Old 05-26-2009, 12:48 PM   #43
Warpick
Drives: Rust bucket and a jalopy
Originally Posted by PieNsky View Post
GM first came up with this engine in the '60s. Sold it to Kaiser who put it in some Jeeps. AMC bought Kaiser and later sold the design back to GM
Well no wonder it's a strong engine! It potentially powered a Henry J! Quick someone put a full tilt TA performance crate engine in one!
Warpick is offline   Reply With Quote
Old 05-26-2009, 02:57 PM   #44
SomeGeoffGuy
SomeGeoffGuy's Avatar
Drives: 2016 2SS Convertible
Originally Posted by Warpick View Post
Got a link for a stock cobra to see the differences or at least what RPM the abruptness started? Also a GTP I'd be curious at seeing the differences in A:F. If it's jus a measure to keep it from leaning out at the top end and cause detonation.
I will shoot you a screenshot of the table when I get home tonight.
-Geoff
'12 2SS RS Convertible - Traded in.
'16 2SS Convertible - White on white, mag-ride, NPP, nav.
SomeGeoffGuy is offline   Reply With Quote
Old 05-26-2009, 03:01 PM   #45
rays
V6 - It just isn't normal
rays's Avatar
Drives: 2010 2LT M6, F250 7.3L Diesel
The CTS tested higher with the same engine. I wonder why?
Baseline run: vehicle produced 263.0 rwhp and 241.7 lbs/tq.
With a CAI and corsa exhaust(no other tuning) it tested
294.2 rwhp and 261.3 lbs/tq
Post #24 here:
http://www.gminsidenews.com/forums/f...33/index2.html
2LT RS M6 RJT Black leather
4/29/2009 Ordered
6/24 6000 Delivered
rays is offline   Reply With Quote
Old 05-26-2009, 03:17 PM   #46
MadMaxx
Master of the V6
MadMaxx's Avatar
Drives: 2010 Camaro 1LT/RS
Post #24 here:
Manual transmission, no listing of ambient temp... dynapack historically read higher than mustang, etc. etc.
Mustang dyno's are known as the "hearbreakers" for a reason I'd rather know my as-close-to-real-world-as-possible numbers.
MadMaxx is offline   Reply With Quote
Old 05-26-2009, 03:36 PM   #47
rays
rays's Avatar
Kewl, thanks!
This tuner talk is new to me but I'll be watching and learning
4/29/2009 Ordered
6/24 6000 Delivered
Old 05-26-2009, 03:42 PM   #48
Warpick
You can't even compare the same dyno manufacturer from shop to shop let alone different dyno's.
Maddmaxx is the only one who took his in so that's all we have to base it off of. Which makes him the man by the way.
Ambient temps, elevation, humidity, and all sorts of variables will always produce different results.
Old 05-26-2009, 04:13 PM   #49
Hemlawk
AwesomeBillDawesonville
Hemlawk's Avatar
Drives: CGM 2SS/RS =)
Kewl, thanks!
I'm in the same boat.
AFR ECU CAI.. Ass sphincter says what?
I'm learning
Order placed on 1/13/11 - Purchased 2/22/11 2SS/RS CGM
Hemlawk is offline   Reply With Quote
Old 05-26-2009, 05:33 PM   #50
Teleplayer
Drives: 92 Bonnie SSEI - 2010 GT Soon
Didn't I read somewhere that the ECM sets a rich mixture for so many miles on a new engine?
Teleplayer is offline   Reply With Quote
Old 05-26-2009, 05:44 PM   #51
Michael
World's Oldest Newbie???
Drives: 2010 Camaro 2SS/RS (On order)
Are you sure these can be tuned? No ones been able to tune the new style PCMs on the Pontiacs yet. At least, no one in the Grand Prix sites I frequent.
Michael is offline   Reply With Quote
Old 05-26-2009, 06:12 PM   #52
Warpick
Piggy backs are out in Australia not my preferred method, but stand alone engine management systems are available now.
Piggybacks are the start of new ECU's.
Old 05-26-2009, 07:08 PM   #53
MadMaxx
Master of the V6
MadMaxx's Avatar
Anything can be tuned, it all comes down to $$$. With such a robust featured stock ECU, it's going to be hard(er) for an aftermarket full blown standalone to come along. Pigguback systems are going to be the norm for a while -- and honestly, probably will work just fine. I've got a feeling the transmission and rest of the driveline will become a problem long before the engine does
Old 05-26-2009, 07:15 PM   #54
UsedTaHaveA68
UsedTaHaveA68's Avatar
Drives: Hyundai Sonata
This.
With out overextending too much the DI means that you're not taking air and fuel on the intake stroke. It's just air. So carbs are like air/fuel mixing centers port injection is shooting atomized fuel with the air and compressing it all on the compression stroke.
Fuel is a liquid and can't be compressed as much as air. So with direct injection. You have nothing but air being compressed and as the air is compressed you have all that pressure in the chamber and THEN the fuel is injected and ignited.
Compression needs to be payed attention to, but it's not as important on carb or port injection methods. Which is why you can run such a high compression. It's all air being compressed. The only thing you really need to worry about is can the internals handle all the energy happening in the combustion chamber.
This seems to be a very common misconception. Fast foward to 0:25. You will notice that fuel is sprayed into the cylinder on the intake stroke. If it were sprayed at the top of the compression stroke, it wouldn't be very effective in cooling the intake charge. That and it would probably spontaneously ignite, causing the engine to "diesel."
EDIT: Why can't I ever get these damn videos to embed?!! Here's the link:
http://www.autobloggreen.com/2009/03...ect-injection/
UsedTaHaveA68 is offline   Reply With Quote
Old 05-26-2009, 07:47 PM   #55
ssrsheaven
ssrsheaven's Avatar
Drives: 92 firebird,2010 camaro
Nice keep us up to date.
ssrsheaven is offline   Reply With Quote
Old 05-26-2009, 09:32 PM   #56
SomeGeoffGuy
Here is a shot of the PE vs Time table from my GTP. There is one table for base at 12.4, then another table lowers it as a function of time and RPM. You can see how easy it would be to get into the 10.X range on a 1/4 mile run.
-Geoff
Camaro Laws ChevyNut Off-topic Discussions 107 11-09-2016 06:40 PM
V8 Camaro Performance Upgrades List Milk 1027 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 89 02-20-2015 09:43 PM
Camaro SS 2010 on dyno makes 364 whp & 371 rwtq !! Vid inside UCF w00t Camaro Photos | Spyshots | Video | Media Gallery 128 03-20-2011 11:27 PM
Car and Driver drives V6 Camaro! Xanthos 5th Gen Camaro SS LS LT General Discussions 63 08-26-2008 10:21 PM
