08-26-2012, 01:08 PM   #6
SUKXOST
Do you even lift, bro?
SUKXOST's Avatar
Drives: 2013 1LE Camaro
This thread will be on fire I suspect once some of these 1LEs get to the track!
My 1LE (645WHP/597WTQ) build/journal Thread:
1st ever 1LE COTW http://www.camaro5.com/forums/showthread.php?t=255461
SUKXOST is offline   Reply With Quote
Old 08-26-2012, 04:34 PM   #7
PYROLYSIS
Remember the Charleston 9
PYROLYSIS's Avatar
The 1LE doesn't have 20x10 wheels all the way around, just the same size tires.
Old 08-26-2012, 06:53 PM   #8
SUKXOST
SUKXOST's Avatar
Yep 9" fronts and 10" rears. 285 on all fours to help with understeering(in addition to all of the suspension mods GM did)
YAY GM
Old 08-26-2012, 06:57 PM   #9
cbass
Drives: .
YAY GM
20 x 10 up front
20 x 11 in back
285 on all fours
cbass is offline   Reply With Quote
Old 08-26-2012, 06:57 PM   #10
L99CAMA2011
YAY GM
I assure you there are not 20x9s up front or anywhere on the 1LE. The last correct I heard was 20x10s all round. ZL-1 fronts on all four corners.
Old 08-26-2012, 07:22 PM   #11
PYROLYSIS
PYROLYSIS's Avatar
Originally Posted by cbass View Post
20 x 10 up front
20 x 11 in back
285 on all fours
This guy has it correct. You can look at the brochure for confirmation if you need it.
Old 08-26-2012, 07:28 PM   #12
2cnd chance
Too Many Great Choices
2cnd chance's Avatar
Drives: Grand Sport/Z07
20 x 10 up front
20 x 11 in back
285 on all fours
This is correct.
2cnd chance is offline   Reply With Quote
Old 08-26-2012, 08:07 PM   #13
cipriank
cipriank's Avatar
Drives: 2010 camaro 2ss
20 x 10 up front
20 x 11 in rear...
I assure u
2010 2ss L99
Mods: ADM race intake, ADM scoop w/ washer bottle, SLP long tube headers, SLP 25% UDP, SLP Loud Mouth 2 exhaust, Vmax TB, BER intake manifold,3.45 gears, MSD wires, SLP 160 t-stat, SLP Springs,
EFI live tune by Redline Motorsports
cipriank is offline   Reply With Quote
Old 08-26-2012, 08:33 PM   #14
b4z
Drives: '06 Pontiac GTO M6, '09 V8 SRX RWD
1LE weighs 260 lbs less than a ZL1. So if you could get about 100 hp more out of the LS3 you would have a hell of a car. That is 100 naturally aspirated, not forced induction with 100-120 lbs extra weight on the front end.
b4z is offline   Reply With Quote
