HeadlightArmor
Old 08-06-2012, 03:53 PM   #1
jimmy5
jimmy5's Avatar
Drives: 2012 ZL1 #450
System Question
Going to get some subs for the Z, wanting to put 2 10"s in the sides with those form fitting sub boxes.
I've always liked polk, but thought about getting Boston Acoustic just to keep a theme.
How many watts can the stock system handle? Or would you even hook it up to the amp, and just have the subs alone wired to the amp?
If you were to do it like this, how many watts would you get for the amp? And where all would you hook it up? Also, any advice on amp mounting areas would be appreciated.
jimmy5 is offline   Reply With Quote
Old 08-06-2012, 11:26 PM   #2
yzark99
I run 2 catch cans...
yzark99's Avatar
Drives: 2012 1LT SIM Auto
I would be surprised if the stock system had 5 watts total. The "premium" system probably has 6. Total Garbage.
I hooked up a BA GTA 1000M amp to the rear speakers, running a BA G3 12" sub in a 1 cuft box. I originally had my amp mounted to a shelf under the rear deck. Now building a rack/box holder to mount 3 amps and a crossover.
For signal, you can either tap the rear speakers and run the high input into your amp if it has high input, or connect a LOC to those wires and run an RCA patch cord to the amp's RCA inputs.
Overkill tuned • Air Scoop • CAI • VMAX PTB • JacFab Extendolator • SOLO Hi-Flo Cats and Cat-Back Exhaust
View my top 3 LFX performance mods and more:
yzark99 is offline   Reply With Quote
