Jason 98 TA
Old 08-06-2012, 09:23 AM   #1
01pewterz28
Camaro Junkie
01pewterz28's Avatar
ZL1 springs installed on my 2LT/RS
This weekend I installed ZL1 springs on my Camaro we replaced the stock V6 Springs with a set of ZL1 springs what a difference 1.25" lower
the 1st two photos are of the stock spring height, the next group of photos are of the car lowered.
The two photos of the springs out of the car (V6 on the right, ZL1 on the left) so you can see the difference.
I used to be able to fit 4 fingers in the wheel well from the top of the tire to the top of the fender, now it's hard to fit 2 fingers in.
Looks so much better now
**FIFTY HBM 2SS VERT**
Old 08-06-2012, 09:37 AM   #2
Sleepy
Sleepy's Avatar
Drives: 2011 LS M6 SW
Looks great. How does it ride and handle?
Sleepy is offline   Reply With Quote
Old 08-06-2012, 09:46 AM   #3
01pewterz28
Camaro Junkie
Ride is a little stiffer than stock (not harsh) but a better feel to it. So far handles good once I do the rest of the suspension I should really feel a difference.
Old 08-06-2012, 09:48 AM   #4
jameslk55
jameslk55's Avatar
Drives: 2012 2LT/RS, 2005 SLK55 AMG
Looks a tad lower than stock ZL1s... Any alignment issues? Please keep us updated with the rest of your ZL1 suspension upgrade, as well as some part numbers.
jameslk55 is offline   Reply With Quote
Old 08-06-2012, 09:56 AM   #5
01pewterz28
Camaro Junkie
No alignment issues she was aligned when I did the ZL1 wheels will do.
Old 08-06-2012, 09:59 AM   #6
Sleepy
Sleepy's Avatar
I think it looks a tad lower than stock ZL1 because his stock tires are a little taller than stock ZL1 tires. They fill up the fender gap nicely.
Old 08-06-2012, 10:07 AM   #7
carrs_crew
Livin the Dream
carrs_crew's Avatar
Drives: sold
Any extra needed parts to complete this, was waiting to get coilovers so I was not going to purchase aftermarket springs, but this could be a great bridge until I can buy coilovers. Where did you get them, online or dealer?
carrs_crew is offline   Reply With Quote
Old 08-06-2012, 10:31 AM   #8
01pewterz28
Camaro Junkie
Nope no additional parts it's a direct swap, 2 hours from start to finish.
Old 08-06-2012, 10:32 AM   #9
wirebender
wirebender's Avatar
Drives: 2017 ZL1, A10, White, sunroof, nav
How does the price for those compare to eibach, pedders, BMR, etc? Where did you order from and what did you pay??
wirebender is offline   Reply With Quote
Old 08-06-2012, 10:59 AM   #10
01pewterz28
Camaro Junkie
Not sure price my buddy removed his stock ZL1 springs to put new ones on so he gave me these I would estimate the ZL1 springs are in the $300 range for all 4.
Old 08-06-2012, 11:38 AM   #11
daveagogo1
TRI COUNTY TAMPA
daveagogo1's Avatar
Drives: 2011 1SS/RS VR/BLK A6
Maybe slightly.
Looks good Sean.
Originally Posted by HufferSS View Post
Fast cars have rubber on the quarter panels...you sissies need to knock it off.
daveagogo1 is offline   Reply With Quote
Old 08-06-2012, 12:45 PM   #12
2012REDSS
Drives: 2012 Camaro SS
part numbers? looked them up on gmpartsdirect and they just have the springs listed as coil spring camaro All part number 92195466 and three options for the front but only two without special handleing package part numbers 20953579 and 22737722?
2012REDSS is offline   Reply With Quote
Old 08-06-2012, 01:05 PM   #13
jameslk55
jameslk55's Avatar
Not sure if I read this correctly. You don't need an alignment when you swap out the wheels but shouldn't you check it after new springs are installed?
Old 08-06-2012, 01:59 PM   #14
nak3dsnake
nak3dsnake's Avatar
Drives: 2010 Camaro IBM 2LT/RS M6
These are the part numbers I have for the ZL1 Springs. All four from gmpartsdirect is $273.50 shipped.
Front Spring (2) - 20954688
Rear Spring (2) - 20942619
Looks: AAC P13W DRLs, Heritage Grille, RS Embroidered Headrests, GM Door Sill Plates, GM Premium Floor Mats, Body Color Engine Cover, LLT Mobile 1 Oil Cap, ZL1 Sport Pedals, 3M Clear Bra.
Performance: Vararam Ram Air Intake, Hurst Short Throw Shifter w/ Hurst Hard Drive Pistol Grip, IDEALG Clutch Master Cylinder, RX Catch can, GTO clutch fluid reservoir, Brembo Brakes, 1LE Track Pack, GMPP Exhaust Upgrade.
nak3dsnake is offline   Reply With Quote
