Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro ZL1 Forum - ZL1 Specific Topics > ZL1 Wheels/Tires
Old 08-07-2012, 03:48 PM   #1
ZL1LEGEND
ZL1 - The Legend Returns!
ZL1LEGEND's Avatar
Drives: 2013 ZL1 Camaro
18" Drag radials on the ZL1
For those who are using 18" drag radials on thier ZL1 which wheels are you using? Vette wheels? Size and tire choice also?
Thanks
ZL1LEGEND is offline   Reply With Quote
Old 08-07-2012, 03:54 PM   #2
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
The rear brakes look to be the same as on the SS, so you should have all the same wheel choices.
SUX2BU is offline   Reply With Quote
Old 08-07-2012, 04:00 PM   #3
ZL1LEGEND
ZL1LEGEND's Avatar
Thanks. Looking to buy a spare set of wheels to house 305 rear tires. Looking for recommendation on what others have done.
Old 08-07-2012, 04:08 PM   #4
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
The cheapest would be any of the 18x9.5 vette wheels everybody runs. Even the ZL1 engineers have run them.
Old 08-07-2012, 06:52 PM   #5
Bolt-onC6
Drives: 08 Corvette
Yes, and have two wheels narrowed to 6 1/2" wide for the front as a semi-skinny that looks the same.
And with 186 mph rating you can drive this tire on the street or strip. It actually looks much better than in the picture. http://www.performanceplustire.com/t...05_SLASH_45-18
Bolt-onC6 is offline   Reply With Quote
Old 08-07-2012, 07:33 PM   #6
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
Honestly the $$ you would spend on narrowing is not worth the minimal weight savings.
For about the same $$ you could buy actual skinnies with radial fronts that weigh in at 33 lbs each.
Old 08-07-2012, 07:50 PM   #7
Bolt-onC6
Drives: 08 Corvette
I paid $200 each for my two narrowed and $89 each for tires plus actual shipping of course. Yes a little cheaper for actual skinnies up front but will look much better with matching wheels. And you don't have to change out four wheels with each track visit. Run Mickeys in the back all the time and don't have to change either. Just don't drive 70 mph on wet roads with Mickey's in the back.
A factory wheel on the front with a Z06 in back doesn't look terribly good on a $60K car, IMO!
Old 08-07-2012, 08:05 PM   #8
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
Those tires are 25.3" tall. Most guys around here run 305/45 18 drag tires, which are 28.8' tall. The stock tires are 28.4" tall. I don't think any ZL1 owners are gonna neuter their cars handling by driving around on short/skinny fronts all the time, LOL.
Old 08-07-2012, 08:24 PM   #9
Bolt-onC6
Drives: 08 Corvette
Obviously you have to select the correct rear diameter for the ZL1s offsets.
Old 08-07-2012, 08:43 PM   #10
ZL1LEGEND
ZL1LEGEND's Avatar
So from what I've seen and read a stock 9.5" Z06 wheel will fit the rear of the ZL1 with a 285(?) drag radial? This would be the front wheel from a stock C6 Z06 correct?
Old 08-07-2012, 08:47 PM   #11
xjer22x
xjer22x's Avatar
Drives: 2010 rs/ss black # 10,308
That is correct. The main reason for the front is the offset.
Sent from my SAMSUNG-SGH-I747 using Tapatalk 2
xjer22x is offline   Reply With Quote
Old 08-08-2012, 12:14 AM   #12
2012ZL1
CaRaHoLiC
2012ZL1's Avatar
Drives: '12 ZL1,67 Cam,68 Biscayne 427 4 sp
I ordered the black Z06 9.5" wheels for the rear. Got them on ebay for 100 bux each.
2012 ZL1
2.55 upper, 10" lower pullies, Innovators west billet hub and sfi balancer, solid blower drive isolator, 50 mm idler kit, full length S/S headers no cats, comp cams custom grind cam, comp roller rocker trunion kit, comp push rods,dual valve springs retainers and locks, Injector dynamics ID850 inectors, Rotofab ZL1 cold air kit, Lingenfelter 160 thermostat, Rotofab intercooler reservoir, stock plugs, LS7 90mm throttle body, GTO clutch reservoir mod, my own custom catch can, Tuning by Jannetty, install by me.
2012ZL1 is offline   Reply With Quote
Old 08-08-2012, 01:11 AM   #13
ZL1LEGEND
ZL1LEGEND's Avatar
What size tires are you running on the 9.5" wheels?
Old 08-08-2012, 01:46 AM   #14
xjer22x
xjer22x's Avatar
305/45/18 nitto DR
