JUICEDMOTORSPORTS
Old 08-26-2012, 08:08 PM   #15
bannonm
bannonm's Avatar
Drives: 2011 2SS/RS M6 VR
Originally Posted by cipriank View Post
20 x 10 up front
20 x 11 in rear...
I assure u
I wonder what the logic in doing that was? I guess it leaves a 1LE owner the option of using the same rear tire as the ZL1. I chose 10's with 285's all around for the ability to rotate, although since they are getting most of the wear on the track I may not bother.
bannonm is offline   Reply With Quote
Old 08-26-2012, 09:08 PM   #16
Mgizzle
Mgizzle's Avatar
Drives: 2013 Camaro 1LE 1SS
I am not sure what to think of the different front and rear rims.... most of the time I was hoping to have all 4 be 10'' wide so when I kill the rear tires at the track I can just swap front to back but now that's out the window.... not sure if offsets were already different.
Anyhow, at the same time, I am glad they provided the wider rim because let's be honest...... how many of us are going to leave that motor stock?!?!?!? This might be one of the reasons they left it. I know the wider rear will hurt balance, but so is more power and an itchy right foot. At the same time, leaving them the same as a zl1 will make manufacturing different cars on the same line a lot easier to do and keep everything more simple... I think.
I do like the look with the wider rim too and the tires stretched out.
Mgizzle is offline   Reply With Quote
Old 08-26-2012, 11:07 PM   #17
Fraxum
Fraxum's Avatar
Drives: 2016 SS M6
from what I hear, 1LE + fatter rear sway + differential, cradle, radius rod inserts will = awesome.
Not all that expensive and possibly DIY doable. This is based on ZL1 suspension experience. Check out the suspension mod forum once the 1LEs start shipping. My opinion is you do not need 100 extra HP. 50 more just from bolt-ons should get you a really fast car.
Old 08-26-2012, 11:19 PM   #18
Bad70supreme
Bad70supreme's Avatar
Drives: 2010 aqua blue SS/RS M6
Originally Posted by b4z View Post
1LE weighs 260 lbs less than a ZL1. So if you could get about 100 hp more out of the LS3 you would have a hell of a car. That is 100 naturally aspirated, not forced induction with 100-120 lbs extra weight on the front end.
All this 1le talk makes me more proud of my SS. Reason is, the SS sounds more capable dont it! I mean some suspension work, a 3.91 gear and a new set of wheels and tires... we all have a 1LE
10.91 at 122 H/C stock block N/A
Bad70supreme is offline   Reply With Quote
Old 08-27-2012, 07:14 AM   #19
5thGenCamaroKid
No fat chix, car scrapes.
Drives: 2014 GMC Sierra 1500
The other big piece is the trans.
5thGenCamaroKid is offline   Reply With Quote
Old 08-27-2012, 07:50 AM   #20
Norm Peterson
corner barstool sitter
Norm Peterson's Avatar
Drives: 08 Mustang GT, 10 Legacy 2.5GT, ...
With same-size tires, there's just a little less cornering stiffness on the narrower wheels and just a tiny bit more front slip angle. As an isolated effect, I'd expect just a tiny bit more understeer than if all four were either 10 or 11. Or 10.5, for that matter.
10" is not a particularly wide wheel for 285-wide tires.
Norm
Norm Peterson is offline   Reply With Quote
Old 08-27-2012, 11:00 AM   #21
SUKXOST
Do you even lift, bro?
SUKXOST's Avatar
Drives: 2013 1LE Camaro
Originally Posted by cbass View Post
20 x 10 up front
20 x 11 in back
285 on all fours
That's what I said! LOL OOPS
My 1LE (645WHP/597WTQ) build/journal Thread:
1st ever 1LE COTW http://www.camaro5.com/forums/showthread.php?t=255461
SUKXOST is offline   Reply With Quote
Old 08-27-2012, 11:03 AM   #22
cbass
Drives: .
You were an inch off.
Yep 9" fronts and 10" rears. 285 on all fours to help with understeering(in addition to all of the suspension mods GM did)
cbass is offline   Reply With Quote
Old 08-27-2012, 11:35 AM   #23
SUKXOST
SUKXOST's Avatar
Story of my life! LOL
Old 08-27-2012, 11:59 AM   #24
2cnd chance
Too Many Great Choices
2cnd chance's Avatar
Drives: Grand Sport/Z07
Remember the car was designed with a staggered set up therefore the offsets are different front to rear. also the cost of tooling new wheels is unnecessary if the ZL1 wheels are used.*
2cnd chance is offline   Reply With Quote
Old 08-27-2012, 12:15 PM   #25
cbass
Drives: .
Does anyone know why? Does a staggered offset have any advantages or is it just for looks?
Old 08-27-2012, 03:08 PM   #26
Norm Peterson
You'd never notice a 5mm difference in front vs rear offsets without measuring equipment or strings unless you knew precisely what to look for and exactly the viewpoint required.
It appears that with a 1" difference in front vs rear wheel widths - starting at the SS level - they're holding the front and rear track widths equal at 63.7".
In the LS/LT, they're calling out only one wheel offset and letting the rear track "float" just a little (up to 64.1"). If appearance entered into the decision process for utilizing different wheel offsets at all, it would most likely have been here.
Norm
Old 08-27-2012, 04:49 PM   #27
2cnd chance
In this case mostly looks. However wider rear tires do add traction.
Old 08-27-2012, 06:04 PM   #28
DanSS24
DanSS24's Avatar
Drives: Dream Cars in my head
hey...did anyone notice the emblem on the trunk of the white 1LE? It did not look like the SS emblem.
I tried to blow it up but it pixilated
Wishful thinking...but I sure can dream big.
DanSS24 is offline   Reply With Quote
