Old 08-06-2012, 09:34 PM   #1
RetroXI
ME9ATRN
RetroXI's Avatar
Drives: 2011 White 2SS/RS
How can i achieve over 600 HP
I know it takes more than a super charger to get over more than 600 RWHP, so i was wondering if any one could list the parts i would need in order achieve 600+HP...Id appreciate it so much because i am current in the process of trading in my v6 for a v8 (yes the bug finally got me :/), anyways thanks in advance!
Originally Posted by carguy50 View Post
I buy my gas in the hood (93 is less expensive). All I see are Homies trying to figure how to fast jack my wheels. Guess I need to expand my horizons.
Originally Posted by Beescuz View Post
My son is in 4th grade and every night he has to read for 20mins. He reads aloud to me Camaro 5, Camaro Performance, Motortrend, RC cars, and etc ever night.
RetroXI is offline   Reply With Quote
Old 08-06-2012, 09:52 PM   #2
IPT
Drives: '02 Trailblazer, '12 Camaro 2SS/RS
I don't know for sure but I'd say a SC, maybe a change in pulley, LT headers with hi flow cats should get you close (look at Hennessy and Lingenfelter's builds where they list the components and HP's). If that didn't do it a cam should push you up to and over the 600 mark.
I'm sure people need to know also if you mean RWHP or just motor HP too!
IPT is offline   Reply With Quote
Old 08-06-2012, 09:57 PM   #3
S3XPanther
by Odeon
S3XPanther's Avatar
Drives: '12 SS/RS A6 IOM SOLD, '13 1LE IOM
You can do it with just a supercharger.
Procharger running 10psi on a friend's stock LS3 made 604rw.
"It works 60% of the time, every time."
"Some say it's a waste of time, others say it's an incredible waste of time."
"The ultimate measure of a man is not where he stands in moments of comfort and convenience, but where he stands at times of challenge and controversy."
2013 IOM SS/RS - 1LE. Born 5/6/2013 (1 of 32 1SS IOM 1LE's)
S3XPanther is offline   Reply With Quote
Old 08-06-2012, 09:57 PM   #4
S3XPanther
by Odeon
S3XPanther's Avatar
Plus headers of course.
Old 08-06-2012, 10:34 PM   #5
RetroXI
ME9ATRN
RetroXI's Avatar
well heres the other catch, i wanted all 600 to actually be useable and i heard only a certain amount is used, i.e. the ss, dont you loose 30-60 hp (i could be WAY off) useable hp?
Old 08-06-2012, 10:46 PM   #6
xjer22x
xjer22x's Avatar
Drives: 2010 rs/ss black # 10,308
when talking about horsepower rating there are two types that people reference. First is:
FLYWHEEL or ENGINE power- this is the actual power that the engine is producing before any drivetrain loss in calculated in. I.E. they advertise the camaro SS produces 426 hp at the flywheel. so the actual that is used is less at the wheels.
the other is WHEEL horsepower- this is the actually amount of power that is usable at your tires on the road. Generally to get a rough idea of what this power is you can deduct 18% due to the drivetrain drain and other factors. so the camaro SS would be 426 x .18= 76.68 lost so a stock camaro would roughly make 350 wheel horse power.
hopefully that wasn't too confusing and helps.
hopefully this helps.
xjer22x is offline   Reply With Quote
Old 08-06-2012, 10:52 PM   #7
S3XPanther
by Odeon
S3XPanther's Avatar
That's why I said rw
Old 08-06-2012, 10:53 PM   #8
S3XPanther
by Odeon
S3XPanther's Avatar
Seems like you need to expand your knowledge of what you're getting into here.
Old 08-06-2012, 11:11 PM   #9
chappy48
chappy48's Avatar
Drives: 2010 Camaro Auto 2SS/RS
Auto or Standard? Much easier to reach 600rwhp on a Standard. Most supercharger kits combined with LT headers will get you close. Add a Cam and it's pretty much guaranteed But then you need to start looking at keeping your car alive. Built Trans, stronger axles, beefed up engine internals, etc...
Built by Jannetty Racing
670rwhp/649rwtq...Scariness to be determined.
Jannety Racing forged 416.
TVS2300 Supercharger w/Maggie Max Stage 2, 3.6 Pulley, Innovators West 8 rib conversion, OD rear Cog belt drive.
Jannetty Racing Rough Idle Cam, LS3 Conversion.
Jannetty Racing built 6l80e Trans, Jannetty Racing Custom Converter, Built rear diff w/ 3.45 gears, DSS driveshaft and 1400 hp axles.
ADM Twin Pump Fuel System, ADM CAI, Dynatech 1 7/8" Coated Headers, Borla "S" Catback.
Custom 18" Forgestar F14's, Nitto 305/45-18 DR's
chappy48 is offline   Reply With Quote
Old 08-06-2012, 11:41 PM   #10
CyberPredator
50 Shades of Prey
Drives: TT/SS
Twin turbo kit works. 6psi should put you right around 600+ without buying a cam or exhaust or anything else. Just the kit on a 6sp car. 8 psi should break 600 on an auto without any issue
Futral Motorsports built and tuned
CyberPredator is offline   Reply With Quote
Old 08-06-2012, 11:45 PM   #11
camslambam
Drives: 2010 SS, 06 SRT10 Ram
Depends how you want your power band.
If you want a solid 600rwhp all across your band that's going to be very hard to obtain.
Traditionally a top mounted s/c would be your best bet to get lots of low end torque and up top power. But a top mount will require cam/more boost to hit that rwhp number you want. Where as a centri will hit it much easier but it will lack that low end grunt that a top mount would have.
Really depends on your goals. I have seen lots of 550rwhp tvs2300 faster than other turbo/centri 600rwhp cars because they carry power consistently through the power band.
camslambam is offline   Reply With Quote
Old 08-07-2012, 01:26 AM   #12
Blk-Ice
750HP of Twisted Reaper!
Blk-Ice's Avatar
Drives: Blk 2SS/Blk Carb Fibr NS-1 stripes
Google LMR in Houston Tx and check out their packages.
Fear the LMR Twisted Reaper Brotherhood!
Blk-Ice is offline   Reply With Quote
Old 08-07-2012, 02:52 AM   #13
RetroXI
ME9ATRN
RetroXI's Avatar
Your Absolutely correct, im just now getting into what under my hood, so bare with me and i thank you for taking the time to explain it
Old 08-07-2012, 11:41 AM   #14
xjer22x
xjer22x's Avatar
Well I took the twin Turbo route to get me to the 600hp goal. Due to being more efficient when it comes to how the power is made all I had to do was bolt on the Turbo kit, upgrade the fuel system a little bit, and get it tuned.
Not once did I ever have to take a part of my engine off to make it reach these levels and that's always nice.
Sent from my SAMSUNG-SGH-I747 using Tapatalk 2
