Rick@Livernois
Old 08-04-2012, 09:40 PM   #1
Neto1978
Drives: 2011 camaro ss victory red
Odometer rollBacks
Is it possible to rollback odometer and engine hours meter?
I was checking for buying an used suburban 2008 with 25k miles and only 256 engine hours...
It made me suspicious...
Tks
Neto1978 is offline   Reply With Quote
Old 08-04-2012, 09:49 PM   #2
GunnyG
Da WHALE
GunnyG's Avatar
Drives: 2014 Stingray, 2015 Panamera 4
Might be possible, but I think it's illegal.
Project MantaRay...Underway
GunnyG is offline   Reply With Quote
Old 08-05-2012, 01:16 AM   #3
montej23
montej23's Avatar
Drives: 2011 VR Camaro
Its illegal to do however people have done it
montej23 is offline   Reply With Quote
Old 08-05-2012, 01:24 AM   #4
fielderLS3
fielderLS3's Avatar
Drives: 2016 Mazda6, 2011 Mustang 5.0
How do you roll back a digital odometer?
Is it an hour meter that is meant to be able reset for some specific purpose, like work, or maintenance, or is it supposed to be a total counter, like the odometer? 25K miles and 256 hours = 97.7 mph average, which is not possible.
"Proven V-8 power with better efficiency than a turbo V-6"
"The car is the closest thing we will ever create to something that is alive."eds.
fielderLS3 is offline   Reply With Quote
Old 08-05-2012, 03:35 AM   #5
Brutal SS
Brutal SS's Avatar
Drives: 2015 Camaro 2SS 1LE
Brutal SS is offline   Reply With Quote
Old 08-05-2012, 08:15 AM   #6
Neto1978
Is there anyway using a dtc code reader to retrieve the correct mileage from ecm?
The dealer is able to know if there was a rollback?
Tks
Old 08-05-2012, 01:39 PM   #7
BlackM6RS/SS
BlackM6RS/SS's Avatar
Drives: 2010 Black M6 RS/2SS
My company truck has a hour meter on it and it reset before from having a super dead battery multiple times... It reset the hour meter. FWIW
10 Blk/Blk RS/2SS w/CGM Stripes
ADM H/C/I M6 480rwhp 435rwtq
FE4 LCAs w/Pfadt ZL swaybars Diff bushings Trailing arms Drop springs
BlackM6RS/SS is offline   Reply With Quote
Old 08-05-2012, 01:50 PM   #8
Oldrocker
Oldrocker's Avatar
Drives: 2010 SS2/RS Victory Red
I'd assume the hour meter keeps up with engine running time. That would include idling so it is possible to have 256 hours of running time.
Oldrocker is offline   Reply With Quote
Old 08-06-2012, 11:13 AM   #9
infernometallicSS
infernometallicSS's Avatar
Drives: 2012 Camaro SS Best Run - 10.93@125
This is correct and nowadays they have become a little more sophisticated. Some vehicles have a timer that will tell you engine idle time. The technology. Lol.
infernometallicSS is offline   Reply With Quote
Old 08-07-2012, 06:47 PM   #10
B.Buster
B.Buster's Avatar
Drives: 2010 AquaBlue 2SS/RS
Can't Carfax help? I believe all state inspections are shown
B.Buster is offline   Reply With Quote
Old 08-07-2012, 06:55 PM   #11
Ivan @ Southwest Speed
Totally possible but it raises certain flags inside the BCM.....to the average Joe, nobody would know however.
Best to Carfax that thing up or make the owner provide that to you.
Anything is possible too though...just vet the info.
GLWP!
Ivan
Old 08-07-2012, 08:03 PM   #12
JLE58
Drives: CGM,twin turbo, cam 2010 SS/RS
You would have to change the whole gauge cluster out. Some new cars will store in the ECM and will reset the cluster on it's on. It something your dealer could tell you. Look around the dash near the gauge cluster and see if there are any scratches that seems Someone has changed the cluster. Test drive it and watch the mph and see if it sticks anywhere. That's a good indication that the speed sensor was unplugged for a good while.
JLE58 is offline   Reply With Quote
Old 08-07-2012, 08:16 PM   #13
pouncer72
Drives: 2011 Camaro SS
Send a message via AIM to pouncer72
Milage is tracked by the bcm and wheel sensors. Even if the cluster reads 0 mph, your milage will increase if the bcm is receiving wheel sensor reports. Tried, tested, and proven on my own car. The clusters do not store any information, they just display what they are told.
pouncer72 is offline   Reply With Quote
Old 08-07-2012, 08:21 PM   #14
GMTool
MY SS is SOLD
GMTool's Avatar
Drives: AGM 2012 Camaro 2SS/RS L99
I have a Silverado with an hour meter. I think all cars should have them. I remember reading on some Chevy truck forums that some people have had their hour meters reset itself because of a dead battery type issue.
CAI, Dynatech Headers, HF Cats, JRE Tuned, Corsa Cat Back, Strut Tower Brace.
GMTool is offline   Reply With Quote
