Solo Performance
Old 08-05-2012, 09:52 PM   #1
C-redfly
C-redfly's Avatar
Drives: 2012 completely Red Camaro
Does a trifecta tune void warranty? And how does it work?
C-redfly is offline   Reply With Quote
Old 08-06-2012, 08:08 AM   #2
just_cooling
Pass the juice box
just_cooling's Avatar
Drives: Line up and find out
Send a message via Skype™ to just_cooling
Technically yes because your modding the chip which controls the engine but it will only void your warranty if something happens to your car and you take it to the dealer to be fixed and they say the problem is a direct result of the tune.
The mail you a tune (and cord if needed), you can either plug it up to the computer or use the little handheld device upload the tune. I believe i read somewhere that you can copy your stock tune so you can return to it in case you need to take it back to the dealer.
Cosmetic mods: Plasti Dip
Speed Mods: Muffler delete, switched to boxer briefs
just_cooling is offline   Reply With Quote
Old 08-06-2012, 09:30 AM   #3
BNRacing
Drives: 2010 Cobalt SS, 1972 Nova
technically yes it does void the warranty. However it has been proven several times that our tune is not detectable using gm's current scanners. If GM wants to see the ECM themselves, all bets are off.
Basically we would email you the performance tune and the stock tune for your vehicle and physically mail you a cable to upload the tune to the vehicle.
BNRacing is offline   Reply With Quote
Old 08-06-2012, 10:25 AM   #4
C-redfly
C-redfly's Avatar
Thanks for the feedback. So if you mail me the stock tune as well could I upload the stock tune over the performance tune if I had to get work done at the dealer and is it traceable that I had a tune?
Old 08-06-2012, 06:43 PM   #5
BNRacing
That's correct, you can return back to stock at any time as long as you buy the cable so you can connect your car to your laptop. If you choose to rent the cable, you'd have to re-rent it and hope we had a loaner to send you. They're almost always loaned out.
