Old 08-06-2012, 06:52 PM   #1
Jameg1011
Jameg1011's Avatar
Drives: 2012 2LT 45th anniversary
Cleaning the intake valves
Pulled the intake manifold off today to find a ton of build up on the values. (yes i ordered a catch can instantly). Whats the best way to clean that off of there? Is there a spray or something i can use while i have the manifold off? (i dont feel like taking the heads off ect i have work at 7am) If anyone has any idea, any input would be appreciated!!
Jameg1011 is offline   Reply With Quote
Old 08-06-2012, 07:21 PM   #2
Lil' Nasty
[COTW 4/13/15]
Lil' Nasty's Avatar
Drives: Supercharged LLT
Some use sea foam but Im no expert on that stuff hopefully Tracy can chime in on this
Lil' Nasty is offline   Reply With Quote
Old 08-06-2012, 07:46 PM   #3
SC2150
BG or seafoam induction cleaning will help some, but physical removal is the only way to get them clean as new....at best seafoam will get maybe 1/2 of it off. You dont want to spray anything into the chamber as it can leak down into the cylinders.
Cant stress the importance of a catchcan (and only the few that actually catch most or all the oil...not the majority that still let a bunch through as you will still get this buildup) from day one.
I would reassemble and run a treatment through following the directions closely and with a good can, you will at least be preventing further buildup.
Old 08-06-2012, 08:54 PM   #4
JohnnyBfromPeoria
JohnnyBfromPeoria's Avatar
Drives: 2012 LS M6, Black
You can get Seafoam in through the brake booster line by necking down the line to a small hose you just barely let suck up a little Seafoam at a time (don't let the engine die, it "could" hydrolock the engine). I use tape to attach the smaller line to the brake booster line. It would be a good idea to change the oil afterwards, for the reason suggested above: leakdown past the cylinder walls.
If you wanted to go one step further, Seafoam in a spray can is called "Deep Creep" and is the same stuff. In theory, you could remove the plenum and have a shot at being able to spray down the intake tract, but the engine wouldn't be running at that point and an oil change would be even more relevant. Do not spray any sensors with the stuff.
If you remove the plenum, clean it out by soaking it in Dawn or your favorite grease-cutting soap and try to get any oil residue out of it, then dry it completely before reinstalling it.
I assume no responsibility for what may or may not happen, and all of this is just my opinion. Feel free to comment on it, however. I can remind you that adding any so-called cleaner to the gas tank will have zero cleaning effect as the fuel is injected directly into the cylinders and doesn't pass the valves on the way in.
John B.
12 LS M6, IPF S/C, ASA GT-5 wheels, VMax PTB
1995 Mitsubishi Montero SR
1987 Dodge Raider Turbo Project
1986 Mitsubishi Montero 2.4l FI Transplant
JohnnyBfromPeoria is offline   Reply With Quote
Old 08-07-2012, 06:42 PM   #5
SC2150
Good info Johnny
Old 08-07-2012, 07:01 PM   #6
20121lt
20121lt's Avatar
Drives: 1LE SS/RS 2013
jameg how many miles are on your motor
20121lt is offline   Reply With Quote
Old 08-07-2012, 08:11 PM   #7
JohnnyBfromPeoria
Originally Posted by SC2150 View Post
Good info Johnny
Thanks, Tracy. I sell floor covering for a living (for the last 26 years), but I have learned a thing or two about other things. Now, whether those things translate into real-world usefulness is debatable. As I said, I assume no responsibility!
Seafoam is fun...
John B.
Old 08-07-2012, 11:45 PM   #8
Jameg1011
Jameg1011's Avatar
12500
Old 08-08-2012, 11:11 PM   #9
Dadof10
Dadof10's Avatar
Drives: 2012 Blk/Beige 2LT M6
Any chance somebody has a "How To" video specifically for seafoaming the LFX engine.
Mods: Heritage Grille,CAI cold air intake,painted engine cover, RX catch can
Dadof10 is offline   Reply With Quote
Old 08-10-2012, 12:03 AM   #10
theragtopguy
Lifetime Philly Fan
theragtopguy's Avatar
Drives: 2015 Spring Edition 2SS M-6
Here's a link to a video showing how to use the CRC Motor Treatment product.....same basic stuff as Seafoam, but with more cleaning additives.
2015 Green Flash, Delivered 4/10/15
CAI, NPP Exhaust, Short-throw shifter
One of 82 GF Ragtops built in '15 out of 811 Total
Member of SEPA5+
theragtopguy is offline   Reply With Quote
Old 08-10-2012, 01:10 AM   #11
caliguy
Don't ask to pop my hood!
caliguy's Avatar
Drives: it's loud.......
All i did was, loosen up the clamp from the snout going to the TB stick the little hose from seafoam can into it, slid snout back over TB with hose going in, tighten down clamp, have a friend hold throttle around 1500RPM's spray for 2mins, shut off car, take out little hose, tighten down snout, let the car sit about 10mins NOT RUNNING, after that fire it up take a drive, down a empty road cause you'll start pouring smoke out, drive spiritly as the instructions say after smoke is gone your good to go...
Limo tint rears, 35% sides | B&G lowering springs | BowTies Blacked out | Red Footwells|Dome Light|Kicker 500Watts-Amp-Kicker 12" Ported Sub=BOOM| Stillin Splitter |Pssst 100 shot| 13.36 @102.7 @LVMS |
2010.
caliguy is offline   Reply With Quote
Old 08-10-2012, 09:09 AM   #12
20121lt
20121lt's Avatar
i understand this does not clean entirely the valves but i ordered a catch can yesturday as i have been reading this and my camaro has 1800 miles ...
Old 08-10-2012, 09:12 AM   #13
Russell James
Russell James's Avatar
Drives: '69 Z28, '10 NASA TA2, '15 1LE SS
Location: In the garage fixing stuff, track breaking stuff, at work paying for stuff. Or check the bar.
If it runs great, best thing to do is nothing (other than the catch can). Trying any type of flushing is just going to be washing abrasive crap down the cylinders. If it starts to have a problem, take it to the dealer. That's what the 100 k warranty is for.
Type of oil and miles between changes?
Russell James is online now   Reply With Quote
Old 08-10-2012, 09:17 AM   #14
Russell James
I pulled the heads off an SS at 3000 miles (and it had a catch can since 5) and there was what one might think to be a ton of carbon on the CC's, valves... scraped it off, cleaned everything up.... but the reality is it was just normal and had no effect on the way it was running. Ran great before and after.
If something is really wrong, it will be very noticeable and set a check engine light. If it runs perfect, put on a catch can, use the best fuel and oil, change the oil often, enjoy the car. Dissassembly, cleanings, treatments.... why bother introducing more problems to a perfectly running engine.
